#1 |
Doing repairs on Tailgate. Wanting to install new motor and be able to crank the window up and down with tailgate wiring unplugged. Can i run two wires from the motor to the front of truck to a electrical source and then use a three way toggle switch etc to raise and lower the window?
Tell me the right way. Temporary due to winter and the cost of tailgate wiring and installation costs. Thanks for looking
88 XLT 351 C6 BFG Mud King 31's Warn Premium Gold Hubs. Basani Y Pipe and Cat, PST Polygrahite goodies, Turbo muffler.3" tailpipe, Rancho's |
| Sponsored Links | |||
Advertisement | |||
#3 |
Thanks Steve. I posted in the FLAME FREE ZONE. I am a total mope on reading electrical diagrams and cannot understand it. Someone needs to make it easy. I am sure that a refresher for us Mopes would be appreciated by many. Thanks
#4 |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
Yeah, I know where you posted - that's one reason I DIDN'T FLAME YOU. If you can't read a wiring diagram, what exactly were you expecting? That one is about as easy as they get. The only easier ones have colored wires.
Here's the easy answer: no. A common toggle won't work without relays, and if you can't read a wiring diagram, you can't build a circuit no matter what's in it. Either fix it back to stock (the easiest fix), or pay someone to do it for you. |
#5 | |
![]() Join Date: Jan 2010
iTrader: (1) Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
There really is no easy or temp fix for the window. Except for the safety switch in the tailgate. Are you sure it's the switches that are bad and not the safety switch or the motor? The stuff isn't hard to diagnose, just need a test light and a piece of wire for the safety switch.
"hold my beer and watch this" ![]() Hydroboost walkthrought My Build Thread!! II My Build Thread!! - retired |
#6 | |
iTrader: (3) Bronco Info: 1988 XLT 5.0l w/AOD & Rebuilt BW1356
#7 |
![]() Join Date: Jan 2008
iTrader: (2) Bronco Info: Red/White '79 Custom-400, 435, 205. '86 EB beater, 302, 435, 208 stock on 35's, '95 XLT, 302, 5spd.
No need to run wires to the battery to test. Just use a 12v or higher tool battery. I've opened lots of tailgate windows at the Upull with one of my 18v cordless batteries. I carry a connector for the motor plug with a foot or so of wire left on it when I go, and it's really easy to test/work on my tailgates when I have to.
man... the things I've learned on this site simply boggle the minds of everyone I talk too. (Biker Pepe) |
#8 |
Thank you Cheesehead. That is the info i really needed. Sometimes it it better if the so called experts just stay out of it. Some like to beat up on the newbie or the guy that has for gotten so much. I did pretty much as you just said. New motor is in and the window is back in and got it up for the winter. I was told by an expert also that i cannot use a starter button and i have had one for three years also. Go figger! lol
#9 | |
"Here's the easy answer: no. A common toggle won't work without relays", I got the tailgate all back together anyway as far as i had planned to do. The window is up and weather is kept out.You didn't help me at all until your second post.Thanks for it. Cheesehead got me there. Your "REALLY" in caps is a Flame.
#10 | |
Then when I had the time and knowledge (I gained from Steve) I got mine working properly. G/LOn a side not. Don't be too hard on Steve. He comes of brash and rough around the edges but he makes you think/learn for yourself. At least he did me. Steve has a plethora of knowledge to share. He's just not the spoon feeding type. If you put in some time looking over his links you will more than likely find everything you will need. The rest will probably be hidden in the search here. ![]()
#11 | |
Life goes on and so am i. Thanks
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
