#1 |
iTrader: (0) Bronco Info: 1993 Bronco XLT, 302, e4OD, 147k, no mods 1983 F100, 300, 3-speed 80k
Cheap way to get 19 mpg - 5.0
So I recently drove from Buffalo to Long Island, about 1050 mi round trip. On the way down I was averaging about 12.5 mpg
. I bought the truck with about 143k miles so I knew the engine needed some cleaning/maintenance. I only did two things to get 19 mpg. First I ran a full tank of Shell gas. I then filled up one more time and added Lucas Oil Injector Cleaner; http://www.amazon.com/Lucas-10003-Cy.../dp/B000ARPVOI.On the way back up I drove about 65-70 mph and got 18.88 mpg. |
| Sponsored Links | |||
Advertisement | |||
#2 |
I Swallow on 1st date.
![]() Join Date: Aug 2004
iTrader: (8) Bronco Info: 2006 Kia Spectra
if it was that easy everyone would be getting 19mpg. something else was awry, your right foot, hills, wind, craptastic fuel quality, etc.
no fawking way you get a gain of 6+mpg from putting in one bottle of fuel injector cleaner.
2006 Kia Spectra 4 banger/5 speed. Anything for you Saltlife! "Kids, they see the good in everything and through their eyes, they open ours." - Hank Davis |
#3 |
I knew my injectors were bad, mostly because the engine had such high mileage. I agree these gains aren't going to work for everyone.
As for gas quality, on the way down I used 4 different brands of fuel with a consistent 12.5 at 70mph. I stayed at 65 mph at one point and got 12.8, but after the shell gas and lucas oil treatment, I got 18.8. people may not get that much gain, but it should help. |
#4 |
just because injectors are high mileage doesn't make them bad. my minivan had 263k on the injectors and it ran fine, got 20-22mpg in town and 25+ on the highway.
I say something else was wrong. Besides, i have a hard time buying that a 5oz bottle of lucas will treat a 33gallon tank.
#5 |
![]() Join Date: Jul 2009
iTrader: (1) Bronco Info: 90' 351/E40D 38" tires, 4.88 gears, full float 8.8, lockers F&R
If you went from 8 mpg to 14, I might believe it. But 18.8 is almost not possible in a Bronco. Certainly a tank of ethinol gas and some injector cleaner is not going to do it. I think more likly your measuring method is not so good.
#6 |
Well first of all I have a 28 gallon tank.
Second of all, I don't care whether you believe it or not haha, this is what I did and these were my results. I drove 378 miles and used 20 gallons of gas. Measuring mpg? You're kidding? Fill your tank, drive, fill your tank. Divide miles driven by gallons of gas used. |
#7 |
ok, 28 gallons. still, 5oz of cleaner to 28 GALLONS...think about that ratio for a moment....
your math may be correct, however you'd be amazed at how much just a few hills and a decent headwind will absolutely murder your fuel mileage.
#8 |
This is NOT good. I thought we all bought Bronco's because they ran on whale oil and panda tears... Isn't the point to get bad gas mileage in these things so we can ruin the o-zone and make summers last longer?
#9 |
I took the New York Thruway down and up, so i went over the same hills. As for the wind, I agree, but both days I drove had mild wind conditions.
I'd just like to point out that I also have an exhaust leak, and once thats fixed, I should be able to get slightly better mileage than this. I don't know why people think these get horrible mileage, these things are supposed to get 17mpg on the highway. Also, I had bought the 33oz bottle in the link, and 1oz treats about 5 gallons. I'm guessing the treatment is more common in a 5oz bottle? |
#10 |
Purveyor of FSB Swag
I have periods of time where I get extremely good economy with my Bronco, but they're not consistent. I think the E4OD helps a lot, it definitely keeps the RPM's down. I once thought I was getting close to 20 MPG, but after further and more accurate testing, I was getting more like 15-16, which is still good in my book.
The idea that the Lucas oil could make that much difference on its own? I'm thinking you may have had something plugged up, or you were getting a bad signal from your O2 sensor and the oil affected the reading... but I don't think your measuring methods when you filled the tank may be accurate. How are your sure that when you refilled the tank that you got the exact same amount of fuel in? A half gallon would change your numbers considerably. I'm not calling B.S., I'm just thinking that something other than the oil is responsible for such a drastic change. |
#11 |
Man I hope it's consistent, I have to make a few more trips back and forth. I think my foot had a lot to do with the difference as well. The method I used to measure the fuel, was to fill it back up 28.1 gallons. Thats the maximum capacity for my tank. I may be off by .0XX but that would only make a slight difference in the solution.
#12 |
![]() Join Date: May 2007
iTrader: (1) Bronco Info: 95 302 5spd 4.56 w/Detroit in the back 33" tires, warn winch and Custom Soft Top
I am not %100 sure but if your driving a 93 Bronco the odds are good that it is suposed to have a 32 gallon tank. What are some specs on your ride? That would give us something to go on. They might? have been tagged at 17 MGP highway 20 years ago but now
#13 |
Perhaps. I drive a 93 5.0 with an E4OD, running 31.5x10 tires, at 65mph rpms are at a little under 1900. Cruise control doesn't work. Am I missing something?
Actually looking it up now, it says I have a 33 gallon tank. Do these things have a reserve? Not like the size of the tank matters. I only need to know how many gallons I put back in. |
#15 |
iTrader: (12) Bronco Info: 88 FSB. 4.9l -T18-BW1356-33" MTs-Warn hubs
I was getting 19mpg with 31s, on the street.
J A S N http://www.supermotors.net/registry/19528
#16 |
iTrader: (1) Bronco Info: 1992 Bronco Custom, 302/5 speed/4x4. pretty much stock.
The cheap way? Take the Bronco emblems and stick them on your car.
1988 Thunderbird Turbo Coupe, 2.3 OHC with turbocharger and intercooler/5 speed, time warp late 80's high speed road trip car/police magnet.... 1992 Bronco Custom, 302/5 speed, lots of new stuff 1993 Tempo GL 2-door, 2.3 HSC/5 speed, my first car, probably giving to girlfriend to drive so I can justify keeping it around |
#17 |
if you put 28.1 gallons in a true 28 gallon tank means two things. 1.) the pump you went to fawked you. 2.) you would have never made it to a gas station.
#19 |
iTrader: (0) Bronco Info: 79 Ranger XLT-460,NP435,NP205,stock axles/3.50's,2.5"RC lift,33"trxxs mt's,72 impala horn(best mod)
i got 11 mpg in mine once..
...that was before crappy E10 gas that we are forced to buy.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
