#1 |
![]() Join Date: Dec 2003
iTrader: (1) Bronco Info: Tore down, Beat down, just F*CKED.
Going from MAF stroker motor, back to Stock 351w Speed Density.. Questions?
Okay, before this even starts.
I deeply am thankful for any information I can gain from this thread. Much respect. What I don't need in this thread is why am I doing this. I will tell everyone why.. I never should of built a stroker motor for my rig. That's it.. Nothing else. I opened a can of worms. Been 3yrs and now it is back to stock and SD for me. Now, here is the deal. I am getting a 95' roller motor to install in my rig. I have some concerns. I am putting my rig back to speed density, that means repinning the ECM. I had the rig set up for MAF when I installed the stroker motor. With a roller motor and me having 1990 wiring, an MSD Distributor. Do I have to get a new gear for my Dizzy? Or, can I not use this dizzy now? I am researching that as well, this is just a great place for information, so I am including it. I just was hoping for some information to make this install the least painful it can be. I know it's not going to be a walk in the park. I just haven't dealt with a roller motor before. How different is it from a non roller? Thanks for any information.
88'/90'/91 XLT Bronco,351W w/JBA Headers,35X12.5 BFG KM2 M/T's, 3inch body lift and 4 inch Rough Country Lift,D44 Locker , L/S 8.8, 4:56 gears E4OD, |
| Sponsored Links | |||
Advertisement | |||
#2 |
iTrader: (0) Bronco Info: 87 5.0 long travel king shocks deaver springs
Hi without asking you why. Is it a big mistake to put a stroker in thats been built by a shop. I am currently looking at buying one using stock to mild cam. OR was it in the building process I dont want to be on that boat. Did it have more power?
#3 | |
From what I have gathered, it depend on how big you wanna go. There are many threads on this in here. Just search "stroker" and they will pop up. I was going to need injectors possibly, someone who can tune using a Moates QH and a wide band emulator. I don't have the cash for all that. my problem was not enough research was put in by me prior to going with a stroker motor. Had I known all of what is entailed. Hell no, I wouldn't of done it.
#5 |
Cool, thanks
I am using the entire roller motor, so, I "hope" when I get the metal gear, I will be golden. I was checking out Summit. Man, sure some pricey gears there. Would this one work? Or, Do I wait until I have the cash for a more expensive one? http://www.summitracing.com/parts/ma...rd?prefilter=1
#6 |
iTrader: (0) Bronco Info: 1988 XLT 5.0L AOD 200K
It looks like that is the right gear for the 5.8 L , but I don't trust the Summit catalog. It says that this gear will also fit the 5.0 but I know it will not fit my 5.0 distrib. I have the 0.47" diameter shaft
:Have you thought about going carb? Seems like most 351W stroker motors go to a carb for simplicity and cost. MAF tunes, bigger injectors, big bore TB, and high performance F.I. 351 intakes are pretty pricey. You can get a 351W high performance non F.I. aluminum manifold, a non F.I. distrib., and a 750 holley carb for like $300 on craigslist.
Manual Hubs, Six-Litre Tune, 3-G swap, 31" tires, 2" lift, factory dual front shocks, Hedman SS 89470 Shorties, 2-1/2" Y-pipe into 3" SS Magnaflo Cat, 3" SS Vibrant Muffler, 3" SS tail pipe, 3.55 gears, rear posi, AOD w/ B&M shift kit, Saginaw PS swap, Lincoln 18" electric Fan. Faded factory red paint with ZZ Top factory stripes and aftermarket rust on tailgate. Just turned 200k miles
#7 |
![]() Join Date: May 2007
iTrader: (4) Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
B-man, are you saying you have an MSD 8453 with Distributor Mounted EEC-IV TFI ICM and an Iron Distributor Gear? And you now need a Roller Distributor Gear? If so, I have a gear that I can send you. Send me PM.
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
#9 | |
Tuning issues would be why, I have a 95 5.0 ECM but I will have a stock 351w going in. Wasn't sure if that would be an issue. Seems it has all been an issue since the change to stroker motor, E40D and MAF setup. I figured since I had the 5.0 ECM with the 5.8 motor, the fuel tables would be off along with the AFR.. So, I thought I would go back to SD. Which, by no means was a dog for me before. Gave me enough grunt and go.
#10 |
![]() Join Date: Oct 2010
iTrader: (8) Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
Your 5.8 will run on the 5.0 computer just fine. Granted it wont be the best tables but it will run again just fine. Im running the 5.0 comp on my 5.8maf with no issues, only because i havent found a 5.8 maf manual comp yet. Just plop the new engine in swap that gear then plug and play.
![]() Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825 |
#12 |
That was my plan. Course, I just rewired my existing wiring. Added wires to it. I didn't have the harness.
#13 |
iTrader: (0) Bronco Info: 1990 5.8 e4OD, 2wd, 5in" lift, 33's
not that you are going to, but I just did a 5.8 with 5.0 maf pcm conversion and it is working well.
So it is possible without any messing around. otherwise I like the sell what you have and get an SD harness for your conversion back idea |
#14 |
Without correcting for the cubic inch increase the load scaling will be off. This effects spark and fuel tables.
#15 |
![]() Join Date: Dec 2005
iTrader: (7) Bronco Info: 1993 F150 Flare Side
In that case, why not keep it MAF but get a 351W E4OD EEC. MAF is better and you won't have to rewire it. Plus you could likely get something out of the 302 EEC. If you stay MAF, if the bug strikes again, you could add heads and intake without tuning.
#16 |
No bug will be coming here.
SD is fine with me. I have other things and hobbies I want to get into...
#17 |
I have a question.. Is there a different firing order between a roller motor and the usual flat tappet hydraulic motor?
#18 | |
The difference comes in on the 302 with the "HO" roller camshaft starting in the Mustang in 1982. The roller truck 302s have the "new" 351 firing order. I know this was more info than you asked for, but hope it helps anyway. tim |
#19 | |
![]() I have learned that. Thanks for the info!
#20 |
UPDATE.
Okay.
For some reason in my area, I can't find any machine shop that will install the new gear I have on my MSD Dizzy.. It's getting really frustrating.. ![]() I wanna do this the right way and not attempt this myself. Course, what I am asking now is probably not the brightest idea either.. Is there a way to use the 95 dizzy on my rig? All my shit is back to 1991, so, wiring is different. I was just wondering if I could possibly rewire it to work? Or,, could I take my MSD guts out and put into the 95 dizzy.?? I am assuming no on both. Looks like I could possibly be looking for another dizzy. Any help is greatly appreciated. I am close to getting this sucker back together. Yay for me.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
