Weld on 78/79 trac bar riser. Any need for this? - FSB Forums
Thread Tools Display Modes
Old 10-22-2012, 02:48 PM   #1
wildhorses
Bronco Info: 1978 Bronco
Made some proto types. These are specific to 78/79 Hi pin Dana 44. Works with stock or adjustable trac bars. Basically we don't care as much for trac bar drop brackets. Just asking for input. Would anyone need this?
WILD HORSES 4X4
209-943-0991, 640 n. Eldorado, Stockton CA 95202
http://www.wildhorses4x4.com/specials_FS
wildhorses is offline   Reply With Quote
Old 10-22-2012, 02:49 PM   #2
wildhorses
From the back.
WILD HORSES 4X4
Old 10-22-2012, 03:36 PM   #3
CrazyBRONCOguy
SOD BUSTERS Member
CrazyBRONCOguy's Avatar
Bronco Info: Which One?
That doesn't give it bump steer by changing the angle that much of the trac bar in relation to the draglink? assuming you have a drop pitman arm.
I do like that it would be a good way to fix a worn mounting point in the stock location
'92 Eddie Bauer- C6 Swap, Roller 351W, MAF, RJM Harness, B.O.C. SCT Tune, 35" BFG's
'78 Custom- 4" Superflex Lift, Mild 460, 8 Point Cage, 4.10 Gears, 35" MTZ's
'96 F250- Tow Rig, 460, E4OD Punisher Valve Body, Triple Piler Gauges
'92 F150- 2wd, Winter Beater, 3.73's, 5.0
'79 F250- 2wd, Farm Truck, Waiting Restoration
'03 SVT Focus- Daily Driver, OZ Wheels, 6 Spd
'86 Mustang- Fastback, SOHC 4.6L Swap Project
CrazyBRONCOguy is offline   Reply With Quote
Old 10-22-2012, 04:22 PM   #4
wildhorses
The idea is to use the riser instead of a drop bracket in conjunction with a drop pitman arm. We want to keep the angles correct and avoid any bump steer issues.
Another use is to add clearance between the lower trac bar bolt and tie rod when doing a tie rod over. In that case you might skip the drop pitman arm depending on lift amount.
You are right it also takes care of the stock worn out mounting spot.
Thanks for asking.
WILD HORSES 4X4
Old 10-22-2012, 04:40 PM   #5
El Kabong
Driving Stuff Henry Built
El Kabong's Avatar
Bronco Info: -90 xlt, 351w, e4od, 3.55:1, sag, warn hubs, trans cooler, 35" bfg m/t, -73, 400, np435, 35s
You might want to also ask in the Solid Axle Swaps forum. The guys doing swaps seem like they would be likely users, & some of them use 44s.
El Kabong is offline   Reply With Quote
Old 10-22-2012, 07:18 PM   #6
wildhorses
Appreciate the tip we'll do that.
WILD HORSES 4X4
Old 10-22-2012, 08:04 PM   #7
OX1
OX1's Avatar
With 4 inch springs, I regularly stuff the bottom spring cup into the
lower outer edge of frame. Not sure that riser would allow me full travel.
I built a 78 beater many years back with 4" lift on 36's.
I dropped frame end of track bar with a support that
ran to opposite side of frame, tying into stock bolts/plate that
hold upper shock mount (behind axle). Granted that rig
did not have a tie rod over.
I guess it is a trade off of flex vs tie rod clearance (assuming the flip
because without flipping tie rod clearance is a none issue with track bar).
It does seem to me that bumpsteer is just not that big of an
issue on the fullsizes vs the EB. I had street rigs from
stock susp/35's to 9" lift and 44 boggs. Every susp
combo I can think of and never really had bump steer issues.
My 70 EB with 3.5, 33's and perfect geometry still has bump steer,
go figure.
79 XLT, 400/C6/mog 404's/42 IROKS, 8.5" lift.
79 XLT, 400/C6/D60-D44 8 lug, 2" lift, 35 BFG AT
74 Bronc build, 408/C6/Black Box/205/406 mogs/43 SX stickies
OX1 is offline   Reply With Quote
Old 10-22-2012, 11:24 PM   #8
BigWheelz
Bronco Info: 1978 Bronco, 466 EFI
I would seriously consider one if it does not interfere with suspension articulation on the passenger side. From the pics I see a factory bump stop located inches from the mount....
The '78-79 drop trac arm bracket has always been a source of weakness....it multiplies the radial torque applied to the stock frame rail by the axle. I feel the typical drop track bar bracket is a real contributor to death wobble....until now there have been limited solutions. The WH part applies the load to a much more rigid structure at the correct angles.
FWIW I have been looking real close at the clydesdale steering to address the death wobble and general steering response....it is rigid, very nicely engineered, but hard to afford the $890 price.
Keep up the good work WH, Thanks for supporting the limited market that is the 78-79 Bronco.
Opportunity is missed by most people because it is dressed in overalls and looks like work- Thomas A Edison
BigWheelz is offline   Reply With Quote
Old 10-23-2012, 10:58 PM   #9
wildhorses
I knew that could be a potential issue just from the install I did. We will be testing it out to see how much it could limit travel. What coils are you running?
I like the support bar, definitely needed when using the drop bracket.
I would agree. I think some of it has to do with a better tie rod/draglink design in the first place. The drag ties in much farther near the end of the tie rod. Thanks for the input.
WILD HORSES 4X4
Old 10-23-2012, 11:15 PM   #10
OX1
OX1's Avatar
Older 4" superlifts.
Old 10-23-2012, 11:23 PM   #11
wildhorses
We'll be testing it out more this week now that this rig is back on the ground.
We knew the price of the Clydesdale was up there, all I can really say is that the price is a reflection of what we have to pay for them. We also know we are going up against rod end type kits in the $400 range. The Clydesdale is very different and very versatile. One of the first ones we sold went to Australia to be installed on a right hand drive 79 Bronco. (It was converted) With that one all the features of adaptability came into play. After the first install we did on the 77 F150 we thought honestly it looks like this is what these rigs should have come with in the first place.
Thanks for the thoughts. We are looking at the 78/79 with an eye to do primarily new stuff. So we are making it up as we go. The challenge here in CA is the smog laws. You can't really do what you want under the hood. If I could it would run better, faster and cleaner.
WILD HORSES 4X4
Old 12-10-2012, 09:56 PM   #12
bronco_buster
Bronco Info: 74 f100 mine,79 bronco my wifes
Does that weld to the cast C? If so how does that effect the strength?
A El Kabong said you may want to check with the SAS guys. I know more than a few guys that would have solid axles if someone offered an inexpensive kit using stock and modified stock parts. It would save them all of the piecing stuff together.
Stand on it till you make it or bust it then stand on it somemore
bronco_buster is offline   Reply With Quote
Old 12-13-2012, 07:35 PM   #13
78-U10
What happens at full compression with the riser on there? On a 66-77 with a riser and a 5.5" coil at full compression it will for sure hit the frame rail -- not ever rock crawling but at speed for sure.
78-U10 is offline   Reply With Quote
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
