Need to lower bronco to get into enclosed trailer - FSB Forums
Thread Tools Display Modes
Old 11-13-2012, 11:30 AM   #1
ncdan
Bronco Info: 84 FSB 351W HO
I know there is ton of information on lifting these rigs but I need to lower mine about 2" temporarily.
I've pulled the shocks out and let the air out of the tires and I'm still about 2" too tall to get it into the trailer.
I might be able to get another half inch out of the tires and maybe stay on the bead.
I was wondering if anyone had any suggestions.
The only 2 things I can think of are removing the springs and or trying to compress the springs with a ratcheting strap of some sort. The truck will be like this for about 30 hours while I tow it cross country so this isn't some funky permanent setup I'm trying to do.
Any thoughts out there?
Thanks,
Dan
ncdan is offline   Reply With Quote
Old 11-13-2012, 11:37 AM   #2
Apache0715
Apache0715's Avatar
Bronco Info: 1987 XLT, Locked 9"/Posi D44 SAS, 4.10s, 351W/C6 37" STT 1995 XLT 6" lift, 351W/E4OD 35" AT
What size tires do you have on now? can you get a set of smaller tires?
Apache0715
1987 Ford Bronco XLT362W/C6 Holley 4bbl Edelbrock Performer, Comp cams
8" SAS Lift, 37" Discoverer STT
D44 Eaton Posi 4.10, Strange 9" 35sp Detroit 4.11
3G Alt and hydroboost
1995 Ford Bronco XLT; 351W, E4OD, 6" Lift, 35" BFG AT
Apache0715 is offline   Reply With Quote
Old 11-13-2012, 11:39 AM   #3
ncdan
I have brand new 33's I think a second set of tires is a budget breaker for me but I can't say it's a bad idea. I do a spare set of steelies in the garage that I might be able to get some used tires on. Heck if I thought it would make it up the trailer on the steel rims I'd roll it up on those!
Old 11-13-2012, 11:53 AM   #4
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
Try getting it up and in with the steel rims. Ratcheting the suspension would probably work also, I'd get some good ones though that are a min of 2 inch wide straps.
"hold my beer and watch this"
Hydroboost walkthrought
My Build Thread!! II
My Build Thread!! - retired
Ewgoetz is online now   Reply With Quote
Old 11-13-2012, 11:58 AM   #5
ncdan
It's looking like the ratcheting might be the fastest cheapest first attempt at this.
I'm thinking I might want to place a jack under the diff and slowly jack while ratcheting to help relieve the pressure from the ratchet to get maximum compression.
Old 11-13-2012, 01:13 PM   #6
Steve83
Steve83's Avatar
Go to the JY & buy 4 of the cheapest rims you can find that will fit, and roll it in on bare steel. Maybe throw down some plywood strips to protect the trailer floor if necessary. But you'll have to strap the truck in-place so it doesn't slide inside the trailer. If you can find rims with tiny tires, even better. They don't have to be driveable tires.
Why are you using an enclosed trailer?
Old 11-13-2012, 02:06 PM   #7
Andrew James
Age. Fac ut gaudeam
Andrew James's Avatar
Bronco Info: 1989 Bronco Custom 4.9/M5OD EFI
I was just about to say that Steve. So two votes there.
1991 Ford Bronco XLT 5.0/E4OD EFI
1996 Ford Bronco Eddie Bauer 5.8/E4OD EFI
1990 Pontiac Formula Firebird 5.7/T5 TPI
1991 Ford F150 Custom 4.9/M5OD EFI
1993 Ford Mustang Convertible 2.3/AOD EFI
Andrew James is offline   Reply With Quote
Old 11-13-2012, 02:08 PM   #8
ncdan
I have a set of 15' steel wheels in the garage that are at the right price for sure. This may sound nuts but do you think they will have enough grip to get up a plywood ramp? I guess I always have the 4wd option.
Old 11-13-2012, 02:42 PM   #9
Andrew James
Age. Fac ut gaudeam
Spray them with some rubber undercoating lol.
Old 11-13-2012, 03:09 PM   #10
Weber
I ♥ TTB
Weber's Avatar
Bronco Info: 89 lifted a smidge
I'm on board with puting the steelies or some rollers on, with my luck a strap would break and my rig would be wedged in the trailer...
Originally Posted by Broncogirl89 View Post
Well try snatch next time.
-In Heaven you get love and peace.
In Hell you get to party with Pirates and Ninjas.
Weber is offline   Reply With Quote
Old 11-13-2012, 05:14 PM   #11
JBfab
JBfab's Avatar
Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
Hit up some full sized cars and grab doughnut tires.
It's not custom if you bought it from a catalog!
Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825
JBfab is offline   Reply With Quote
Old 11-13-2012, 06:20 PM   #12
351w500
Unforgiven's Pet
351w500's Avatar
Bronco Info: '90 xlt 351w E40D Truetrac I GOT ROLLER ROCKERS !
doughnut tires that will fit the big 5 lug pattern ? One more vote for wheels only here .
351w500 is offline   Reply With Quote
Old 11-13-2012, 06:27 PM   #13
JBfab
JBfab's Avatar
Didnt some of the older lincons and merks have the big bolt pattern. Hell if they dont drill them for it. Its only to load and unload.
Old 11-13-2012, 09:46 PM   #14
gadawgz71
gadawgz71's Avatar
Bronco Info: 96 M EB w/ SAS'd D44 35s 302, 95 Blk XLT 351
Ratchet straps is all you have to do. 45 mins of your time and your done. I've had to do it to get one into a garage once but it did have a solid axle which was helpful. I'm sure it can still be done.
1996 M EB SAS D44 w/ 35's 302w-1995 Black XLT 351w-
SOLD
1996 PG EB 351w -1996 Wht EB 351w-1996 Wht Sport 351w
1996 MB EB w/ KR Interior 302w-1996 EB 351w, 3" BL- 1996 PG EB 351w
1996 351w, 115k - 1996 EB 351w- 1996 Blk Sport 408w
1995 Blk Sport 113k - 1996 Wht sport 351w-1996PG EB 351w
1993 EB 351w - 1990 302w/ M5OD -
1978 XLT 351m - 1971.5 Sport, 331w
gadawgz71 is offline   Reply With Quote
Old 11-14-2012, 02:08 PM   #15
fsbgav
fsbgav's Avatar
Bronco Info: 1989 300 CID Ford Bronco Custom
If you're aiming to hit up a junkyard to get a set of cheap wheels & tyres I did a bit of google searching a while ago and found a list of cars that have the same lug pattern as the Bronco. It's a bit European centric list but may help if you go the route of looking for a reaaly small set of wheels to fit.
It's not my list, so I cannot guarantee it's error free.
Lada
Niva (2121, Hussar, etc) – fitted with 16” x 5” wide, (ET55/57mm, ie a High offset)
Wheels: disk stamped, rim size 127J-406 (SJ-16). Tyres: radial-ply 175/80R16 with 315 mm static radius or cross-ply 6.95-16 (175-406) with 322 mm static radius.
Cossack (aka Turist, Toro, etc) OEM rims - 15” by 5.5 or 6, (H offset), different brands (ROH, BWA, etc) vary slightly in different markets.
Suzuki
LJ 80, SJ 410, SJ413, Jimny, Samurai, Escudo, Sierra, Caribbean, X-90, Vitaras & some Grand Vitaras – mostly 15 x 6 (L/M offset, -10...15mm)
Sidekick (USDM) ’96 - ’97, 16 x 7 (M offset)
Vitaras & some Grand Vitaras (USDM) ’98 -, 16 x 7 (L offset)
Maruti / Maruti Udyog
Gypsy mostly 15 x 6 (L/M offset, -10...15mm) (Indian licence built Suzuki SJ)
Kia
Sportage '93/’94 on, 15 x 7 (L/M offset, 0...-3mm) (later Sportages have 6 studs)
Rocsta
Sorentos '94 on, probably 16 x 7s, (L, 0-3mm)
Daihatsu
Taft/Scat: F10, F20, F25, F50, F55, F60, F65
F70/Fourtrack/Rugger/Rocky/Wildcat/Feroza – probably 15’s (offset 0...-3mm)
Dodge 2
Ram 1500 4WD
Ramcharger ’79-’83, 15 x 6.5 (all L offset)
Ram Charger ’88 – ‘93
Ram ½ ton truck (2wd and 4 x4) ’94 on, 16 x 7
Ram van ’85-’96, 15 x 7
½ ton truck 4x4 ’79 – ’83, 15 x 6
½ and ¾ ton truck ’84 – ’93, 15 x 7
Holden
Drover (Australian rebadged Sukuki SJ) (L/M offset, -10...15mm)
HopeStar
ON360 (progenitor of the Suzuki LJ)
Jeep
All CJ Jeeps ‘46 – ‘85 have 5x139.7 15” with either 4.5/5/6” rims (L offset)
Also Jeep full size trucks and wagons up to 1972; & C-101 Jeepster Comanando '67 to '74 (don’t mistake them for the 5x114 fitted to Cherokee/Wrangler and modern 5 stud Jeeps)
Jeeps (licence built):
Mahindra (Jeep, India), Mitsubishi (Jeep’53 – ’98, Japan), Willys Colombia (Jeep –’99), Willys Overland do Brasil/Ford (Jeep ’54 – ’83, Brazil), Kaiser Argentina (IKA) (Jeep ’56 – ’78, Argentina), Türk Willys Overland (Jeep – ‘80s) Hotchkiss (Jeep ’54 – ‘70s, France), Nekaf (Jeep ’56 – ’62, Netherlands), EBRO (Jeep ’53 - ’85, Spain), Hadonghwan ('54-??, South Korea), Pars Khodro (Iran). All unconfirmed - certainly 5 stud, and very very unlikely to be anything else.
Ford M151 “Mutt” Jeeps ’59 – ’78 (unconfirmed - certainly 5 stud and likey to be based on the Jeep PCD; also they have a pretty H looking offset). Early MUTTs had cast mags (oval slots).
International Harvester
All Scouts have 5x139.7
Ford
All USDM Fords '28-'48 (?)
Mercury - all '39-'51
Post-WWII “Jailbar” pick-ups
F series trucks ’54 – ’95, 15 x 6 (L offset) (don’t mistake them for the 5x135s the ’96- F 150s had)
Lincoln - all '52-'60
Bronco ’66 – '96, 15 x 6 and 7, (L offset) (don’t mistake them for the 5x114 the Bronco II (’82 – ‘90) had)
½ ton E-100, 150 van, ’70 – ’96, 15 x 6, (L offset)
Econoline E150, ’88 – ‘94
ie you could fit the legendary Ford 9 inch diff - and keep stock rims!
Chevrolet / GMC
Tracker, Vitara (USDM) ’98 on, 15 x 6, 12mm X 1.25 (L/M offset, -10...15mm) (US rebadged Suzuki)
Niva 2 (re-badged Lada)
Pontiac
Sunrunner (Canadian rebaded Suzuki) (L/M offset, -10...15mm)
Chrysler
8 cyl. & wagon '46-'55
Imperial '54-'66
Geo
Tracker 2WD 1989-1998
Toyota
Blizzard (re-badged Daihatsu)
Landcrusier V8s are listed as 5x1.39.7s in Russia, but I suspect an error (ie actually 5x150 as the ‘Cruiser is listed in other markets, but who knows maybe their V8 'Cruisers have Daihatsu bits for some bizzare reason).
Delta Motor Corp (Phillippines)
Mini Cruiser (Daihatsu F20 based miniture version of the Toyota FJ40), (unconfirmed - certainly 5 stud, and unlikely to be anything else)
Morris
Commercial LC3 – LC5 (‘50s) (unconfirmed, looks right but need numbers?)
Mazda
Proceed (Japanese rebadged Suzuki) (don't confuse with non-Suzuki based Proceeds)
AZ-Offroad (Japanese rebadged Jimny) (L/M offset, -10...15mm)
Mahindra
Scorpio (unconfirmed - 5 stud, and they make Jeeps so maybe...)
Tata
Safari (unconfirmed - 5 stud, but they made Mercs so maybe not)
UAZ
various (ET 20, 106.0 mm, 6x15, 6x16)
LuAZ
various amphibian & utility models (unconfirmed, but they look right and were once owned by AvtoVaz), Offset High
GAZ
GAZ-69
Rolls Royce/Bentley
Silver Cloud/Phantom – the ultimate 18” ‘bling’ rims for a Niva if you can ever find a set.
Bertone Freeclimber
Daihatsu based Italian 4x4 (powered by BMW!)
Volvo
C202 & Valp L3314 models (not the C30 models which have an 8 bolt pattern) had 6.50-16" or 5.50-16" rims
Santana
Vitara and 300/350 (Spanish rebadged Suzukis) (L/M offset, -10...15mm)
Willys
Pick-ups
Offset Guide:
H = high or positive offset, typically +45, 40, 35mm (typically front wheel-drive)
M = typically + 20mm offset
L = low, typically 0 or negative offset
Hope the list helps....
Tailgate Rust.
Wear it with Pride!
My Bronco: www.supermotors.net/22205
fsbgav is offline   Reply With Quote
Old 11-15-2012, 12:27 AM   #16
Steve83
Steve83's Avatar
That list is blatantly wrong about all F-series having 15s, and about them changing in '96; F150s didn't change until '97. And they weren't all 15x6 - those were rarely used after ~'86; they were also 15x8 for 31s and 15x7 for metric until ~'91; and 15x7.5 for metric from ~92-96.
Old 11-15-2012, 12:36 AM   #17
GetBent4x4
Bronco Info: Brick Nose on 15x10s/32s with leveling coils
Prob says 96 for the f-series because the 97 body style came out early like April of 96 it was hitting dealerships.
GetBent4x4 is offline   Reply With Quote
Old 11-15-2012, 12:54 AM   #18
Steve83
Steve83's Avatar
That's a stretch. What about the '95 F450 or the '82 F250? It's an ERROR.
Old 11-15-2012, 03:20 PM   #19
fsbgav
fsbgav's Avatar
Like I said, it's not my list so I can't guarantee accuracy.
I just posted to try and help the OP.
Tailgate Rust.
Wear it with Pride!
Old 11-15-2012, 04:19 PM   #20
f150inline
f150inline's Avatar
Bronco Info: f150
steel wheels and spray the lips with bedliner to make them grip
96 f150 straight 6, d44 SAS, 4.56s, Aussie lockers, 35 inch mtrs. My build thread http://www.fullsizebronco.com/forum/...d.php?t=213623
f150inline is offline   Reply With Quote
You may not post replies
Forum Jump
