'79 Hardtop weatherstripping - FSB Forums
Thread Tools Display Modes
Old 08-30-2012, 09:20 PM   #1
SteelSteeds
SteelSteeds's Avatar
Bronco Info: '79 Freewheeler
I've searched and haven't found any information, does anyone have any photos of how the weatherstripping for the top is installed?
The long quarter panel to top pieces are self explanatory, it's the two pieces along the front leading edge I'm having trouble with. It appears one piece is attached to the body of the Bronco, and the other is glued to the top itself. I'm having a hard time figuring out the proper orientation.
The w/s on my top is long gone, apparently hasn't been on there in the 18 years I've owned it and I never really noticed the glue residue where it was. And I think the w/s on the body must have been removed by the body shop, or it too was missing, because I have no memory of it...
Lance
'79 Bronco - Freewheeling Package
429/C6/NP205
SteelSteeds is offline   Reply With Quote
Old 08-31-2012, 01:43 PM   #2
379sinvb
Resurection Ranch
379sinvb's Avatar
Bronco Info: Blue Eyes,Black Stallion & Yeller
I've got the top off of mine right now Lance and will try and get you some pics to go off of. Weatherstripping was in place on mine when I got new ones so I had a reference to go off of. However I'm not 100% sure it was factory installed obviously.
ForOffRoadDomination
Rick
My Projects- "Left for Dead"
Yellers Build
379sinvb is offline   Reply With Quote
Old 08-31-2012, 04:10 PM   #3
speedyweasel
Certified Asshat
speedyweasel's Avatar
Bronco Info: Dentside Bronco & '04 Excursion XLT
Post those pics in here if you would, Rick. I need to replace mine and would like to see them, too.
speedyweasel is offline   Reply With Quote
Old 09-01-2012, 04:25 PM   #4
379sinvb
Resurection Ranch
379sinvb's Avatar
Pictures as requested. Good sticky adhesive is required for this stuff. I've found that every year I take this thing off I always have to reglue a section or two. Of course when you leave on the ground like I did this year certainly doesn't make it any better
Truck
I hope these help.
Rick
Yellers Build
Old 09-01-2012, 05:22 PM   #5
psychlopath
Ranger: 2001 - Present
psychlopath's Avatar
Bronco Info: 1979 Freewheel'n, PowrLok, ARB, OBA, and anything else I can cram in
Hairy chap, isnt he?
-Be, Know, Do
psychlopath is offline   Reply With Quote
Old 09-02-2012, 07:50 PM   #6
7LBRONCO
7LBRONCO's Avatar
Bronco Info: 78 XLT, 429 Thunderjet, C6, sh ackle flip in rear, 4" springs in front, 4.56 gears, f& r trac loc
Clean the inside of the top really well, including getting rid of loose paint. I used 3M trim adhesive, brushed on both the top and the weatherstrip. Let dry until tacky,and then start pressing the weatherstrip in place.
7LBRONCO is offline   Reply With Quote
Old 09-04-2012, 02:40 PM   #7
speedyweasel
Certified Asshat
Trade you seats?
And I think you can probably lose the windshield shades now. They're probably not doing a whole lot anymore.
Old 09-04-2012, 03:15 PM   #8
379sinvb
Resurection Ranch
379sinvb's Avatar
Keeps the seats cooler. That black is smoking hot this time of year. Those seats are awesome let me tell ya.
Rick
Yellers Build
Old 09-04-2012, 03:16 PM   #9
speedyweasel
Certified Asshat
Rub it in, why dontcha?
Old 09-05-2012, 04:20 PM   #10
SteelSteeds
Fantastic, thank you very much! That answers all of my questions perfectly, and also reveals that I'm still missing one piece: I don't have the vinyl that slips over the inner seam on the top opening (white, in your case). I'll have to source some of that.
Now that I know which body seam that double piece goes on, and the correct orientation, I can get that one installed tonight.
Thanks again.
Lance
429/C6/NP205
Old 09-05-2012, 11:17 PM   #11
379sinvb
Resurection Ranch
379sinvb's Avatar
I will
Thanks again.
You are welcome my friend.
Rick
Yellers Build
Old 12-13-2012, 08:57 PM   #12
78-U10
Is the weatherstripping you buy for the 78-79s any good? I mean does it actually fit or does it require a zillion hours to fit up correctly.
78-U10 is offline   Reply With Quote
Old 12-14-2012, 09:25 AM   #13
CBboots
CBboots's Avatar
Bronco Info: 79 Custom, 460, C6
I got all the weatherstrip for the topper from JBG earlier this year and it fit like a glove. The end section that fits into the tailgate needed a little love, but not that bad at all.
My 79 build http://www.fullsizebronco.com/forum/...d.php?t=207864 - Aluminum 3-core radiator, Mallory 85 HEI conversion distributor, High Angle Driveline One Tons front and rear, JBFAB Twin stick shifter kit, True trac differentials front and rear, Yukon 4.56 gears front and rear, Moser Extreme 31 spline rear axles, Borgeson adjustable steering shaft and rag joint, 95 amp 3G alternator, Fireguy/RJM Tech upgraded headlight harness, and a ton of other crap!
CBboots is offline   Reply With Quote
Old 12-14-2012, 12:56 PM   #14
speedyweasel
Certified Asshat
Good to know, Christian. I've been pondering whether to go to Dennis Carpenter ($$$$) or JBG ($$) for those. If JBG's work fine, I may as well save a few pennies.
Old 12-15-2012, 09:39 PM   #15
CustomNewbie
Bronco Info: 1979 custom with a 400
LMC has them pretty cheap and their catalog shows the exploded view of parts orientation, helped me see why there is two seals for the same area.
CustomNewbie is offline   Reply With Quote
Old 12-16-2012, 11:53 AM   #16
Mels
Sway Is My Fan Club.
Mels's Avatar
Bronco Info: '78 Ranger XLT - 429/C6, 4"s/35s. '88 XLT - 351/C6, 6"s/35s
Do NOT buy any rubber weatherstrip stuff from LMC. All they're good for are knick knack stuff and the exploded diagrams in their catalogs.
'66 F100 -- Little Black
'78 Bronco -- Brutus
Mels is offline   Reply With Quote
Old 12-17-2012, 02:55 PM   #17
speedyweasel
Certified Asshat
^^ Ouch.
Old 12-18-2012, 08:30 AM   #18
rangervall
rangervall's Avatar
Bronco Info: 2x 78 Bronco Customs
I got mine from http://www.dennis-carpenter.com/pdf/66-96Bronco.pdf
Some of the stuff is more expensive but well worth the quality IMHO.
rangervall is offline   Reply With Quote
Old 12-18-2012, 10:01 AM   #19
outlawbob
Bronco Info: 1978 & 1990
Dennis sells his stuff to the other sites......he has the machines in charlotte to make the rubber..but his price is higher for that reason..Get it from JBG..I did and I am very happy with it.
outlawbob is offline   Reply With Quote
Old 12-18-2012, 03:01 PM   #20
speedyweasel
Certified Asshat
bob, the JBG isn't from Dennis Carpenter, is it? Carpenter's stuff is great but it's expensive as hell.
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
