swapped my psom.... nothin - FSB Forums
Thread Tools Display Modes
Old 10-15-2012, 06:04 PM   #1
musclegto
well, since I bought the truck about a month ago. In attempts to fix my hard shifting I swapped the VSS. Since then the ABS light has been on, leading me to believe the original sensor was good and this new autozone was bad from factory.
I pulled codes, got nothing, so then I figured it had to be the PSOM. Picked one up this weekend from 95 that was being parted out. Got the whole gauge cluster and looked in good condition. Swapped the speedo, fired her up and.... nothing.
Speedo still does not work, still shifts hard. What is more likely, that the donor PSOM was also bad? or that my problem is not in the PSOM but somewhere else? I ordered a VSS from FORD to get rid of the ABS light.
95' 5.0/E4OD
musclegto is offline   Reply With Quote
Old 10-15-2012, 06:07 PM   #2
sackman9975
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
I'm betting that your ABS module took a dump. There is a way to bypass it. And You should do this anyways just to rule this out. There is a link........I'll have to find it. I've done mine as my module went bad and speedo went south.
~ Scott ~ ~ Ford's, please bring back the Bronco!! ~
~ My Exhaust clip on YouTube ~ 203k on the odometer and no longer a daily driver. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
sackman9975 is offline   Reply With Quote
Old 10-15-2012, 06:09 PM   #3
sackman9975
Here's the link.
http://www.fullsizebronco.com/forum/...d.php?t=141328
Old 10-15-2012, 07:00 PM   #4
musclegto
I will go ahead and try it, hopefully thats it.
95' 5.0/E4OD
Old 10-15-2012, 07:03 PM   #5
catsnw
A broke kid with a bronco
catsnw's Avatar
Bronco Info: 1995 EB bronco 5.8, auto, true duals, k&n intake, 3G alternator, 12 front lights (more to come!)
X2
Happened to me too. Easy to bypass.
Originally Posted by 88LiftdBronco View Post
So what you're saying is, that when you see a penis you think of another guy?
٩(●̮̮•)۶
catsnw is offline   Reply With Quote
Old 10-15-2012, 08:18 PM   #6
silent one
silent one's Avatar
Bronco Info: 1995 sport,6''DC Stage II 37's streetlocks 4.56's ARB,BroncoAir rear bumper Hefty Fab front bumper
Why would the ABS make the tranny shift hard.
What shifts are hard.
MALL CRAWLER EXTRAORDINAIRE
Silent One's Supermotors Page
January 2010 FOTM Winner
silent one is offline   Reply With Quote
Old 10-15-2012, 08:26 PM   #7
musclegto
All of them, even reverse. But 1st to 2nd is the worse one.
95' 5.0/E4OD
Old 10-15-2012, 08:50 PM   #8
catsnw
catsnw's Avatar
When the abs computer burns it cuts the vss square wave off from the Psom. The Psom sends the readjusted signal to the trans telling it when to shift. That why you should reprogram the Psom with a tire change.
Vss signal basically travels like so
Vss====>abs computer=====>psom======>trans.
٩(●̮̮•)۶
Old 10-15-2012, 08:58 PM   #9
4NIC8R
4NIC8R's Avatar
Bronco Info: 91 Silver Anniversary
If you still have issues it is possible it's the tone ring inside the Diff. Rule other things out first though.
An E4OD goes into limp mode when it does not get a signal from the VSS. It's the same sensor that tells the ABS if the rear wheels are locked up. Ergo, if the ABS light is on and the transmission is in limp mode, it's a good indicator that there is a problem with the VSS.
4NIC8R is offline   Reply With Quote
Old 10-15-2012, 09:04 PM   #10
catsnw
catsnw's Avatar
Or the wires. A broken wire will do the same thing. If the tone ring is messed up then you should hear it bc you would has other probelms INSIDE the axle.
٩(●̮̮•)۶
Old 10-15-2012, 10:20 PM   #11
sackman9975
Agreed.....
Plus the Speedo should still move. It may bounce horribly, but should still move. ABS module gone bad equals no Speedo at all.
Old 10-15-2012, 10:40 PM   #12
musclegto
jumped the abs module, bingo, speedometer works. Now I it seems like the problems is finding a new one.
95' 5.0/E4OD
Old 10-15-2012, 10:41 PM   #13
musclegto
this wouldn't be it, would it?
http://www.amazon.com/A1-Cardone-12-...nco+abs+module
95' 5.0/E4OD
Old 10-15-2012, 10:42 PM   #14
catsnw
catsnw's Avatar
Originally Posted by musclegto View Post
Do AcDElco or Motorcraft make them?
Not that I know of. eBay or try a junk yard computer. I did that and it worked.
٩(●̮̮•)۶
Old 10-29-2012, 08:58 PM   #15
musclegto
have been looking for one for weeks to no avail? Has anyone seen one around?
95' 5.0/E4OD
Old 10-30-2012, 02:40 AM   #16
Steve83
Steve83's Avatar
Why did you start a new thread?
http://fullsizebronco.com/forum/showthread.php?t=214680
Read this caption, then keep going to the NEXT until you've read everything about 4WABS:
Old 10-30-2012, 05:00 PM   #17
Ranger429
Thats Mr. f#@$head to you
Ranger429's Avatar
Bronco Info: 79 Bronco, 79 F-350
If your asking to buy parts in the open threads the thread will be deleted.
Other thread has been deleted.
http://72.18.199.92/~fullsize/forum/image.php?type=sigpic&userid=4394&dateline=1212879  615
79 F-250 Ranger XLT SOLD_____79 Bronco Ranger XLT 400 35" Cepeks
79 F-350 Supercab Ranger Lariat 4WD, under the knife
Originally Posted by slw210 View Post
I think an administator needs to have a talk with some of the moderators around here.
Ranger429 is offline   Reply With Quote
Old 10-31-2012, 08:43 PM   #18
musclegto
I read the caption as i do with all your links, now i need to find one. :)
95' 5.0/E4OD
Old 11-01-2012, 08:47 AM   #19
miesk5
I used to know this stuff
miesk5's Avatar
yo, I had problems finding one from yards here; 2 were bad.
Raybestos is selling; "Abs Computer Module"
Remanufactured part
http://www.raybestos.com
Select Catalog and go through the drill for the part #; then do a Google
do not order; contact Rock Auto and ask if available because Raybestos may have ceased reman on these units (again)
http://www.rockauto.com
try;
BBA-reman - Bronco/Ford truck remanufactured ABS, ECUs, throttle bodies, air mass meters catalytic converters, etc
call toll free at 1-866-573-2740
Confirm with e mail; be sure to cite Year, Make, Model, etc
USN (Ret) & MIL/DoD Contingency Planner (ret)
THANKS to ALL WHO SERVE!
my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php
Old 11-19-2012, 01:34 AM   #20
musclegto
I have exhausted my sources and have not found one. Hopefully I can found one in a junkyard soon.
95' 5.0/E4OD
You may not post replies
Forum Jump
