Frequency of wheel bearing changes. - FSB Forums
Thread Tools Display Modes
Old 11-15-2012, 06:43 PM   #1
rapaint66
Bronco Info: 1990 XLT 4x4
Hey guys, I have a 1990 XLT 4x4 Bronco with 55k original miles. It is in pretty good shape and does not appear to have been used offroad very much. I know it was used to pull a 26ft cig boat in Florida in its former life. My question is how often should I change the wheel bearings? It seems like a pretty big job for a noob. I have done this on boat trailers but the bronco seems like a bit more difficult. I have noticed no vibration or abnormal sounds as of yet. Just curious.
rapaint66 is offline   Reply With Quote
Old 11-15-2012, 07:03 PM   #2
DLuders
Bronco Info: (Dad of '89 Bronco owner)
If it was used to pull a boat, there is a good chance that the wheel bearings were repeatedly submerged in salt water. Maybe some of the bearing grease washed away over time. I'd replace them now. Here is a FSB topic showing pictures and instructions on a 1995 Ford Bronco wheel bearing replacement job.
DLuders is offline   Reply With Quote
Old 11-15-2012, 07:08 PM   #3
helirich
helirich's Avatar
Its not hard in front if you have a d44 spindle nut wrench. It is a little more of a pain in back because of the c-clip axles. But to answer your question, I have a 90' that still has one of the front original bearings. My truck has over 200 grand on it and extreme offset wheels. (14" wide) the rear could last just as long. I wouldn't change em unless they were bad. I find the seals are much more likely to need changing.
helirich is offline   Reply With Quote
Old 11-15-2012, 09:11 PM   #4
GetBent4x4
Bronco Info: Brick Nose on 15x10s/32s with leveling coils
You only changed them when they go bad. You should take them out and clean them off and repack them with synthetic grease, since you don't know the maintenance history.
GetBent4x4 is offline   Reply With Quote
Old 11-15-2012, 11:27 PM   #5
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
clean them off and repack them with {new, red ;} grease, since you don't
x2 :) That was what I was thinking but x2 on what ever'body said so far. :)
I carefully bent a piece of baling-wire to match the socket-size of the nut
on my '91 Bronco and then measured it before buying the socket HellaRich;)
mentioned. Got the right one the first time that way. xD
Changed my bearings the first time because a PO went through deep?water
then let water set in there and so it lightly-rusted the races and a few rollers
on both dangged wheel spindles. So mine ain't original bearings anymore. :/
Alvin in AZ
Alvin in AZ is offline   Reply With Quote
Old 11-16-2012, 05:31 PM   #6
Kingfish999
Nothing beets a Fullsize
Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
id replace them now and pack them full of grease. jsut cause there not bad this week doesnt mean there not bad next. i had 2 friends recently who i warned about them starting to fail and they both said "ill do it eventually". later that week i was using a grinder to cut blown wheel bearing races off the spindle.
best thing to do it actually lift the wheel up and move it side to side and up and down. compaire movement of the wheel to the movement of the knuckle. if the wheel and knuckle move together alot then the balljoints are bad. if the wheel only moves alot the bearings are worn. if it hardle moves then your fine but still good to regrease them at minimal. also another test i do alot is after a decently long drive, feel how warn the lockouts are. they should be warm but not too hot that you cant hold it
most places ive seen never put enough grease on them from what ive seen or they torque the nut incorrectly. even from factory they dont put much grease on them. i replace my bearings ALOT cause i do some very rought stuff to my truck that most people see as crazy and i dont like blowing bearings out
Kingfish999 is online now   Reply With Quote
Old 11-16-2012, 07:49 PM   #7
GetBent4x4
Pack em full like a pornstar.
Old 11-17-2012, 01:36 AM   #8
Americandan
Americandan's Avatar
Bronco Info: 95 5.0 XLT
From the dealer, the parts aren't very expensive. I got both inner and outer and spindle and everything including the kitchen sink for this job. I got mine from Russell Ford here in Houston so it's OEM from where ever they make it (either USA or china or whatever)
I'm not racist, I'm just culturally insensitive...
Americandan is offline   Reply With Quote
Old 11-17-2012, 02:39 AM   #9
rhauf
rhauf's Avatar
Bronco Info: 82 bronco 408w 4" lift 35's, 88 bronco 351w all stock on 31s
if the grease looks clean, and like grease (no metal shavings or signs of water or other pollutants) just add a little more grease and put it back together.
if the grease looks dirty, disassemble, clean the old grease out, and inspect the races. if they are shiny and new looking, grease and reassemble. if they are showing a wear pattern then replace them.
wheel bearings will last pretty much forever if they are kept greased properly.
-Ryan
Check out my youtube page. Many bronco videos.
http://www.youtube.com/user/rhauf1
rhauf is offline   Reply With Quote
Old 11-17-2012, 08:17 AM   #10
miesk5
I used to know this stuff
miesk5's Avatar
yo,
For replacement/inspection, see my site for Bearing, Wheel & Spindle -> Installation @ http://www.broncolinks.com/index.php?index=508
such as;
Replacement & Spindle Seals in a 90 (part of his ball joint installation)
Source: by Iolaus (Jeff J) at FSB
This is the edited version
This is by Ford for 96;
See attachment below by STEVE83 with Notes for driving in mud, water, etc.;
if your vehicle is operated off-highway, perform the following items every 1,000 miles. If your vehicle is operated in mud and/or water, perform following items daily;
Inspect front wheel bearings & lubrication. etc.
Follow the Normal Schedule for most normal everyday driving conditions.
Follow the Severe-Duty Schedule if driving habits frequently include one or more of the following conditions:
towing a trailer or carrying a heavy load
operating in severe dust conditions
extensive idling such as door-to-door delivery service
snowplowing
off-road operation
short trips of less than 10 miles (16 km) when outside temperatures remain below -18°C (0°F)
NOTE: Idling the engine for extended periods will accumulate more hours of use on the vehicle than actually indicated by the mileage odometer. Consequently, the odometer reading can be misleading when determining the right time to change engine oil and filter.
If the vehicle is used in a manner that allows it to remain stationary while the engine is running for long periods (door-to-door delivery, power/utility company trucks or similar duty), then Ford recommends increasing frequency of oil and filter changes to an interval equivalent to 200 engine hours of use. Since most vehicles are not equipped with hourmeters, it may be necessary to approximate idle time and plan oil/filter changes accordingly.
Normal Schedule
NOTE: Kilometer intervals are rounded off.
For items marked with number in parentheses, see footnotes at end of this schedule
5,000 Miles (8,000 km)
[Change engine oil and replace oil filter.
Rotate tires and adjust air pressure. (1) (2)
Check and lubricate clutch release lever (7.5L and 7.3L DI turbo diesel).
Check clutch reservoir fluid level.
Inspect and lubricate automatic transmission shift linkage.
Lubricate steering linkage suspension, driveshaft U-joint, if equipped with grease fittings, and lubricate slip-yoke (if equipped).
Inspect exhaust system for leaks, damage or loose parts. Remove any foreign material trapped by exhaust system shielding. (3)
10,000 Miles (16,000 km)
15,000 Miles (24,000 km)
Inspect engine cooling system, hoses, and clamps and check coolant strength every 15,000 miles (24,000 km) or 12 months.
For 7.3L DIT diesel engines, add 8-10 ounces of FW-15 to the engine coolant every 15,000 miles (24,000 km).
Lubricate transfer case shift lever pivot bolt and control rod connecting pins (4x4).
Inspect disc brake system hoses and lines.
Lubricate caliper slide rails (F-Super Duty).
Inspect drum brake systems, hoses and lines.
Inspect parking brake fluid level (F-Super Duty).
Replace fuel filter every 15,000 miles (24,000 km) or when the filter restriction lamp is illuminated (7.3L DI turbo diesel only).
Change fuel filter (recommended but not required for California certified vehicles).
Check spring U-bolt torque (F-Super Duty).
20,000 Miles (32,000 km)
25,000 Miles (40,000 km)
30,000 Miles (48,000 km)
For 7.3L DI turbo diesel engines, add 8-10 ounces of FW-15 to the engine coolant every 15,000 miles (24,000 km).
Replace air cleaner filter every 30,000 miles (48,000 km) or 30 months. If operating in dusty conditions, follow severe-duty maintenance schedule.
Replace the air cleaner filter when the restriction gauge is in the red zone (7.3L DIT diesel only).
Replace crankcase emission air filter. If operating in dusty conditions, follow severe-duty maintenance schedule (4.9L, 5.0L manual transmission, and 7.5L only).
Change automatic transmission fluid (5).
Inspect and lubricate front wheel bearings.
Inspect parking brake system for damage and operation.
Lubricate throttle kickdown or TV lever ball studs.
[color="Magenta"]Lubricate front axle RH axle shaft slip-yoke (4x4).[/COLORInspect and lubricate spindle needle bearings (4x4.
Inspect and lubricate hub locks (4x4).Check spring U-bolt torque (F-Super Duty).
35,000 Miles (56,000 km)
40,000 Miles (64,000 km)
45,000 Miles (72,000 km)
50,000 Miles (80,000 km)
Change engine coolant initially at 50,000 miles (80,000 km) or 48 months. Thereafter, change engine coolant every 30,000 miles (48,000 km) 36 months (gasoline engines only).
For 7.3L DI turbo diesel engines, add four (4) pints of FW-15 each time engine coolant is changed.
55,000 Miles (88,000 km)
60,000 Miles (96,000 km)
Replace spark plugs (gasoline engines only).
Replace the air cleaner filter when the restriction gauge is in the red zone (7.3L DI turbo diesel only).
Replace crankcase emission air filter. If operating in dusty conditions, follow severe-duty maintenance schedule (4.9L, 5.0L manual transmission and 7.5L only).
Replace PCV valve. (4)
Check Thermactor hoses and clamps (recommended but not required).
Inspect accessory drive belt condition.
Inspect and lubricate spindle needle bearings (4x4).
Change transfer case oil (4x4).
Change manual transmission oil.
65,000 Miles (104,000 km)
NOTE: It is normal for a certain amount of moisture and staining to be present around the muffler seams. The presence of soot, light surface rust or moisture does not indicate a faulty muffler.
70,000 Miles (112,000 km)
75,000 Miles (120,000 km)
80,000 Miles (128,000 km)
Change engine coolant every 30,000 miles (48,000 km) or every 36 months (gasoline engines only).
For 7.3L DI turbo diesel engines, four (4) pints of FW-15 each time engine coolant is changed.
85,000 Miles (136,000 km)
90,000 Miles (144,000 km)
95,000 Miles (152,000 km)
100,000 Miles (160,000 km)
All rear axle lube quantities must be replaced every 100,000 miles (160,000 km) or if the axle has been submerged in water. Otherwise, the lube should not be checked or changed unless a leak is suspected or repair required.
105,000 Miles (168,000 km)
110,000 Miles (176,000 km)
115,000 Miles (184,000 km)
120,000 Miles (192,000 km)
Replace manual transmission oil.
Replace transfer case oil (4x4).
1) Wheel lug nuts must be retightened to proper torque specifications at 500 miles/800 km of new vehicle operation (100 miles/160 km and 500 miles/800 km for vehicles equipped with dual rear wheels or equipped for snowplowing). Proper torque specifications are provided in this section. Also retighten to proper torque specification at 500 miles/800 km after (1) any wheel change or (2) any other time the wheel lug nuts have been loosened.
(2) On dual rear wheel vehicles, rotate the front tires side to side without disturbing the rear tires.
(3) It is normal for a certain amount of moisture and staining to be present around the muffler seams. The presence of soot, light surface rust or moisture does not indicate a faulty muffler.
(4) At 60,000 miles (96,000 km) dealer will replace the PCV valve at no cost except on Canada and California vehicles.
(5) Except C6 and E4OD transmissions, which do not require regular fluid changes under normal operating conditions. Refer to the Severe Duty Maintenance Schedule for regular maintenance intervals for all transmissions, including C6 and E4OD.
For items marked with a number in parentheses, see footnotes at the end of this schedule.
NOTE: The Severe-Duty Schedule provides maintenance intervals for replacing air cleaner filter if vehicle is driven in severe dust conditions. However, some driving conditions may require even more frequent air cleaner replacement intervals than those shown.
3,000 Miles (5,000 km)
6,000 Miles (10,000 km)
Rotate tires and adjust air pressure. (1) (2) (3)
Inspect exhaust system for leaks, damage or loose parts. Remove any foreign material trapped by exhaust shielding. (4)
Lubricate steering linkage suspension, driveshaft U-joint, if equipped with grease fittings, and lubricate slip-yoke (if equipped). (5)
9,000 Miles (15,000 km)
12,000 Miles (20,000 km)
15,000 Miles (25,000 km)
Inspect engine cooling system, hoses, and clamps and check coolant strength every 15,000 miles (25,000 km) or 12 months.
Inspect disc brake system hoses and lines. (5)
Lubricate caliper slide rails (F-Super Duty). (5)
Change fuel filter every 15,000 miles (25,000 km) (7.5L DI turbo diesel only).
Inspect parking brake fluid (F-Super Duty).
18,000 Miles (30,000 km)
21,000 Miles (35,000 km)
Change automatic transmission fluid.
24,000 miles (40,000 km)
27,000 Miles (45,000 km)
30,000 Miles (50,000 km)
Replace air cleaner filter every 30,000 miles (50,000 km) or 30 months. (6)
Replace the air cleaner filter when the restriction gauge is in the red zone (7.3L DI turbo diesel only). (6)
For 7.3L DI turbo diesel engines, add 8-10 ounces of FW-15 to the engine coolant every 15,000 miles (25,000 km).
Replace crankcase emission air filter. (4.9L, 5.0L manual transmission and 7.5L only.) (6)
Change fuel filter every 15,000 miles (25,000 km) (7.3L DI turbo diesel only).
Inspect and lubricate front wheel bearings. (5)
Change rear axle lube (F-Super Duty only). (7)
33,000 Miles (55,000 km)
36,000 Miles (60,000 km)
Inspect exhaust system for leaks damage or loose parts. Remove any foreign material trapped by exhaust shielding. (4)
39,000 Miles (65,000 km)
42,000 Miles (70,000 km)
45,000 Miles (75,000 km)
48,000 Miles (80,000 km)
Change engine coolant initially at 48,000 miles (80,000 km) or 48 months. Thereafter, change engine coolant every 30,000 miles (50,000 km) or 36 months (gasoline engines only).
51,000 Miles (85,000 km)
54,000 Miles (90,000 km)
57,000 Miles (95,000 km)
60,000 Miles (100,000 km)
Replace PCV valve. (8)
Inspect accessory drive belts.
Inspect and lubricate front wheel bearings (5).
63,000 Miles (105,000 km)
66,000 Miles (110,000 km)
69,000 Miles (115,000 km)
72,000 Miles (120,000 km)
75,000 Miles (125,000 km)
Inspect engine cooling system, hoses and clamps and check coolant strength every 15,000 miles (25,000 km) or 12 months.
Inspect drum brake linings, hoses and lines.
78,000 Miles (130,000 km)
Change engine coolant every 30,000 miles (50,000 km) or 36 months (gasoline engines only).
81,000 Miles (135,000 km)
84,000 Miles (140,000 km)
87,000 Miles (145,000 km)
90,000 Miles (150,000 km)
Replace crankcase emission air filter (4.9L, 5.0L manual transmission and 7.5L only). (6)
Change rear axle lube (F-Super Duty only). (4)
93,000 Miles (155,000 km)
96,000 Miles (160,000 km)
Lubricate throttle kick-down or TV lever ball studs.
99,000 Miles (165,000 km)
Replace rear axle lube.
102,000 Miles (170,000 km)
105,000 Miles (175,000 km)
108,000 Miles (180,000 km)
111,000 Miles (185,000 km)
114,000 Miles (190,000 km)
117,000 Miles (195,000 km)
120,000 Miles (200,000 km)
(1) City delivery vehicles and other unique applications that require constant turning may need more frequent tire rotation. Tire rotation interval may be based on the tire wear.
(2) Wheel lug nuts must be retightened to proper torque specifications at 500 miles (800 km) of new vehicle operation 100 miles (160 km) and 500 miles (800 km) for vehicles equipped with dual rear wheels or equipped for snowplowing). Proper torque specifications are provided in this section. Also retighten to proper torque specification at 500 miles (800 km) after (1) any wheel change or (2) any other time the wheel lug nuts have been loosened.
(3) On dual rear wheel vehicles, rotate the front tires side-to-side without disturbing the rear tires.
(4) It is normal for a certain amount of moisture and staining to be present around the muffler seams. The presence of soot, light surface rust or moisture does not indicate a faulty muffler.
(5) If the vehicle is operated "off road" in water that is deeper than the hubs (1/2 wheel height), then these items must be serviced daily.
(6) Extremely dusty conditions will require more frequent replacement of your air filter. Check your air filter at 3,000 miles (5,000 km). If it is dirty, replace it and then keep replacing it at the same interval every 3,000 miles (5,000 km). If it is not dirty, check it again at 6,000 miles (10,000 km) and again at 9,000 miles (14,500 km) until the required maintenance interval is established. Do not go beyond 30,000 miles (48,000 km).
(7) F-SUPER DUTY APPLICATIONS must change axle lube every 30,000 miles (48,000 km) unless synthetic oil is used. Super Duty vehicles are NOT equipped with synthetic oil from the factory. Synthetic oil MUST BE changed at 100,000 mile (160,000 km) intervals.
(8) At 60,000 miles (96,000 km) dealer will replace the PCV valve at no cost except on Canada and California vehicles.
USN (Ret) & MIL/DoD Contingency Planner (ret)
THANKS to ALL WHO SERVE!
my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php
Old 11-17-2012, 01:32 PM   #11
Alvin in AZ
AKA: Butthead
Originally Posted by rhauf View Post
{later on} if the grease looks clean, and like grease (no metal shavings or
back together.
x2 and buy some good grease and keep using that type and brand -or-
replace the grease and clean everything every time, take your pick. ;)
I like the "red" grease the best I ever tried, used to use the moly-sulfide
grease and since then found the red grease superior. It'd be cool to hear
what others have tried and found to work out the best for them tho.
"red" grease comes in store-brand cans and name-brand cans from what
I can tell about it, it all seems to be coming from the -same- -factory-.
A friend of mine in south central Arkansas got himself a job in a east Texas
oil bottling plant and was very upset to see house-brand-labeled bottles and
name-brand-label bottles going under the same-hopper getting the same-oil
in 'em. He was especially upset to see his favorite brand Havoline getting
the same oil as the house brand!
Really upset! LOL :)
"it either meets spec or it don't" -Alvin's guess after hearing Kenny's story
Alvin in AZ
Old 11-18-2012, 01:24 AM   #12
Mrit
Mrit's Avatar
Bronco Info: 1986 Eddie Bauer
Don't over-think it. Wheel bearings are simple, if there are no signs of a problem, you pretty much dont have one. If you hear chirping/grinding or any wheel related noise, then you need to worry.
I have never changed the pass side wheel bearings in my 1986 Bronco, and only changed the D/S because water got in there and rusted it. If ya feel the need, pull the hub and change the grease. Post pics and we can probable tell you if there is a problem
'86 Eddie Bauer, '99 F350 Lariat, '75 Corvette Stingray.
It's got safety tubes, but I ain't scared, Brakes are good, tires fair... "Hot rod Bronco"
My truck http://www.supermotors.net/registry/3868
Mrit is offline   Reply With Quote
Old 01-11-2013, 04:45 PM   #13
BroncoBuff777
Bronco Info: 1989 Ford Bronco 5.0 (Eddie Bauer) 4x4
great info
BroncoBuff777 is offline   Reply With Quote
Old 01-11-2013, 06:50 PM   #14
BakerBaker
BakerBaker's Avatar
Bronco Info: 87 EB w/302,C6,1356, 36 TSL's and I need a spare, PM me if you local and have a spare tire for sale
BakerBaker is online now   Reply With Quote
Old 01-11-2013, 09:04 PM   #15
nelbur
Bronco Info: 1986 302 EFI
I have about 230,000 on the original front wheel bearings. I repacked them once when I changed brake disks. The rears have been problematic, but I do pull a boat trailer. I have worn out two sets, and am now on a junk yard rear end.
nelbur is offline   Reply With Quote
Old 01-11-2013, 09:57 PM   #16
convcit
convcit's Avatar
Bronco Info: 1984 with a 351W, HEI Dist, Hedman headers, Holly carb, C6, 3in suspension lift, 33'in Sport Kings
Alvin in AZ
Hi/Lo oil was Valvoline and Exxon's cheap brand was the superflow... dont know if they changed anything since 1995 but find out where they are bottled and do some research to find your brands cheap... I used to use the autozone house brand becouse it was Castrol but they changed to someone else..
When in doubt... use more duct tape...
1984 with a ecently rebuilt 351W, comp. cam, Holly carb and intake, 3in suspension lift, sitting on 33
's
convcit is offline   Reply With Quote
Old 01-12-2013, 10:55 AM   #17
cajunrebel
Chillin on the Gulf Coast
cajunrebel's Avatar
Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
I personally use the blue marine grease in my all my bearings. The way I look at it is that it holds up fine in trailer bearings which see heavy loads, often for long distances, and get dipped regularly in salt water. I started using marine grease a while back and have seen less contamination with it. My pops owns 4 trailers (boat, dovetail, stakebed, and enclosed) and we packed them all with it. No problems from any of them. The boat trailer has been dipped in salt and brackish water more times than I can remember and we have never had a problem on need to repack. Trailers also commonly use smaller tires than most any Bronco has, which means more rotations per mile, and I have never had them run hot. Thats just my 2 cents worth. If your down in BR and gonna dip the thing in the water and mud you want to keep the grease as clean as possible and marine grease is made for that.
cajunrebel is offline   Reply With Quote
Old 01-12-2013, 01:53 PM   #18
Alvin in AZ
AKA: Butthead
Originally Posted by cajunrebel View Post
...blue marine grease...
x2 :)
My cowboy buddies swore by the red grease over the MoS2 enhanced grease
so I switched too then one of 'em discovered that the blue grease was better
than the red grease and they all switched when their red grease supplies ran out.
That's here in the desert and none of them are into boats anymore, it's for their
trucks and trailers. They use stock trailers anymore gone are the days of cattle
trucks made from stripped chassis. :/
I'll switch to blue grease when my red grease supply runs out. :)
Alvin in AZ
Old 01-12-2013, 03:49 PM   #19
Kingfish999
but is it rated for disk breaks?
Old 01-12-2013, 04:39 PM   #20
Alvin in AZ
AKA: Butthead
Originally Posted by Kingfish999 View Post
but is it rated for disk brakes?
I believe it is.
Read the can for me and double check.
Alvin in AZ
You may not post replies
Forum Jump
