Strange 'no start' issue... - FSB Forums
Thread Tools Display Modes
Old 11-01-2012, 09:06 PM   #1
flint knapper
flint knapper's Avatar
Bronco Info: '90 EB, '70 Half Cab
'90 model Bronco, 302, AOD
Coming home from work a couple of days ago...bronco starting losing power, backfiring, running rough...finally died. After about 10 minutes on roadside I tried to crank it. It started up (ran rough...then cleared up) went about 2 miles then started running poorly again, died.
This continued several more times until I finally made it home. Got a ICM and installed on the distributor, cranked up motor it ran fine for a test drive. Next morning the Bronco would not start (cranks fine).
Figured MAYBE the distributor pick-up was bad (dizzy is old), replaced...no start. Coil is old...so replaced it, no start.
Yes...I know, "throwing parts at it" is ill advised, but these parts were old and I have very little time to do much in depth testing on it. I will pull some codes later on....but what are some 'common' reasons for a no start condition.
Fuel pump is new (this past summer it went out), I can hear it priming up fine...but haven't checked the pressure yet. IAC and EGR are new. TPS hasn't been giving any trouble.
When I pulled spark plug last night and grounded it out...there was spark...but it looked kind of weak. Yellowish, not a good blue spark.
Any ideas where to start from here will be appreciated.
Flint.
flint knapper is offline   Reply With Quote
Old 11-01-2012, 09:17 PM   #2
bulrid8
Bronco Info: 1990 4x4 351w
Fuel filter?
bulrid8 is offline   Reply With Quote
Old 11-01-2012, 09:28 PM   #3
Black'nTan96
Black'nTan96's Avatar
Bronco Info: 1996 Bronco 5.8 mild build, kingpin Dana 60 leaf SAS, Sterling 10.25 rear, 38.5" TSL SX's
Flint, you sound like you are fairly mechanically inclined so forgive me if I suggest things you've already crossed off your list. But think basic, your truck needs fuel, air, and spark. If it has these things with no problems relating to them it should light. Sometimes when Im stumped I just make sure to check these basics before I get tied up with more complicated things. Check spark at the wires. Check fuel pressure. Even double check the firing order since you have been there. And while checking plugs I like to take the time to check the compression while Im there. May not solve your problem but sometimes poking around with the basics can lead you to an underlying problem.
Black'nTan96 is offline   Reply With Quote
Old 11-02-2012, 12:07 AM   #4
flint knapper
Originally Posted by bulrid8 View Post
Fuel filter?
Not entirely out of the question...but it is only a couple of months old and it wouldn't explain why it went from running fine (the night before) to a 'no start' the next morning.
However...if it proves to be 'fuel' issue rather than a 'spark' issue ....I will certainly look at the filter.
Thanks for your reply,
Flint.
Old 11-02-2012, 12:22 AM   #5
flint knapper
Agreed. Just trying to decide which to look at first. I'll pull some codes tomorrow and see if that will help steer me in the right direction. It could be something as simple as a wire going to ground.
I had pulled one wire (and plug) grounded it and cranked the engine (quick way to check for spark) but it looked a bit weak to me. Stalling and sputtering engine (if spark related) is classic Bronco ICM or Distr. Pick-Up, so that is why I changed the ICM (I carry a spare). That actually seemed to cure the problem. Odd that the vehicle would not 'fire' the next morning.
Distributor problems can be intermittent and mine was very old, so no skin off my nose replacing it. Pretty sure...I've got the firing order right and didn't get the distributor put back in 180 out. Even then...it should TRY to fire.
New coil...just to ensure good spark, cheap part.
Check fuel pressure
I'll check that tomorrow. I've got a gauge. New fuel pump this past summer, new injectors (just maintenance at same time). Has new IAC and EGR (all old items...I was slowly replacing). TPS is a few years old...but checks out.
Thanks,
Flint.
Old 11-02-2012, 12:48 AM   #6
Cheesehead
Cheesehead's Avatar
Bronco Info: 1988 XLT 5.0l w/AOD & Rebuilt BW1356
Are the plugs wet with fuel? I had similar symptoms with my truck when I bought it and drove it home. Ended up being a bad ECT. Pull codes. Takes 5 minutes. Then see what if any pop up. G/L
Cheesehead is offline   Reply With Quote
Old 11-02-2012, 12:56 AM   #7
Black'nTan96
...and I assume you've replaced or at least checked the distributor cap and rotor. Check for corrosion or cracks. I replaced mine when I did my ICM
Old 11-02-2012, 01:55 AM   #8
MudBrother
MudBrother's Avatar
Bronco Info: 1996 351W 3 inch lift, holdin off the rust for now!
Is it failing to start again after running (or even after sitting and cooling down)? Mine would stall and re-fire while driving, and then a little while later it would only start after cooling down. Then, after trying fuel filter, distributor ICM, ignition coil, testing all wires, I gave in and took it to my a local mechanic. Turns out the Ignition module (NOT the ICM on the dizzy) has a heat sink that corodes over time, and the heat wont transfer from the Ignition module to the heat sink.
I had it replaced once at the first mech, but then it began again several weeks later. Took it to a recommended mech and he found the rust on the heat sink. He cleaned up the heat sink, and put some heat transfer goop between the sink and the module. The total job (with motorcraft part) cost about $300. WELL WORTH the $$$, considering the parts I didnt throw at it.
Motocraft part number 1x226 (what was on my invoice)
PArt cost 219.36
THe one the first mech put on was chinese and cost about 90.00. AVOID IT. The second guy said the orginal Ford part lasted probably 4 to 5 years even with the overheating/heat sink corrosion. The first replacement Chinese part took a crap in a week...
Hope that helps. Its a very common 302/351W issue by the looks of the threads...
MudBrother is offline   Reply With Quote
Old 11-02-2012, 08:38 AM   #9
flint knapper
Right, new cap and rotor. Also replaced the coil lead distributor (had a spare), plug wires are good, spark plugs recently changed.
Old 11-02-2012, 11:54 PM   #10
flint knapper
Double checked firing order: Good
Fuel pressure (at prime up) 38-40 psi.
Checked all wires and connections for obvious breaks, chaffing, or disconnected fittings/connectors. All looked fine.
Pulled # 6 plug and wire (easy to get to), grounded it and cranked the engine. Got a spark..but still doesn't look exactly right to me. Sort of yellowish/orange, not a good blue spark...but there is 'spark'.
Got some codes: 33, 84, 52 and a separator code. Don't think any of these would prevent the engine from starting?
Had one event when reading the codes (vehicle not responding), but when I ran it a second time it worked (ECM)?
Dunno guys...it has me stumped.
Old 11-03-2012, 01:05 PM   #11
flint knapper
BTT for ideas
Old 11-03-2012, 01:07 PM   #12
MudBrother
MudBrother's Avatar
sounds just like mine. It started after it had cooled down. overheated ICM. HAve you looked into this?
Old 11-03-2012, 02:55 PM   #13
JKossarides
JKossarides's Avatar
How old is the ignition switch......just on the odd chance test it and I don't think old fuel filters will prevent a vehicle from starting unless they've been "fouled" by water or mud from off roading etc. ...though it can't hurt to change them if they haven't been done for a while...
Sounds like the FPR = fuel pressure regulator is ok with those psi numbers, any issues with injectors.....IDK
You said you replaced the distributor and ignition module, was it a TFI = thick film integraded style...did you test the old one, several times for passing grade before replacing...
Does the 90 BKO have a PIP = profile ignition pickup on the distributor shaft.....?
Definately test the EVP sensor that sits on top of the EGR valve and see what you come up with, maybe it needs to be replaced if it's been on there for a while based on the fault codes.
ECT = engine cooling temp sensor is a fuel manager at cold start and normal operation but any issues with it can prevent the engine from starting, rich condition etc. etc.
Is the alternator putting out enough voltage....?
Just a few thoughts!
Good Luck ~
Old 11-03-2012, 03:33 PM   #14
flint knapper
Brand new this summer, actuator broke...but I replaced the switch at the same time.
Fuel filter only several months old, no bad fuel through the tank...that I know of. New fuel pump recently, good fuel pressure, its getting fuel (but perhaps in various amounts).
Injectors are new....less than a year, been trying to slowly get new parts on the old bronco...bit by bit.
Yes TFI (gray) same type I've running for 20 years. No...didn't check, I keep a couple of spares at all times.
Yes, new with new distributor, cap and rotor.
Both parts new...this summer. Also new IAC
Hmmmmmm....could be a problem.
Yes...good 160 amp alternator, good strong battery.
Thanks for your input Sir.
Flint.
Old 11-03-2012, 03:36 PM   #15
flint knapper
Do you mean the ECM?
Old 11-04-2012, 02:14 PM   #16
flint knapper
Any other ideas guys?
Cranks like a banshee...just won't fire up.
Tried advancing and retarding the timing (just for fun), no difference...won't start.
Old 11-04-2012, 07:02 PM   #17
4NIC8R
4NIC8R's Avatar
Bronco Info: 91 Silver Anniversary
If it's getting spark and getting fuel, what about compression?
Might give it a test after testing out the ECT
1991 SA
5.8L, E4OD, BW1356
217,000 miles and rolling
Second... and Fourth Owner!
4NIC8R is offline   Reply With Quote
Old 11-05-2012, 03:01 PM   #18
JKossarides
If not the ECT, what about the coil or distributor, if it cranks but doesn't fire up.....IDK....?
Hope you get it sorted out Brother! ~
Old 11-05-2012, 08:45 PM   #19
flint knapper
Got an ECT for it this evening, will install when I have time. Coil and Distributor (and cap and rotor are new).
Old 11-05-2012, 10:04 PM   #20
flint knapper
New ECT, still no start.
Specifically, what items/conditions could cause this?
I know I'm getting fuel to the fuel rail (40 psi), I assume my injectors are working (they were the night before the engine wouldn't start). I've established that I am getting spark (even though I think it a bit weak).
No obstructions to prevent air from getting to the engine.
Fuel + Air + Spark = Engine start (or at least trying).
You may not post replies
Forum Jump
