Neutral Safety Switch-? - FSB Forums
Thread Tools Display Modes
Old 10-15-2012, 11:17 PM   #1
379sinvb
Resurection Ranch
379sinvb's Avatar
Bronco Info: Blue Eyes,Black Stallion & Yeller
I'm lookin for ideas/insite as to why my Bronco is going through neutral safety switches. The reason I say switches is because in the last 2-3 months I have replaced it three times and four times within the last year.
Thoughts?
Thanks!
ForOffRoadDomination
Rick
My Projects- "Left for Dead"
Yellers Build
379sinvb is offline   Reply With Quote
Old 10-16-2012, 12:18 AM   #2
78bronco460
press ALT+F4
78bronco460's Avatar
Bronco Info: '78 Bronco with motor, axles and stuff
Manual or automatic trans?
78bronco460 is offline   Reply With Quote
Old 10-16-2012, 07:34 AM   #3
CrazyBRONCOguy
CrazyBRONCOguy's Avatar
Bronco Info: See Signature
shorted out somewhere, as in a wire has some insulation missing and it happens to hit in the right metal spot sometimes.
'92 Eddie Bauer- C6 Swap, Roller 357W, AFR, SRP, H-Beam Rods, MAF, SCT Tuned, 4" Lift, 4" Exh, 4.10's, 33's
'78 Custom- 4" Deaver Lift, Mild 460, 8 Point Cage, 4.10's, 35" MTZ's, Clydesdale Steering, WH Trac Bar
'96 F250- 460, E4OD Punisher Valve Body, TriplePiler Gauges, Crane HI-6S Ign
'05 Excursion- V10, Warn Hubs, Coffin Muffler, Volant CAI
'92 F150 '79 F250 '86 Mustang '95 T-Bird '08 DS450 '01 Banshee '86 TRX250R
CrazyBRONCOguy is offline   Reply With Quote
Old 10-16-2012, 10:58 AM   #4
379sinvb
Resurection Ranch
379sinvb's Avatar
It's an automatic tranny (c6).
Rick
Yellers Build
Old 10-16-2012, 09:34 PM   #5
BigWheelz
Bronco Info: 1978 Bronco, 466 EFI
Crappy taiwan switch is all that is available for the 78-79.
Get a motorcraft switch for a 1986 with C6 and splice in your old connector.
Opportunity is missed by most people because it is dressed in overalls and looks like work- Thomas A Edison
BigWheelz is offline   Reply With Quote
Old 10-18-2012, 01:04 AM   #6
379sinvb
Resurection Ranch
379sinvb's Avatar
I'll take a look at the wires this weekend for any breakdowns. I'll also be looking for a MC switch incase it goes again.
Thanks fellas!
Rick
Yellers Build
Old 10-18-2012, 08:46 PM   #7
BigWheelz
Thanks fellas!
Look close at the taiwan switch....it will be separated where the case and plastic glue together.
Old 10-18-2012, 09:20 PM   #8
379sinvb
Resurection Ranch
379sinvb's Avatar
I have the bad one I just pulled and will inspect it, thanks.
Rick
Yellers Build
Old 10-23-2012, 11:03 PM   #9
379sinvb
Resurection Ranch
379sinvb's Avatar
Here is a pic of the one I just removed. As you said, the plastic is seperated from the housing.
Rick
Yellers Build
Old 10-24-2012, 01:38 AM   #10
Ziggy
Ziggy's Avatar
Bronco Info: 79 Bronco
Same thing happened to mine, bought a Standard Blue Streak and haven't had any problems with it since.
3G Alt. Upgrade, Duel Batteries, 351M bored .030 over with Edlebrock cam and intake, C-6 w/AO4D internals, 3" lift w/RS 9000, 33x12.50 MTR's, Saginaw PS Pump Conversion, On Board Air, Detroit Locker, Hydro Boost Brake System, Altimeter from a CH-46D, Map Light from a MH-53E.
U. S. Government - Wasting paper and keeping Lumber Jacks gainfully employed since 1776.
Ziggy is offline   Reply With Quote
Old 10-24-2012, 12:22 PM   #11
Ranger429
Moderator
Bronco Info: 79 Bronco, 47 Binder
Were you tired when you posted this? I have yet to see a NS switch on a manual trans.
Originally Posted by 351w500 View Post
My sister in law is 3 months pregnant and next week I'm gonna shove a loaded .357 up her coochie just to familiarize the kid with weapons !
Ranger429 is offline   Reply With Quote
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
