What is this? - FSB Forums
Thread Tools Display Modes
Old 11-13-2012, 09:53 PM   #1
Jitters
Jitters's Avatar
Bronco Info: 1995 Eddie Bauer
What is this?
Can anyone identify the Motorcraft unit in the photo? It's located just below the main wiring harness on my 95 Bronco
Best Regards,
Jitters
Jitters is offline   Reply With Quote
Old 11-13-2012, 09:58 PM   #2
Cheesehead
Cheesehead's Avatar
Bronco Info: 1988 XLT 5.0l w/AOD & Rebuilt BW1356
Well I have an '88 so I am not sure but it looks like the TFI module. IIRC the later years were mounted on the fenders instead of the dizzy.
Cheesehead is offline   Reply With Quote
Old 11-13-2012, 10:05 PM   #3
defcon5
defcon5's Avatar
Bronco Info: 1992 XLT 5.8, SAS 8 inches and Tons
He is right it's the TFI.
1992 Bronco XLT, 351w. 8 inch lift SAS on tons!
http://s1334.photobucket.com/
defcon5 is offline   Reply With Quote
Old 11-13-2012, 10:08 PM   #4
Jitters
Jitters's Avatar
Thanks guys. What does the TFI do?
Old 11-13-2012, 10:09 PM   #5
78-79FordMan
Ford Hoarder
78-79FordMan's Avatar
Bronco Info: 7 of them 1978-79's and 1 of the 1991's and 1 of them 1986's
make ya rig run
Ford It Man
78-79FordMan is offline   Reply With Quote
Old 11-13-2012, 10:11 PM   #6
defcon5
defcon5's Avatar
The Thick Film Ignition module, type IV serves two functions.
1. It accepts a very weak signal from the distributor (a 'trigger" signal, by a Hall Effect method) and uses that trigger signal to open and close a solid state switch to the ignition coil.
2. It measures the current loading to the ignition coil, and adjusts the current sent to the coil to the optimum so it reaches saturation, but is not overheated with excess current.
Basically then, it replaces the function of the mechanical breaker points in controlling the ignition coil, which had two parameters. One, the timing as to when the points opened, controlled by a cam., And two, the dwell (time points are closed, usually stated in degrees of rotation of the distributor) to charge the coil. Both the timing and the dwell are critical to engine performance, and points require regular maintenance. Even when performing well, there are still shortcomings, especially at high engine speeds.
While originally electronics came to automobile ignitions for improved performance and reliability; the advent of emissions regulations made them mandatory in order to minimize maintenance needs, and even just to meet requirements.
An associated note--- the TFI-IV has a history of problems when it is MOUNTED DIRECTLY on the distributor. If overheated, it will simply not function, though usually recovers when cooled sufficiently. Many hobbyists who use the module in their vintage cars use a wiring adapter and move the module itself to a cooler location under the hood, and keep the advantage of the electronics but avoid the overheating troubles. Ford Motor Co. settled a class action suit over the issue years ago.
Old 11-14-2012, 01:43 AM   #7
Steve83
Steve83's Avatar
http://fullsizebronco.com/forum/showthread.php?t=210069
Old 11-14-2012, 03:44 AM   #8
GetBent4x4
Read the meme
Bronco Info: Brick Nose on 15x10s/32s with leveling coils
95 should be on the drivers fender..the metal fender. Is it still there?
GetBent4x4 is offline   Reply With Quote
Old 11-15-2012, 09:14 PM   #9
Jitters
Jitters's Avatar
Yes it is....
Old 11-15-2012, 09:15 PM   #10
Jitters
Jitters's Avatar
Wow! This is great info. Thanks so much...
You may not post replies
Forum Jump
