Transfer case - bronco vs F-150 - FSB Forums
Thread Tools Display Modes
Old 11-09-2012, 08:52 PM   #1
madramper
I bought a 95 bronco to use as a parts truck for my 93 F-150. I went and picked up an F-150 4x4 driveshaft today and noticed a problem. The bronco transfer case has the same 4 bolt flange as the rear diff, but the f-150 shaft is for a slip yolk. What do I need to do to change the transfer case? Can it be changed? Would I be better off just getting an F-150 transfer case?
1994 Cobra - 351w / T56 / PT76HPSH turbo ~700hp
2004 Cadillac CTS-V - 475rwhp
Working on building a winter "beater"
madramper is offline   Reply With Quote
Old 11-09-2012, 09:21 PM   #2
CWbronco
CWbronco's Avatar
Bronco Info: 95 xlt, 302, 37's, 4.56's, D44 SAS, 10.25 FF
Yes it can. Tailshafts on the BW1356 case swap over very easily. I swapped it on mine, I believe jermil did his also with a writeup, and shadofax has a good writeup on opening and refreshing a case.
Sent from my iPhone using Autoguide.com App
Build
SAS
FOTM Oct. 2012
CWbronco is online now   Reply With Quote
Old 11-09-2012, 09:44 PM   #3
madramper
Cool. Thanks! I had a rough day of wrenching only to end it by finding out my driveshaft wasn't going to work! I'm glad to hear there is a way!
Old 11-09-2012, 09:49 PM   #4
BRONCONUT
Local # 40 Boilermakers
BRONCONUT's Avatar
Bronco Info: 5.8 w/ MSD, optima, K&N, OBA, 8 lugs, Detroit w/ 4.88's, 4 wheel disc brakes & Kick ass camo,
An f150 shaft and t-case wouldnt work so great on a bronco. The bronco needs a double cardan shaft for the short wheel base, the slip shaft would be binding under there and eventualy fail. You can do like said though and mate the two if that is what you need, it is pretty simple.
BRONCONUT is online now   Reply With Quote
Old 11-09-2012, 10:30 PM   #5
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
he bought the bronco for the parts to put on the F150.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 11-10-2012, 02:07 PM   #6
madramper
Yes, I have a 2wd F-150 that I am converting to 4x4.
Old 11-11-2012, 09:43 PM   #7
4NIC8R
4NIC8R's Avatar
Bronco Info: 91 Silver Anniversary
It's more than just the tail housing. You'll need to tear it open (which I highly recommend due to the oil pump stay-arm issues they have) and swap in a different shaft that is for an F-150.
1991 SA
5.8L, E4OD, BW1356
217,000 miles and rolling
Second... and Fourth Owner!
4NIC8R is offline   Reply With Quote
Old 11-11-2012, 10:53 PM   #8
Steve83
Steve83's Avatar
When SMN comes back up, click my black Bronco in my signature, scroll down the album list to Diagrams, then go about 1/3 down that page and look for the exploded manual-shift BW1356.
Old 11-12-2012, 10:46 AM   #9
AbandonedBronco
Big Six
AbandonedBronco's Avatar
Bronco Info: 1981 300ci 6cyl w/4bbl conversion. 4spd manual
I'm not sure how different the two are, but I just did this on my Bronco with an NP208. Got a transfer case from an F-150. It wasn't too difficult.
Took the bolts holding the covers for the tailshaft off.
After I took the bolts holding the two halves of the casing out, the cover came right off. Had to pry just a little bit because of the silicone.
Once the case was open, this C clip is the ONLY thing holding everything in.
Once that was removed...
The gear and tailshaft came right out. The chain is off in this picture, but you lift both gears at the same time with the chain on them.
When swapping the other tailshaft in, just be sure all the internals are lined up. There are a few things that can shift around.
Just reverse to install. Clean up the silicone, put a fresh new layer on, and bolt it back together.
I'm sure it's rather similar for the BW.
1981 & 1984. Both w/ 300 I6. Holley 600 4bbls. 31x10.5" tires. NP-435 trans. 2.5" Exhaust.
Supermotors Pics
AbandonedBronco is offline   Reply With Quote
Old 11-12-2012, 06:21 PM   #10
m-unit
Bronco Info: 1990 5.8 e4OD, 2wd, 5in" lift, 33's
I have a rear shaft you can have. I don't know where you are, but I'm doing the opposite conversion and have the flanged bronco driveshaft sitting around.
I'm in Socal. Maybe you will be too.
m-unit is offline   Reply With Quote
You may not post replies
Forum Jump
