78 Fs frame ranger body swap - FSB Forums
Thread Tools Display Modes
Old 09-23-2012, 07:28 PM   #1
78'FSB
So I'm the proud new owner of a 78 FSB. I took it off roading for the first time up in Michigan. It performed very well except for the body mounts that were pretty much gone. The whole underside of the bronco shell is very rusty and structurally unstable, even to weld reinforcements on. So I was wondering, does anyone have any info/experience swapping a first or second gen. ranger body (83-92) onto a full size 78 bronco frame? Any information would be very helpful, thanks!
78'FSB is offline   Reply With Quote
Old 09-23-2012, 08:19 PM   #2
96XLTJD
96XLTJD's Avatar
NO DONT DO IT.
96XLTJD is offline   Reply With Quote
Old 09-23-2012, 08:24 PM   #3
78'FSB
Why not?
Old 09-23-2012, 08:29 PM   #4
66CC
Show us some pics.
You can cut and replace a lot of tin before throwing the body away.
66CC is offline   Reply With Quote
Old 09-23-2012, 08:45 PM   #5
78'FSB
If I had to, I could do a lot of welding and reinforce it, but I like the idea of tires sticking out more then that almost 7 foot wide body, I'm building for tighter trails and if my tires are going to hit before my body does, then I can maneuver that much easier. My plan is to actually cut the front of the ranger bed out and the back of the cab and weld it together to make my own mini-bronco. I'm looking for any info to see how it fits on the frame before I buy a ranger body
Old 09-23-2012, 08:55 PM   #6
78'FSB
How do I post pics since I can't add attachments?
Old 09-23-2012, 09:02 PM   #7
379sinvb
Resurection Ranch
379sinvb's Avatar
Bronco Info: War Horse,Blue Eyes,Black Stallion & Youngblood the newest member.
You're a noob so I'm going to take it easy well maybe.
Here is where you post questions:
http://www.fullsizebronco.com/forum/...splay.php?f=21
Here is how you post pictures:
http://www.fullsizebronco.com/forum/...ead.php?t=6204
Maybe search a little and read a little before we go giving us your 2 cents.
I have not seen the Ranger on 78 frame but there is one in the General Section.
Rick
My Project- "Left for Dead"
379sinvb is offline   Reply With Quote
Old 09-23-2012, 11:57 PM   #8
Redwagon
rolling Rolling ROLLING....
Bronco Info: 93 Cherokee
moved to correct forum....
Tim
Newest token Jeep owner....
Redwagon is offline   Reply With Quote
Old 09-24-2012, 08:56 AM   #9
reptillikus
ate lug
reptillikus's Avatar
Bronco Info: 88ish bronco(?)/96 F250; both with D60s
Do a search for the user The Legend, he put a 80s Ranger body on his 77 frame. Its a pretty badass truck.
reptillikus is online now   Reply With Quote
Old 10-08-2012, 03:16 PM   #10
f150inline
f150inline's Avatar
Bronco Info: f150
Why a ranger body if you want to build a mini bronco? just use a bronco 2.
96 f150 straight 6, d44 SAS, 4.56s, Aussie lockers, 35 inch mtrs. My build thread http://www.fullsizebronco.com/forum/...d.php?t=213623
f150inline is offline   Reply With Quote
Old 11-13-2012, 02:50 PM   #11
I6 Bronco
Bronco Info: 300 I6, 79 bronco Frame 84 F150 cab
Dont let them sway you, If its junk its junk. Mine was.....well, it might still be. But still.
I6 Bronco is offline   Reply With Quote
Old 11-13-2012, 06:55 PM   #12
78-79FordMan
Ford Hoarder
78-79FordMan's Avatar
Bronco Info: 7 of them 1978-79's
fix'en to do a '86 ranger on a '79 bronco frame. because the bronco is beat to crap rusted out . and has no title...
Ford It Man
78-79FordMan is offline   Reply With Quote
Old 11-13-2012, 07:28 PM   #13
Andrew James
Age. Fac ut gaudeam
Andrew James's Avatar
Bronco Info: 1989 Bronco Custom 4.9/M5OD EFI
Put a Bronco 2 body on it.
1991 Ford Bronco XLT 5.0/E4OD EFI
1996 Ford Bronco Eddie Bauer 5.8/E4OD EFI
1990 Pontiac Formula Firebird 5.7/T5 TPI
1991 Ford F150 Custom 4.9/M5OD EFI
1993 Ford Mustang Convertible 2.3/AOD EFI
Andrew James is offline   Reply With Quote
Old 11-13-2012, 07:32 PM   #14
bronco466
Bronco Info: 96 bronco all stock
the ranger body swap is not to bad at all we have done a couple of them the bronco 2 is alot shorter then the full size
bronco466 is offline   Reply With Quote
Old 11-13-2012, 07:43 PM   #15
78-79FordMan
Ford Hoarder
i scraped and sold all my bronco 2 .. and even my rangers 2 years ago .. so i bought the ranger for a $100 that i am going to use.. and i don't what to use a big heavy body .. as mine will only be using a gutted out body.. i probably want use the front clip .. i will be building something like Dooley's dodge on Mudstruck.com
Ford It Man
You may not post replies
Forum Jump
