What damage have i caused??? - FSB Forums
Thread Tools Display Modes
Old 11-13-2012, 07:50 AM   #1
BigJohn89
BigJohn89's Avatar
Bronco Info: 1989 XLT 5.8 with C6. 6" Rough Country Lift, Saginaw PS Pump, regeared to 4.10's
So i went to durhamtown with some friends on saturday. I unlocked my hubs (or so i thought) before leaving the trail. Drove 150 miles or so home and thought i had a problem with my right front wheel. We wrote it off as mud problems and thats all. I went out to make sure my hubs were in the free position and both seemed to be. I then started to try to lock the front right and it would not budge. I tried to turn it to free again and the cap popped off. It feels like it is still engaged on the rt side. What kind of damage have i possibly caused myself?
Sent from my DROIDX using AutoGuide.Com Free App
BigJohn89 is offline   Reply With Quote
Old 11-13-2012, 07:57 AM   #2
war1ock
war1ock's Avatar
Bronco Info: 1980 300 I6 4spd/1981 302 C6
As long as your transfer case is in 2 hi all thats happening is your front end parts are spinning. I wouldn't think that would cause damage because in the winter I leave my hubs locked for months so I don't have to get out in the snow to use 4wd
Sent from my C771 using AutoGuide.Com Free App
My Build
war1ock is offline   Reply With Quote
Old 11-13-2012, 08:23 AM   #3
BigJohn89
BigJohn89's Avatar
Well it has to be doing something because its "jumpy" in turns and you can feel it bucking a little when u start rolling off. The cap came off the right hub and a ball bearing and small spring were just laying there.
Old 11-13-2012, 08:57 AM   #4
TheUnforgiven
Salt blows goats for fun
TheUnforgiven's Avatar
Bronco Info: 2006 Kia Spectra
pull the shit apart and look.
2006 Kia Spectra 4 banger/5 speed.
I enjoy the cawk.
Originally Posted by paintballdude902 View Post
I'm going to shoot you and rape your girl
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 11-13-2012, 09:02 AM   #5
OhNoBronco85
She likes my
OhNoBronco85's Avatar
Bronco Info: 85, Rebuilt C6, Jasper 351W, Weiand, Shorties, Bed-Armor, Hella 700s, HID headlights
I've replaced hubs before. Not too hard. The warn premiums are lifetime guarantee...
Sent from my iPhone using Autoguide.com App
OhNoBronco85 is offline   Reply With Quote
Old 11-13-2012, 09:04 AM   #6
BigJohn89
BigJohn89's Avatar
Its going to the mechanics shop if its more than hubs. I dont know what im looking at. Just wondering what i could be looking at.
Old 11-13-2012, 09:08 AM   #7
BigJohn89
BigJohn89's Avatar
So it could be no damage but the hubs themselves? I was making sure i could not have messed up my front gears or transfer case or something big
Old 11-13-2012, 09:09 AM   #8
Saltlife
Beach bumming it....
Saltlife's Avatar
Bronco Info: 88 XLT 351W C6 With way too much to list here done to it.
Hubs are easy to install yourself. Snap a picture of what it looks like and post it. If it's just hubs your done in no time.
Josh
88 XLT with rebuilt 351W and C6. 7" lift on 35" 12.50 mickey thompson baja claw mtz's, SUMMIT headers, direct fit MagnaFlow High Flow cat, No mufflers, Saginaw, TRE flip, 3g 160 amp alt, HIDs, sliders, and custom bumpers with KCs.
FSB Official Health and Fitness Thread
My Build - El Surfista
Saltlife is online now   Reply With Quote
Old 11-13-2012, 09:09 AM   #9
TheUnforgiven
they probably don't know either. this design of axle is so obsolete in its setup most newer techs will look at it and go "huh".
there's a big snap ring on the ID of the hub tube. pull that out and the hub should come out then.
seriously, you're going to get F*CKED in the ass for nothin'.
I enjoy the cawk.
Old 11-13-2012, 10:16 AM   #10
AbandonedBronco
Big Six
AbandonedBronco's Avatar
Bronco Info: 1981 300ci 6cyl w/4bbl conversion. 4spd manual
I had the same popping and weird steering when I accidentally left one locked and one not. Never hurt anything, just acted funny.
Sounds like your hub went out and needs to be repaired/replaced. I imagine it'll be all good to go after that.
1981 & 1984. Both w/ 300 I6. Holley 600 4bbls. 31x10.5" tires. NP-435 trans. 2.5" Exhaust.
Supermotors Pics
AbandonedBronco is offline   Reply With Quote
Old 11-13-2012, 10:24 AM   #11
BigJohn89
BigJohn89's Avatar
Here is the inside. Hope this helps
Old 11-13-2012, 11:22 AM   #12
psychlopath
Student of life, man.
psychlopath's Avatar
Bronco Info: 1979 Freewheel'n, PowrLok, ARB, OBA, and anything else I can cram in
Holy lack of grease!
Toss a set of Warn or (better yet) Mile Marker units in there.
Check your bearings, ball joints and the rest of your front suspension while youre under there. I'm sure there are some write ups hanging around here.
And carefully consider the state of the rest of the easy-to-forget fluids in your vehicle.
I <3 FAR 43.
psychlopath is offline   Reply With Quote
Old 11-13-2012, 12:49 PM   #13
GetBent4x4
Bronco Info: Brick Nose on 15x10s/32s with leveling coils
Prob a good time to repack your wheel bearings. I took my manual hu s apart years ago and cleaned with a cup of gas and a toothbrush. Then lightly coated them in anti seize.
GetBent4x4 is offline   Reply With Quote
Old 11-13-2012, 12:52 PM   #14
mickey556
Bronco Info: '89 bone stock. Got 3/4 of parts for spring resto and disel swap tho!!!!
looks like the lack of grease in there had things all seized up, and breaking. hit up a parts store or the internet store of your choice. Advance sells warn premiums put them in my bronco a few years back. Pretty cheap fix, and only takes an hour or so.
I dont have proper tools for pulling the lock clips out so i always had to fight with them... with a pick and some snap ring pliers could easily be a 20minute job per side.
** 1989 Bronco XLT - 7.3 idi NA / ZF5 speed conversion underway. Build thread http://www.fullsizebronco.com/forum/...=1#post2865645
mickey556 is offline   Reply With Quote
Old 11-13-2012, 04:38 PM   #15
KTO17
KTO17's Avatar
Bronco Info: 1995 C-350 9 passenger bus, 7.5L, Auto, 225K miles, 8000# Winch, 285x75x16
Was that the FRITS group?
I agree with replacing with Warn premiums.
Don't just order or buy them anywhere. Some hubs require a kit that is not included with the hubs. Someone that really knows Fords will know what you need. Check with Steve83 or one of the gurus on here. They can help.
Buy a Chiltons or Haynes manual. If I can learn this so can you. Read up in the manual. When you replace the hubs you can go a little further and check the wheel bearings. IF it got really hot or not enough grease then they could have damage, BUT could be fine. You want to check the spindle nut torque anyway so go the step further and check the bearings. I did mine on my 93.
FYI. Something I learned that i didn't know. There are multiple bearings that can go bad in the spindle/hub assembly. In your case you have a hub bearing failure. There are also wheel bearings and spindle bearings. Spindle bearings are the most labor intensive to replace and probably most commonly ignored, but they should only spin when the 4x4 is engaged or the hubs locked.
If you really don't want to learn it then look for someone willing to do some side work. Its soo much cheaper!
Doug
1995 Centurion C-350 4-Door Bronco
1965 Buick Rivera-401 Nailhead V8-Sunday Driver
1961 Shasta Deluxe 19' Camper
KTO17 is offline   Reply With Quote
Old 11-13-2012, 07:21 PM   #16
GetBent4x4
Tons of manual hubs in the jy. I have been seeing them for years.
Old 11-13-2012, 07:42 PM   #17
strokin7.3
strokin7.3's Avatar
Bronco Info: 79 Custom 351m c6 np205
If you do replace them do not just glob a bunch of grease in there. A light coat of grease, atf or any other lubricant will suffice. It also appears that you have some other problem going on because your axle shaft seems to be pushed in pretty far and the snap ring is off of it. might look at your axle shaft and make sure that everything is good to go there as well. Keep in mind that you can do this yourself, its pretty easy to tear these front ends apart and as long as youre no doing gears theres not much you can really screw up.
79 Bronco Custom 351M C6 NP 205 4" lift 36x12.50x15 Super Swamper tsl 5.13s W/ lockers
94.5 F250 XLT Supercab Long bed 7.3L 5spd 4x4
strokin7.3 is offline   Reply With Quote
Old 11-13-2012, 10:44 PM   #18
BronCummin5.9
Ineligible
BronCummin5.9's Avatar
Location: 04 degrees 7 minutes 37 seconds, 007 degrees 37 minutes 51 seconds
Bronco Info: 93 Parts Bucket
Seriously?!? ATF in wheel bearings? ATF is a detergent it does NOT possess the viscosity necessary to properly lube a high heat bearing over long periods. Use proper bearing grease and pack them until it comes out the opposing gaps. Too much grease is not a bad thing in wet environments, and is cheap insurance.It is always best to check your hubs at least quarterly, or prior to any water crossings. They are fairly simple to maintain, and it looks intimidating but really if you can manage setting up your cable television, you can manage hubs , all you need is instruction , get a manual.
BronCummin5.9 is offline   Reply With Quote
Old 11-14-2012, 12:36 AM   #19
GetBent4x4
Bearing should be packed but hubs are not suppose to be. They can be lightly coated in a lube to prevent corrosion.
Old 11-14-2012, 12:39 AM   #20
TheUnforgiven
no, damn calm down. take some fawkin xanax. they were referring to putting a little ATF in the HUB LOCK.....grease in the hub lock is known to prevent them from working properly.
I enjoy the cawk.
You may not post replies
Forum Jump
