Info on the Heat/AC recyle mod - FSB Forums
Thread Tools Display Modes
Old 11-12-2012, 11:36 AM   #1
KTO17
KTO17's Avatar
Bronco Info: 1995 C-350 9 passenger bus, 7.5L, Auto, 225K miles, 8000# Winch, 285x75x16
I have searched and can't find the thread, but I'm sure I saw one on here about a mod to the climate controls to have a recycle option in any mode of heat or AC.
By the looks of the vacuum line diagram for my 95 it looks like it would be easy, but I want to get some feedback from those that have done this mod.
Doug
1995 Centurion C-350 4-Door Bronco
1965 Buick Rivera-401 Nailhead V8-Sunday Driver
1961 Shasta Deluxe 19' Camper
KTO17 is offline   Reply With Quote
Old 11-12-2012, 12:59 PM   #2
Steve83
Steve83's Avatar
To have an option, you'd have to add a control switch/valve. The only way I know to do that is to swap to the '87-early '88 control panel, which has an independent recirculate valve. I used one in my truck for many years, but I haven't decided whether to use it in the new build.
AFAIK, no one has done anything like that to a '92-96.
Old 11-12-2012, 01:16 PM   #3
forbye
forbye's Avatar
Bronco Info: 1990 XLT 5.0, K&N Hot Air Intake, Motorsport Headers, 3" Dynomax Exhaust
Here's one for an 87-91. Looks like your only issue might be finding a location for the extra switch.
http://fullsizebronco.com/forum/showthread.php?t=165079
"I can't say that a '90 is going to change your mind about Fords... That era of truck isn't known for exceptional reliability or simplicity of maintenance-Steve83"...Now he tells me!
forbye is offline   Reply With Quote
Old 11-12-2012, 01:36 PM   #4
KTO17
KTO17's Avatar
Steve, I really thought you had the info on this and searched your stuff and googled before posting.
I saw a picture of something similar to the link from forbye, but on a 92-96. They installed a small control. I think at the bottom right of the control panel.
I was just thinking of running a line from the black hose to white and putting a manual valve between them, but I like the idea of the switch and the powered valve.
After an exhaust leak from the passenger manifold I want this option. The exhaust would get sucked right in the cab with the heat on at stop lights, not to mention fumes from other vehicles. My exhaust is no longer a problem but others still are.
Doug
Old 11-12-2012, 01:37 PM   #5
KTO17
KTO17's Avatar
Thank you. Thats the idea, just for a 92-96.
Doug
Old 11-12-2012, 02:28 PM   #6
Steve83
Steve83's Avatar
Modern car exhaust is probably cleaner than the air in the truck. There's a seal between the firewall & hood to prevent underhood air from entering the fresh air duct, so your own exhaust leak shouldn't be an issue. And even on recirc, there's still outside airflow - you're not inside sealed chamber.
You may not post replies
Forum Jump
