#1 |
What is this piece called?
can anyone help me identify the name or part number for the piece in the attached photo?
It is a clip that holds the cable for the blend door. A mechanic snapped mine off when doing some work so now the cable to my blend door slips off every time I open or close it...there are no identifying marks on it. I have tried google searches for blend door retainer clip, etc. but nothing... any help is greatly appreciated! Thanks!
| Sponsored Links | |||
Advertisement | |||
#4 | |
Unfortunately when I found this problem the mechanic had zip tied it, which didn't provide a long term fix :) |
#5 |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
http://fullsizebronco.com/forum/showthread.php?t=210069
You can't buy it new. Go to the junkyard. There are plenty of good ones near Houston. At worst, you'd have to go to the highway between Silsbee & Kountz to visit Armor J. |
#6 |
You will end up having to buy an entire new box for it, or go to the junk yard and rob one
1989 F150, 302, auto, 4x4, 9in rear swap 3.73 ratios Maxxis big horn 33's on american racing wheels Decked out with Cb's an police scanner bone stock other wise Soon to be 302 with, forged internals for about 300 hp, and a 125/150 shot of the spray!!
#7 |
![]() Join Date: Jul 2011
iTrader: (0) Bronco Info: 1989 XLT, 351W, C6 and 1994 XLT, 351W with E4OD
Yep had the same thing happen to mine, only I was the mechanic. They get brittle and snap off after awhile. I went to the junk yard and replaced the whole box, cable and all. I wouldn't even bother looking for a new one. Tie Wraps won't work for long. I tried that first.
Glayd |
#8 |
![]() Join Date: Apr 2005
iTrader: (1) Bronco Info: 1986 Bronco XLT 4x4 -AOD -Warn Hubs, NEW stock 302EFI, MSD cap, rotor, 48kv coil, 9mm FMSR wires
If the "mechanic" broke it then he should replace it or offer you the money to replace it, listen to Steve83...
Good Luck ~
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
