over heating issue - FSB Forums
Thread Tools Display Modes
Old 11-12-2012, 01:10 PM   #1
90Bronco79
90Bronco79's Avatar
Bronco Info: 1996 XLT 5.8L MSD distributer 33" BFG M/T Brand new E4OD E4OD Bosch Wires E3 plugs Rear Aussie
over heating issue
Ok first I have replaced the water pump, stat, and heater core. I topped off the heater core when installed / reinstalled, stat opens and closes as the upper hose get warm to hot then back. I am in the process of burping the system after replacing the stat but every time i turn off motor fluid gushes out of the rad like a geyser. I don't know what else to do at this point. Any suggestions would be nice. Yes I have searched
Rides
1996 Ford Bronco 5.8
2008 HH-60M Black Hawk
90Bronco79 is offline   Reply With Quote
Old 11-12-2012, 01:12 PM   #2
Steve83
Steve83's Avatar
Coolant leaking out is NOT "overheating". A cap is like $6. Read this:
http://www.fourdoorbronco.com/board/...ead.php?t=5230
Old 11-12-2012, 01:17 PM   #3
90Bronco79
90Bronco79's Avatar
with the cap on the temp rises to just before the line for normal with the cap off while burping just after shutting down to let it cool it gushes out there is no leakage other wise.
Yes the cap is the next on the list to replace when my wife gets back from the gym.
Rides
Old 11-12-2012, 01:32 PM   #4
JKossarides
JKossarides's Avatar
Bronco Info: 1986 Bronco XLT 4x4 -AOD -Warn Hubs, NEW stock 302EFI, MSD cap, rotor, 48kv coil, 9mm FMSR wires
Go to Napa and buy a "Stat" thermostat for around $6.00 they're good quality, I just replaced mine, if you're having issues how old is the fan clutch......?
Good Luck ~
Old 11-12-2012, 01:34 PM   #5
90Bronco79
90Bronco79's Avatar
The stat is brand new and the fan clutch is most likely stock how would i know if the clutch is bad?
Rides
Old 11-12-2012, 02:05 PM   #6
TheUnforgiven
Salt blows goats for fun
TheUnforgiven's Avatar
Bronco Info: 2006 Kia Spectra
that's normal behavior on some vehicles. Some don't do that, some do. what i always did after the stat opened a few times was raise the engine speed with one hand (this will suck the coolant level down), top off the radiator, cap the radiator, and THEN shut the engine down, letting it cool with the system sealed.
then check and top-off once fully cooled down.
2006 Kia Spectra 4 banger/5 speed.
Saltlife enjoys the cawk.
Originally Posted by paintballdude902 View Post
I'm going to shoot you and rape your girl
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 11-12-2012, 02:10 PM   #7
90Bronco79
90Bronco79's Avatar
I really hate working with the cooling system give me a mechanical issue any day. I am still getting bubbles out so how many times should could it take to purge all the air out of the system.
Rides
Old 11-12-2012, 02:13 PM   #8
TheUnforgiven
cooling systems are cake.
Get it as close to full as you can and seal it up. if you daily drive it, check it every morning for 3-5 days. it will purge itself once you get it 90% of the way there.
Old 11-12-2012, 02:18 PM   #9
90Bronco79
90Bronco79's Avatar
Thanks I really appreciate the help.
Rides
Old 11-12-2012, 02:22 PM   #10
JKossarides
Age for one thing if you don't know how old it is, the coil spring in the center and overall condition. I just changed mine since it's been on there for 9 years since I've owned the BKO and probably the original one, sometimes rountine maintainance replacement is in order if parts are old.....http://www.oreillyauto.com/site/c/de...3389&ppt=C0331
You can tell if your temp needle is moving up towards H where the fan clutch may not be doing it's job.
Shop around for a better price on the internet, I'm sure you can do better..
Good Luck ~
Old 11-12-2012, 02:32 PM   #11
Steve83
Steve83's Avatar
Read this caption:
...AND the link I posted above.
Old 11-12-2012, 02:33 PM   #12
TheUnforgiven
when cold, you should be able to spin the fan with relative ease by hand (WITH THE ENGINE OFF), and once at operating temperature the fan should be almost impossible to turn by hand (WITH ENGINE OFF).
if it doesn't follow either of those, it's bad.
Old 11-12-2012, 02:39 PM   #13
90Bronco79
90Bronco79's Avatar
I'll check that out too. Added fluid after the drop from purging and filled the res I hope this works going to take if for a drive later will let you know the out come. BTW I have read both thanks bookmarked both.
Rides
Old 11-13-2012, 01:17 PM   #14
90Bronco79
90Bronco79's Avatar
Driving into work this morning i noticed that when under power the temp gague would go down and then when i let off the gas it would climb to the high side of the Normal range. Still have very weak heat but it runs just not sure if the pump is going since its less then a year old.
Rides
Old 11-13-2012, 10:58 PM   #15
BronCummin5.9
Ineligible
BronCummin5.9's Avatar
Location: 04 degrees 7 minutes 37 seconds, 007 degrees 37 minutes 51 seconds
Bronco Info: 93 Parts Bucket
If it was run in the higher temps before the repairs your temp sensor could have been damaged, if you have an ohm meter you can check your sensor, but I usually replace them if the vehicle was over heated to any extreme, as they can give faulty readings and have you second guessing your repairs.
BronCummin5.9 is offline   Reply With Quote
Old 11-14-2012, 01:45 AM   #16
Steve83
Steve83's Avatar
Originally Posted by BronCummin5.9 View Post
If it was run in the higher temps before the repairs your temp sensor could have been damaged...
No, it couldn't. There is no temperature at which a FSB engine will run, shut down, & run again without repairs that would damage any sensor.
Old 11-14-2012, 07:42 AM   #17
BronCummin5.9
Ineligible
And by "repairs" you mean... heads resurfacing and new gaskets or other more involved than that of which he did already? Even if you are correct, could the sensor be bad anyway, why did he replace the water pump in the first place and heater core and thermostat?
Old 11-14-2012, 11:41 PM   #18
Steve83
Steve83's Avatar
You're not making any sense. You said the sender was damaged by heat. Where are you reading that his engine ever got hot? What temperature do you think it would have to get to for the sender to be damaged?
Old 11-15-2012, 02:56 AM   #19
BronCummin5.9
Ineligible
I didn't say the sensor was damaged ...
It doesn't say the engine was run hot it said parts were replaced... BUt why were they replaced ya reckon?
As for temperatures it takes to destroy a sensor.... I wouldn't know, I am not making sens...or..
Old 11-15-2012, 03:09 AM   #20
Bronco Lady
Bronco Lady's Avatar
Bronco Info: 1985 351w Auto C6 4bbl Dual Exhaust on 33s
may i jump in with an over heating question? my bronco over-heated this summer. coolant was overflowing the resevoire. I kept her parked for the summer due to mechanical issues. As I drove my Bronco to the shop howevfer (in mild temps) I heard a gurgling near the passanger's side firewall where the hose/valve are and steam or smoke come out of my vents into the cab. Could this be a simple thermostat as I had initially estimated this summer, or is there a bigger issue like the heater core? thanks!
Bronco Lady is offline   Reply With Quote
You may not post replies
Forum Jump
