#1 |
iTrader: (0) Bronco Info: 1979 bronco,351m C6 np 205,
What type of oil in a 1978 c6?
Hi,
Do i need a type F oil or dexronIII in a C6?? I used the search fonction, i almost always find the answers i need but not this time... An old guy at work told me that it need type F, Ford=type F. The Napa store dosent have any pint of type F in stock. I must be surely for car older than my bronco (1978). Thanks, Marc |
| Sponsored Links | |||
Advertisement | |||
#2 |
SOD BUSTERS Member
I would agree with the type F, its what is in my '78.
I got it from a farm supply store
![]() '92 Eddie Bauer- C6/208 swap, Roller 357W, MAF, RJM Harness, BlueOvalChips SCT Tune '78 Custom- 4" Superflex Lift, Mild 460, 8 Point Cage, 4.10 Gears, 35" MTZ's '96 F250- Tow Rig, 460, E4OD Punisher Valve Body, Triple Piler Gauges '92 F150- 2wd, Winter Beater, 3.73's, 5.0 '79 F250- 2wd, Farm Truck, Waiting Restoration '03 SVT Focus- Daily Driver, OZ Wheels, 6 Spd '86 Mustang- Fastback, SOHC 4.6L Swap Project |
#3 |
Thanks 351w500
![]() ![]() Join Date: Mar 2005
Location: Northcentral,CA.Twain Harte, up here in the mountains
iTrader: (52) Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
Yes type F, try a different store you shouldn't had any problems finding this fluid.
And it's Fluid not oil if you ask for it.
![]() I take Prayer Requests. God Bless |
#6 | |
iTrader: (0) Bronco Info: '87 Bronco Custom; 300cid EFI w/ 3" exhaust; 35" Goodyear Wrangler Kevlar MTRs on 15x8; 2.5" lift
Unless the trans has been rebuilt; usually a rebuilt will use modern internals (friction material) and then require Dextron or something equal.
"I'll try to be nicer if you'll stop being an idiot." Quote:
#8 | |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
Stick with Type F. Ford still produces it, and Ford doesn't recommend Mercon for transmissions built for F.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
