#1 |
Tailgate motor madness
trying to replace the tailgate lift motor with one of these:
http://www.autozone.com/autozone/par...ier=41182_0_0_ it won't line up with the holes for the screws. there is only one position where the motor sits flat and the shaft is centered in the whole. if you try to rotate it it just falls off. it sits at an angle, maybe 5 degrees off horizontal. you would think altering the gear position by spinning the motor, or the window position by moving the arms, would allow it to creep to the right position. you would be wrong. yes, I have read the thread http://www.supermotors.net/registry/2742/12689-2 you got to be a bloody contortionist to work on this thing, then this crops up. am I missing something? |
| Sponsored Links | |||
Advertisement | |||
#2 |
iTrader: (12) Bronco Info: 88 FSB. 4.9l -T18-BW1356-33" MTs-Warn hubs
I ran into the same problem with the autozone junk. I had to grind the hole open a little, but it will bolt up. Its easier if you remove the regulator.
J A S Nhttp://www.supermotors.net/registry/19528 free caveman |
#3 |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
#4 | |
#5 |
#6 |
iTrader: (0) Bronco Info: 1990 bronco 5.0 aod 4x4
window motor
go to a private auto parts vendor and buy yourself a A1 cardone window motor those match up unlike autozones.
1994 f150 xlt 4x4 flair side
#7 |
iTrader: (0) Bronco Info: 1991 Custom, 4.9 I6
I literally just finished installing pretty much that motor bought from napa. At first it was not lining up, but got the center pin in te hole and pivoted it so the screw holes lined up. From what I saw when I installed it, the gear on the motor had to line up with the window gear to fit right*obviously* but I still got it to work and now mine moves yay!! Lol
1991 Custom, 4.9 I6, 3'' inch lift and 35" tires |
#8 |
its funny i just replaced mine with a pick a part motor. it wasnt as hard as i though it was going to be. had some issues and finally figured out it was the connector not making a connection, hard wired it and its all good. how much are those motors from the parts store
#9 |
![]() Join Date: Jun 2010
iTrader: (1) Bronco Info: Brick Nose on 15x10s/32s with leveling coils
All you need to do is replace the bushings on the original motor. The last few yrs of these trucks have the window motors rivited together though.
#10 |
I bought another motor from Long Motor Company. Identical in every way to the Autozone motor.
I removed the regulator, drilled the one hole that is spaced different from the others and put the motor in. Et voila - success. in the future I will be one more voice in the "just remove the regulator" chorus. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
