#1 |
Comp Cams 31-255-5
Hello,
I own a SD 1990 F150 with the 5.0L engine. I'm hoping I can reach out and get some help from the Bronco family regarding my camshaft selection. I recently rebuilt my engine and I am pretty much convinced that my camshaft selection was very much the wrong selection. It looked good on paper, but in practice, it's a different story. The camshaft I'm currently using is 35-512-8 by Comp Cams. My engine is doing everything but running properly. It's surging, bucking, running pig rich and shutting off. It was running fine prior to the rebuild with the stock flat tappet camshaft. I am seriously considering going with a 92-93 F150/Bronco stock roller camshaft due to the specs being pretty much the same as the flat tappet camshaft that was originally in my truck. So, with me recognizing my camshaft selection was not the best of choices, I truly do not want to go back to the stock camshaft seeing everything I've done to the engine. I am not looking for the baddest truck alive, I'm pretty much just wanting a torquey, reliable build that I can hook up and tow with from time to time. At this point, I need a roller camshaft that will play nice with my SD because I don't want to upgrade to MAF. What I am considering is getting Comp Cams to custom grind a roller version of the 31-255-5 camshaft. In your opinion, would this be a wise thing to do? If I'm not providing sufficient information, please let me know. My mods are in my signature. And I want to add that I am using the 1-3 firing order with the 35-512-8 camshaft, but I'm very much open to going back to the old 1-5 firing order.
1990 F150 - 5.0L Stock GT40 Heads | .030 Over (Speed Pro H120CP30 Pistons) | T-Moss Ported Lower Truck Intake | Comp Cams XE258HR-14 Last edited by qdeezie; 11-09-2012 at 05:19 PM. Reason: Firing order comment |
| Sponsored Links | |||
Advertisement | |||
#2 |
![]() Join Date: Dec 2007
iTrader: (41) Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
Why not go with the stock HO roller cam? It's a favorite around here.
~ Scott ~ ~My Exhaust clip on YouTube ~ 204k on the odometer and no longer a daily driver. ~ ~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
#4 | |
Mustang.
Here's a quote from the "how to pick a camshaft for EFI" thread Quote:
#5 |
Ok, I will try to look one up. I think I saw one from an 86 Mustang for sale somewhere. Your help is greatly appreciated!!!
1990 F150 - 5.0L Stock GT40 Heads | .030 Over (Speed Pro H120CP30 Pistons) | T-Moss Ported Lower Truck Intake | Comp Cams XE258HR-14 |
#6 |
I just looked again and saw that it says 89 to 95 Mustang. I'll look around a bit more.
#7 | ||
With that said, I run a 5.0 HO roller cam in my GT40X headed 5.8. The cam provides excellent power from 1400ish rpms up, but is a little soft from off idle to the 1400ish. In other words, I don't agree with the thread linked above. Sadly I based my cam selection on this, the $ of a proper mass air conversion, and the fact I could get this cam cheaply off the Corral.net. I am pleased overall with its selection but do think better options are out there. I am not one of those guys that never see over 3000rpms in my vehicle. I am sure those guys would hate the HO cam choice. hth tim |
#8 |
I privately wonder is there a company that can figure out or has figured out the SD truck camshaft riddle and produce a decent SD custom ground camshaft that would work well for a truck.
After I sell the 35-512-8 camshaft, I'm going to call around and see if there are any SD roller cams with the 1-5-4 firing order or someone that can custom grind one and stand behind their work if my factory computer decides to disagree. In the meantime, I decided to go with the 92-93 roller camshaft for the sole reason of it being the safest bet to get my truck back on the road. Currently, I am in the process of tearing my truck engine down currently and hope to have the camshaft installed over the next few days.
#9 |
I figured I'd come back to give the latest news for the sake of formality. The camshaft was not the issue. I got a bit stubborn and it paid off because I did not want to pull that camshaft out.
I had everything on the engine professionally cleaned with the exception of the upper intake and that was where the problem was. I "cleaned" it previously but I needed to take the cleaning part to the next level. 1) The vacuum tree on the upper intake was stopped up, so I took that off and let it soak in parts cleaner. 2) I sprayed the upper down with purple stuff (full strength) and took it to a heated car wash and sprayed the #$%^ out of it. All kinds of chunks of carbon/sludge came out. Now I actually see bare metal on the inside of it. 3) I ran a dedicated vacuum line to the MAP sensor. I accomplished this by routing the PCV fitting in the rear of the upper intake to the MAP sensor and I tapped a hole in the side of the upper per the Ford TSB and ran the PCV to that and capped off the now unused ports on the vacuum tree. I used two brass fittings from Home Depot to adapt the 3/8 PCV fitting in the rear of the intake to the 1/4 fitting on the MAP sensor. I also used 1/4" and 3/8" radiator hose to ensure that I won't have to deal with hoses collapsing. The result: A smooth running engine and all kinds of low end torque. It's definitely fun to drive. I am currently using Stock GT40 heads, but I can't help but imagine how strong the engine would be with aftermarket heads, so I'll be swapping out the heads sometime down the line.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
