302 water pump HELP - FSB Forums
Thread Tools Display Modes
Old 11-09-2012, 10:38 PM   #1
OldsRocket
OldsRocket's Avatar
Bronco Info: 1984 Bronco XLT 302 c6 np208, 1979 Bronco Ranger XLT 460 c6 np205
302 water pump HELP
Replacing the engine in my '86. The engine cast numbers say its a '79 LTD engine. I bought a water pump for it.....wrong pump. The LTD pump was cast iron and the one I'm replacing it aluminum.
The cast number is e9te-8505-aa
I've checked the web and I've seen everything from Ford Truck 351w to "yep, thats a water pump."
What is this pump from? I'd like a definite answer so i can get the correct pump tomorrow.
In case you're wondering, the engine was in an '81 Mustang before i bought it. Not the original engine. The brackets and pulleys I'm using are from an '89 Crown Vic wagon. The new engine is from a '94 Bronco. As you can see, its a mismatched mess, but all I need it the correct water pump and I'm back on the road in my Mustang.
OldsRocket is offline   Reply With Quote
Old 11-10-2012, 08:26 AM   #2
sackman9975
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
You're going to want to make sure you have the corrcet timing cover for what your doing before you make sure the water pump is correct. There are different water flow for the rotation of the water pump(s).
~ Scott ~
~My Exhaust clip on YouTube ~ 205k on the odometer and no longer a daily driver. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
sackman9975 is online now   Reply With Quote
Old 11-10-2012, 12:42 PM   #3
OldsRocket
OldsRocket's Avatar
I've already swapped my timing cover and accessories to the new engine from the old. Just need to know what this pump is. I think i got it....'89 ford truck is what i've been able to find.
Old 11-10-2012, 01:24 PM   #4
JKossarides
JKossarides's Avatar
Bronco Info: 1986 Bronco XLT 4x4 -AOD -Warn Hubs, NEW stock 302EFI, MSD cap, rotor, 48kv coil, 9mm FMSR wires
For additional info try here and see what you can find:
www.broncolinks.com
FSB member El Kabong's ~ baba loohey's favorite FSB links and questions...
Good Luck ~
Old 11-10-2012, 01:41 PM   #5
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
Cool, so which timing cover you got on it now?
Can you see the image in Sack's post?
Are you running a serpentine belt or V belts?
Butthead in AZ
Alvin in AZ is offline   Reply With Quote
Old 11-10-2012, 07:14 PM   #6
OldsRocket
OldsRocket's Avatar
Butthead in AZ
Got the waterpump solved. I was looking at the wrong pump. Had a duh moment.
To answer your specific question though......my brackets/pulleys are off a '89 Crown Vic Wagon. They use a 6 groove "serpentine" belt set in a forward rotation unlike your typical serpentine setup.
Old 11-10-2012, 07:36 PM   #7
Alvin in AZ
AKA: Butthead
So OldRocket ;) your timing cover is like the one in the lower right hand
corner of Sack's picture?
Right? :) (it's the one with both water ports pointing in odd directions)
Gotta get this right or the flow will be wrong, this is important yet simple.
Butthead in AZ, retired RR signal wireman, -yes- it is possible to do your
job 100% right every damned time danggit!
Old 11-11-2012, 01:26 AM   #8
OldsRocket
OldsRocket's Avatar
So OldRocket your timing cover is like the one in the lower right hand
No. The old engine, timing cover, etc are from a '79 something or other. I'm using the old timing cover with the fuel pump mount. After a brief dumb@$$ moment on my part, I got the pump figured out. I was looking at the wrong pump when i got the cast number. I looked at the pump that was on the '94 Bronco engine when i should have been looking at my old pump. Got the 2 mixed up sometime during the transfer of parts.
I did, however, make this mistake of mounting a reverse pump ('94 Bronco) on my forward timing cover. Learned my mistake real quick.
Although now I have a totally new problem. I'll post it up in a minute and link it from here.
Heres the new problem. Maybe more timing?
http://www.fullsizebronco.com/forum/...18#post2981818
You may not post replies
Forum Jump
