Heater/ac stopped working!!!! - FSB Forums
Thread Tools Display Modes
Old 11-08-2012, 07:42 AM   #1
BigJohn89
BigJohn89's Avatar
Bronco Info: 1989 XLT 5.8 with C6. 6" Rough Country Lift, Saginaw PS Pump, regeared to 4.10's
Just came out the other morning and its not blowing on heat or ac. Some air still comes through bc my window will defrost after 15 minutes or so. The backlight is still on and radio works fine but will not change and actually kick on the blower. I have not messed with anything and it just stopped working. Is there a fuse that could be bad? All help appreciated because my rear window is stuck down and taking the boys to durhamtown saturday. Thanks in advance
Sent from my DROIDX using AutoGuide.Com Free App
BigJohn89 is online now   Reply With Quote
Old 11-08-2012, 11:07 PM   #2
BigJohn89
BigJohn89's Avatar
Anyone have an idea where to start?
Old 11-09-2012, 12:47 AM   #3
Steve83
Steve83's Avatar
Of course.
Fuse block.
Old 11-09-2012, 12:48 AM   #4
TheUnforgiven
Salt blows goats for fun
TheUnforgiven's Avatar
Bronco Info: 2006 Kia Spectra
do you have power at the blower motor on the passenger side of the dash? yes? continue onto...
hit the motor with a hammer, does it turn over? yes? replace it. no? replace it anyway if you have power there.
the air is moving from you driving the vehicle or the head radiating from the core. if the fan isn't moving it's not the one moving air. start there.
2006 Kia Spectra 4 banger/5 speed.
I like to eat poop.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 11-09-2012, 07:32 AM   #5
BigJohn89
BigJohn89's Avatar
Originally Posted by Steve83 View Post
Of course.Fuse block.
None blown. Looks like my fb may have had a problem before
No air flow at all. Ill check the blower motor.
Old 11-09-2012, 08:37 AM   #6
miesk5
I used to know this stuff
miesk5's Avatar
yo BigJohn89 ,
I don't have the 89 Fuse Block Diagram but in 88, Fuse #9 is dedicated to Heater/AC - 30 amps
pic by jem270
pic in a 90
Source: by ElKabong (Ken, El Kabong)
Wiring Diagram in a 90
Source: by Seattle FSB (SeattleFSB) http://www.supermotors.net/registry/media/943188
Any air flow from Defroster Vents?
if so,
The system is designed to provide defrost when no vacuum is applied to any of the three air door vacuum motors. This is done to prevent a situation where defrost cannot be obtained due to a system vacuum leak. Instead, a leak in the vacuum control circuit will send all airflow to the defroster outlets. This condition may occur during acceleration (slow leak), may exist at all times (large leak) and may happen only when certain specific functions are selected, indicating a leak in that portion of the circuit.
Most common leak is in original white vacuum line to Outside Recirculate Door Vacuum Motor
pic in an 89 by Mavman
passenger side, near firewall and hood hinge; white vacuum line
USN (Ret) & MIL/DoD Contingency Planner (ret)
THANKS to ALL WHO SERVE!
my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php
Old 11-09-2012, 11:39 AM   #7
Steve83
Steve83's Avatar
In what way? It's common for the blower fuse to burn its terminals withOUT burning the fuse.
Old 11-09-2012, 11:56 AM   #8
TheUnforgiven
and to also burn the resistor and/or the connector for the blower motor.
I like to eat poop.
Old 11-09-2012, 12:48 PM   #9
BigJohn89
BigJohn89's Avatar
Here is a pic. You can see where it burnt and the fuse was still in. All 30a fuses are still good that are in the fb.
Old 11-09-2012, 12:51 PM   #10
BigJohn89
BigJohn89's Avatar
Is this the motor you speak of? If so i hit it with a socket ext and nothing
Old 11-10-2012, 12:09 AM   #11
Steve83
Steve83's Avatar
Here is a pic.
Yep - that's it. But that's not "a problem before" - that's your CURRENT problem. Click this, read the captions, and either replace the fuse block (the white plastic part), or move that fuse to another location:
No, that's a vacuum motor for one of the diverter doors. He's talking about the BLOWER motor, under the L hood hinge.
But since you know the fuse terminal is burned, there's no point in worrying about the motor right now. I'm sure after you get the fuse fixed, the motor will work fine.
Old 11-10-2012, 10:09 AM   #12
TheUnforgiven
you mean under the passenger hood hinge. not left. not right...
I like to eat poop.
Old 11-18-2012, 05:32 PM   #13
BigJohn89
BigJohn89's Avatar
Stupid question steve. Can you tell from the pic that the burnt spot is the correct fuse that controls the heater? Reason i ask is that this was the first time i have opened the fuse panel to see the block. Reason i ask is that i did not know if it was possible something else has been burnt out this whole time i have had the truck.
Old 11-18-2012, 08:22 PM   #14
Steve83
Steve83's Avatar
...and you didn't look at the fuse block map on the knee bolster or in the owner's manual?
Old 11-18-2012, 08:32 PM   #15
BigJohn89
BigJohn89's Avatar
My manual got torn up offroad by a cooler spill. And also no fuse map as that was the first place i looked. Then i looked online for a fuse diagram. It is indeed the correct fuse. It probably burned bc it was a 20a and it calla for a 30a. Changing the box should be easy enough right? How can i "move" the fuse location?
Old 11-18-2012, 08:44 PM   #16
BigJohn89
BigJohn89's Avatar
Sry. Dbl post
Old 11-18-2012, 09:37 PM   #17
Steve83
Steve83's Avatar
No, that would have blown the fuse - not burned the terminal in the fuse block.
Let us know after you've done it.
Click that thumbnail and read the captions.
Old 11-19-2012, 07:34 AM   #18
miesk5
miesk5's Avatar
yo John,
That is Fuse 9 as shown in the Red fuse block diagram/legend pic by jem270 that I posted above
click on above to enlarge
Old 11-19-2012, 04:48 PM   #19
BigJohn89
BigJohn89's Avatar
No, that would have blown the fuse - not burned the terminal in the fuse block.Let us know after you've done it. Click that thumbnail and read the captions.
i looked through and could not find about relocating the fuse. i saw where you put my picture in there also. I am def just goint to relocate the fuse as i had no idea what the back of the box looked like. More than I want to tackle. I only looked through the pics of my style fuse box. Again I appreciate your help steve
You may not post replies
Forum Jump
