bronco high idle and truns off when lowered - FSB Forums
Thread Tools Display Modes
Old 11-01-2012, 10:59 AM   #1
b-rex90
Bronco Info: 1991 bronco xlt
hi guys i have a 1991 bronco when i bought it it would turn off the second u put in drive or reverse,so i put new plugs,wires,oil,fuel filter ,air filter,ignition coil,idle control valve,and new distributor now the truck drives and has no problem going into gear but the rpm's are at 1500 on idle but when we lower the idle she dies in gear like right away i am at whits end i just bought a scanner and am gonna try when it get to house but i also thought i could have a vac leak but i cant seem to find any
b-rex90 is offline   Reply With Quote
Old 11-01-2012, 11:04 AM   #2
defcon5
defcon5's Avatar
Bronco Info: 1992 XLT 5.8, 3 inch body lift and 33 inch BFG
Come back with the codes then will talk
1992 Bronco XLT, 351w. Mostly stock for now.
http://www.superford.org/registry/ve...il.php?id=3717
defcon5 is offline   Reply With Quote
Old 11-01-2012, 11:32 AM   #3
b-rex90
ill give it a try will see what the hell happens this truck loves to kick my ass lol
Old 11-01-2012, 01:03 PM   #4
JKossarides
JKossarides's Avatar
Bronco Info: 1986 Bronco XLT 4x4 -AOD -Warn Hubs, NEW stock 302EFI, MSD cap, rotor, 48kv coil, 9mm FMSR wires
Definately pull codes and see what elec/electronic faults are indicated but usually cleaning the IAC = idle air control valve does the trick, check test the TPS = throttle position sensor for voltage range, either may pop up as a fauilt code.
Just press the gas pedal down when the idle is high and kick the rpms down until you figure it out.....with sensors a lot depends on how old they are so if you don't know or haven't replaced in some time them now is a good time to do so....
The rule of thumb with the IAC is, if you unplug it and the engine stalls it's one full turn of the throttle body "idle stop screw" inward/right located on the right side of the throttle body, it's spring loaded and I would count the number of screw threads protuding on either side of the TB block if you need to put it back the way it was....
Good Luck ~
Old 11-01-2012, 07:41 PM   #5
b-rex90
thanks JKossarides ill post what codes the scanner post
Old 11-21-2012, 08:08 AM   #6
Big Chief
Bronco Info: 1987 Bronco
Any update on this one? There are a couple of threads on it but never heard if you figured it out? I have the same issue.
Big Chief is offline   Reply With Quote
Old 11-21-2012, 10:06 AM   #7
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
Rex/OP lists everything except a new TPS (reporter). ;)
Been thinking about how to go about getting a "TPS report" and just now
came up with this idea... Strip the three wires (or just two) like a 1/2"
and then twist the wire to form a "teat" then solder the little teats.
The trick is to stagger 'em so they won't-never touch each other.
I made three little jumpers but it's just another step installing those that
just seems unneeded?
Test yours using an analog voltmeter and/or an ohmmeter, look for smooth
voltage or resistance operation. It's a potentiometer... is there such a thing
as a 100% all-the-time -smooth- operating potentiometer? LOL :)
Alvin in AZ
ps- Just checked out Rockauto.com and a Standard Motor Products TPS
is more money than a Motorcraft. ~$50 ...look under "Fuel/Air"
Alvin in AZ is offline   Reply With Quote
Old 11-21-2012, 03:34 PM   #8
Seattle FSB
Seattle FSB's Avatar
Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
Junkyard made TPS Test Harness...
My concern is how the OP is lowering his idle which caused the engine to die in gear. I hope he wasn't turning the factory set throttle stop screw...
See these links:
Throttle Position Sensor Testing, Replacement and Adjustment
How to Test and Clean your IAC
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
Seattle FSB is offline   Reply With Quote
You may not post replies
Forum Jump
