NEED HELP BIG TIME!!!!!! - FSB Forums
Thread Tools Display Modes
Old 11-14-2012, 02:48 AM   #1
chevykiller916
Bronco Info: bone stock 94 xlt
ok well i have a 94 bronco which i thought was a 4x4 found out a hard way in a muddy feild but my mom originally never told me the owner had taken out the transfercase to save mpg lol so i found a deal.on cl for one but he is throwing in a dana 44 off a 79 f100 hes saying it will fit and all i need is a bracket kit for the radius arms is this true ?? also with a tranfercase which years wilk fit if i were to go another route to pick n pull the axle is stilk there for the front drive train to.connect to and the rair drive train is just hooked up to the tranny showin alot of metal on the yoke and my car is a auto 4x4 and he even tooj out the buttons but still has the wires that the case cnnect to could.i use a case that has a shifter ??
chevykiller916 is offline   Reply With Quote
Old 11-14-2012, 12:25 PM   #2
chevykiller916
bump
Old 11-14-2012, 12:39 PM   #3
fartman
fartman's Avatar
Bronco Info: 88 FSB. 4.9l -T18-BW1356-33" MTs-Warn hubs
To add that 79 axle, you will need more then just a bracket. Search on here for SAS or solid axle swap. There is some custom work that needs to be done.
If you pull one from a JY, I would look for one with a manual shifter.
Sliding rear windows, GT roll bar, Cargo net and looking for other rare options.
J A S N http://www.supermotors.net/registry/19528
fartman is offline   Reply With Quote
Old 11-14-2012, 12:48 PM   #4
LarryP
Thanks 351w500
LarryP's Avatar
Location: Northcentral,CA.Twain Harte, up here in the mountains
Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
Just put the right tcase and parts in for your bronco and be done with it.
Also please don't use titles like you did for your thread here. That titles does NO help for someone using the search here. Use the specific problem are the title thank you.
I take Prayer Requests. God Bless
LarryP is offline   Reply With Quote
Old 11-14-2012, 01:14 PM   #5
kemicalburns
Never Done
kemicalburns's Avatar
get Tcase and front/rear driveline from a 93-96 bronco at wrecking yard. just make sure the bronco has the same tranny as your otherwise the drivelines wont be the proper length.
94 XLT 357/E4OD Trans-go stage II
6" Stage II ProComp,35x12.50BFG/AT
4.88 f (aussie) / r (open) / Custom Sliders
JBA headers,Custom Y pipe hi flow cat & Full 3"
kemicalburns is offline   Reply With Quote
Old 11-14-2012, 01:46 PM   #6
Kingfish999
Nothing beets a Fullsize
Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
If they deleted the Tcase, wouldnt they also have to change output shafts of the tranny? In which case means he would have to change it back or get a new tranny.
Get a transfer case from a bronco. Tcase from an F seires truck will have a slip yoke instead of fixed yoke that our trucks have. Perferable a Borg Warner 13-56 transfercase as its factory, its very strong, has good low range, and doesnt need support like a NP205. Also look for one that doesnt have the hole for the speedometer cable in the back and one that is manual shift instead of electric.
Also you will need the correct size driveshafts front and rear. Might get lucky and find a truck that has same tranny/Tcase combo as you. otherwise you will need to get them build custom.
No that D44 will not fit easy. Its alot of work to put a SAS on our truck. Are you sure they changed the front axle to a 2wd axle? You can get any TTB D44 from an F-150 or Bronco from 1980-1996.
Kingfish999 is offline   Reply With Quote
Old 11-14-2012, 02:13 PM   #7
blue 92
Bronco Info: 92 flareside 351 zf 5speed
i need to see some pictures of this, i think the op is confused on some of the terminology(no offense intended), and we're all geussing at what he has. my guess, the motor on the t-case went bad, and the front driveshaft and switches were removed. i bet the t-case is still there. just my guess, with pictures we can help better.
or,maybe the front axle is bad, and this was done to prevent accidental engagement. just removed my front driveshaft yesterday, its not heavy enough to affect mpg on a truck this heavy.
All the things I thought I knew, I'm learning again -Don Henley
blue 92 is offline   Reply With Quote
Old 11-14-2012, 06:17 PM   #8
j. r. Nice
Forward Some Money
j. r. Nice's Avatar
Bronco Info: '89 Bronco, 5.8, MAF, Summit shorties, Bassani SS, AOD, Tru-trac posi, Stocker
X2 on the pics. I would want to see several underside ones to see what he's removed. Maybe he just "disconnected" it and left it in there.
If he's swapped to a 2WD transmission, you will need to swap it back. You'll need the adapter, transfer case, probably a rear output shaft, (+the know-how to swap it) as well as the correct driveshafts. Who knows what else he mave have removed. If the front TTB is gone.......you might just look for another truck....or a cheap donor.
What about the PCM, perhaps he changed it so it wouldn't throw codes.
Wow.
Click HERE to visit my frame-off NOS restoration thread.
Photobucket Album ....and a crap load of pictures....
j. r. Nice is online now   Reply With Quote
Old 11-15-2012, 01:21 AM   #9
chevykiller916
ill post pics tmrw. the axle is still there and back driveline is connected to the tranny and the tranfercase was romoved fersure
Old 11-15-2012, 07:32 AM   #10
garymunson
Bronco Info: 93 XLT, 5.8, E4OD, manual Xfer & hubs
I'm sure curious to see the pix. Changing a FSB to 2x is no small feat. Can't imagine what would have gone bad that wouldn't have been cheaper to fix than do that massive a swap. Certainly the trans has been changed/modified plus a custom drive shaft made up. In addition some sort of rear trans mount had to be added. Plus as stated before something probably had to be done to the computer (or the check engine bulb removed). Gonna be a bunch of work to get that back to 4x4.
garymunson is offline   Reply With Quote
Old 11-15-2012, 08:14 AM   #11
Kingfish999
the PO probably couldnt afford a rebuild on the tranny and found that tranny cheap somewhere. probably never used 4x4 so didnt bother him. all he would have to do then is new drivesahft. i dont think a transfercase will cause any codes
Old 11-15-2012, 11:35 AM   #12
chevykiller916
wheb i go to turn on the car before it fires up (were ita just the electrical powering there is a check light
Old 11-15-2012, 11:43 AM   #13
chevykiller916
Old 11-15-2012, 11:45 AM   #14
chevykiller916
Old 11-15-2012, 11:46 AM   #15
chevykiller916
Old 11-15-2012, 12:27 PM   #16
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
It's easy to swap a '91 FSB over to a ZF 2wd -if- you got a donor truck. :)
No kidding on that. :) A >8500# '90 F250 is what I bought.
Doggonit I deleted the stock-E4od-FSB-L-shaped-crossmember pictures! :/
Took 'em for a guy on FTF website forum. ;)
You got a 2wd there or a sorry-assed "one wheel wonder"?
Even my half wornout 8.8" LSD still works good enough for now.
Lots of guys have put limited slip in their rear axle and found they hardly
ever used the 4wd after that.
BeenThereAndAlreadyDoneKnowedThatOne! xD
Even done knowed that before late Nov of '74,
...my '75 F150's got Traction Lok. ;)
Check your rear axle tag...
But also your VIN plate, AXLE = H9 (has a letter) means it's an LSD...
x2 on the title.
<---------------and fill out your stuff.
I got a "like new" 1356E just sittin' here, but you gotta be close to get it.
It needs to be swapped to manual because the ATF messed up the wire
insulation and there's no use fixing such a silly idea as an electric transfer
case. :/
Alvin in AZ
Alvin in AZ is offline   Reply With Quote
Old 11-15-2012, 12:33 PM   #17
Alvin in AZ
AKA: Butthead
I think it's supposed to do that. ?? :)
If you're going to keep it you might want to invest in one of these.. ?
http://www.panix.com/~alvinj/file12/Equus3145.jpg (Equus 3145)
Getting ready to go on a trip or just stuck waiting in a parking lot I whip it
out and check for codes that don't light up the CEL (check engine light).
Alvin in AZ
Old 11-15-2012, 01:32 PM   #18
chevykiller916
x2 on the title.
case. :/
Alvin in AZ
im in sacramento no way of driving to az in my truck and being able to buy the case :/
Old 11-15-2012, 02:27 PM   #19
Kingfish999
you might as well put a lunchbox locker in the rear axle and call it good. if your tranny ever dies you can then swap it back to 4x4. jsut keep your eyes open ofr a donir truck with good e4od and 1356 with drivesahfts till then. a lunchbox locker as almsot as good as 4x4 anyways
Old 11-15-2012, 02:37 PM   #20
Alvin in AZ
AKA: Butthead
x2!
Lunch box or something similar will do you prob'ly. :)
Eaton/Detroit True-Trac is what I'm gonna get, YMMV.
Threads in Forum : Technical Write Ups
Sticky Thread Sticky: All About Lockers (Multi-page thread 1 2 3 4)
Started by peteyg:
http://www.fullsizebronco.com/forum/...ad.php?t=22630
Alvin in AZ
ps- Who sed "buy"? ;)
pps- Get under there and check out your rear axle tag and VIN tag. :)
http://www.panix.com/~alvinj/file12/Ftags.jpg
The second one down is 3L25 = 3.25 gear axle with "Traction Lok"
it came with my '75 F150 and it's got a lot of dirt and gravel road
miles on it, believe it? :) '79 and '80 was working in the Southern
Pacific System Signal Shop in Sacto.
You may not post replies
Forum Jump
