flickering headlights/dash...?? - FSB Forums
Thread Tools Display Modes
Old 11-10-2012, 12:20 PM   #1
bruzrs78
Bronco Info: mostly stock (for now) 78 fullsize. has a 3"bl. w/35s. 351m 4bbl. edlebrock intake
working on my first f.s. 78. i have put a new alt. in and now i have a headlight flckering issue. dash and domelight as well. i have checked grounds and have had the alt. bench checked and was fine. again this is my first older ford i have worked on, so any advise would b awesome.... thanx!
bruzrs78 is offline   Reply With Quote
Old 11-10-2012, 07:08 PM   #2
88Bronco300
She likes my
88Bronco300's Avatar
Bronco Info: '88 XLT with 4.9. 10" of lift on 40's. Saving for sas!
This happened on my '88. Turns out the headlight switch was bad. May not be your issue but something to check out.
88Bronco300 is offline   Reply With Quote
Old 11-10-2012, 08:13 PM   #3
rhauf
rhauf's Avatar
Bronco Info: 82 bronco 408w 4" lift 35's, 88 bronco 351w all stock on 31s
flickering as in, slightly brighter and dimmer? (this would suggest a jumpy voltage regulator. use a volt meter to see if voltage is inconsistent at battery while engine is running)
or, flickering as in, turning off momentarily now and then/flickering off. this would likely be the headlight switch, headlight switch plug, fusable links, or some other connection. turn them on for a bit and feel for a hot connection. heat = resistance (which means problem found)
-Ryan
Check out my youtube page. Many bronco videos.
http://www.youtube.com/user/rhauf1
rhauf is offline   Reply With Quote
Old 11-11-2012, 10:10 PM   #4
bruzrs78
yes i have tried a test on the battery and voltage does jump around or (not consistant) while engine is idling. i noticed at nite in driveway the brake lights flicker also. so i will try my luck with a new voltage regulator. i had already tried eveything that was suggested in that trouble shooting link in this thread. thats y i went alittle further on my own last nite. thanx for your help... it is greatly appreciated.
Old 11-12-2012, 12:43 AM   #5
kentucky4x4
kentucky4x4's Avatar
my 88 done the same thing. ended up being the headlight switch like said above.
kentucky4x4 is offline   Reply With Quote
Old 11-12-2012, 11:45 AM   #6
Mstroker
Bronco Info: 1989 F150
My buddy has an F350 with a 460 in it that keeps murding his head light switches, my money is that yours is bad too.
If it turns out that it's not the switch I would start checking grounds
1989 F150, 302, auto, 4x4, 9in rear swap 3.73 ratios
Maxxis big horn 33's on american racing wheels
Decked out with Cb's an police scanner bone stock other wise
Soon to be 302 with, forged internals for about 300 hp, and a 125/150 shot of the spray!!
Mstroker is offline   Reply With Quote
Old 11-12-2012, 12:35 PM   #7
AbandonedBronco
Big Six
AbandonedBronco's Avatar
Bronco Info: 1981 300ci 6cyl w/4bbl conversion. 4spd manual
I've had this happen twice.
First time was the headlight switch.
Second time was the high beam switch on the floor.
1981 & 1984. Both w/ 300 I6. Holley 600 4bbls. 31x10.5" tires. NP-435 trans. 2.5" Exhaust.
Supermotors Pics
AbandonedBronco is offline   Reply With Quote
Old 11-12-2012, 08:55 PM   #8
bruzrs78
well, now i have a backup voltage regulator. cuz that was not it... yeah i am going to replace the headlight switch and the floor dimmer.. i have gone through the grounds. pulled apart and cleaned off and all that good stuff. im hoping this not going to be one of those electrical freak shows....
Old 11-12-2012, 09:19 PM   #9
JScatt
JScatt's Avatar
Bronco Info: 1995 XLT 351W, 2.5 R/C Lift,4.10's..much more to come
When you say flicker I'm assuming you mean split second lights are on/off. Does it get worse/better when you hit bumps?
No bum that can't speak poifect English oughta stay in this country...oughta be de-exported the hell outta here!"
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
A wild or half-tamed horse, esp. of the western US.
JScatt is offline   Reply With Quote
Old 11-12-2012, 09:25 PM   #10
GetBent4x4
Bronco Info: Brick Nose on 15x10s/32s with leveling coils
Melted power wire plastic holder on headlight switch harness.
GetBent4x4 is offline   Reply With Quote
Old 11-12-2012, 09:57 PM   #11
bruzrs78
no it does not get worse running over bumps. it is consistant in high and low beam. and or when dome light is on. also noticed the other night just appling the brakes, and the brakelights do the same. that is brake lights alone.
Old 11-23-2012, 05:04 PM   #12
bruzrs78
well, well,well... lol! imagine that found and fixed the issue... come to find out there was a bad connection with the wiring harness to the voltage regulator. went out and got a pigtail 4plug harness,spliced the wires and solder together.... and no more "flickering"... man, what a pain it was. and comes down to something so damn simple... thanx for all of your input. it was appreciated!!!!!!
Old 11-24-2012, 12:40 PM   #13
AbandonedBronco
Big Six
Glad you found it! And thanks for posting up what the issue was. :)
Easy fixes are the best.
Supermotors Pics
You may not post replies
Forum Jump
