Looking to do a swap - FSB Forums
Thread Tools Display Modes
Old 11-17-2012, 03:38 PM   #1
RebelPride2009
RebelPride2009's Avatar
Bronco Info: 1996 F250 XL 5.8 E4OD, 4 inch lift, 33x12.5 bfg AT's and 277,xxx miles and still running strong!
Question Looking to do a swap
Okay so I know its not a bronco, sadly mine went to the scrap yard(rotten back half of the frame and blown trans). But now I am working with my 96 F250 XL 351w and e4od trans. 4x4 extended cab. It has around 281k on it and is solid as a rock. I noticed today after a week of towing and hauling about 2400-4000 pounds of scrap metal multiple times a day that I am loosing transmission fluid from my bell housing either the pump seal or something else, im not sure, it doesnt look like it has been pouring alot out but my fluid level is low and smells like its burning up i have paper work of the trans being completely overhauled just under 2 years ago, about 35k ago.I was going to bring it back to the shop that did the work but they are no longer in business. I have been obsessing about doing a zf swap to it for sometime and now I am looking for the transmission. But my problem, I have looked at 5 different ZF trannys, my problem is none of them are 4x4 trannys. I have been hunting craigslist for anything within 300 miles of me, Im not sure what im doing wrong but what is the 4x4 version of the tranny, I have not the slightest clue as to which one is the 4x4 model. Its getting colder out, and if I can get my hands on a transmission soon, the sooner i can get the E4-oh-shit trans out. I have only came across the ZF s5-42 transmission, what is the model type for the 4x4 ZF transmission?
RebelPride2009 is offline   Reply With Quote
Old 11-17-2012, 08:37 PM   #2
JBfab
JBfab's Avatar
Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
I belive they are the same # zfs5-42 just ones 4x and the other 2x. Just keep looking youll find one. Most often they are for the bb and not the sb. Took me almost two years till i found one at the price i was willing to pay.
It's not custom if you bought it from a catalog!
Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825
JBfab is offline   Reply With Quote
Old 11-17-2012, 08:51 PM   #3
RebelPride2009
I didnt think the BB zf trans shared the same bellhousing as sbf's? If thats the case I know where 1 is
Old 11-17-2012, 09:06 PM   #4
JBfab
JBfab's Avatar
The bb and sb are two differant bell housings. The internals are however the same as long as its gas.
Old 11-18-2012, 11:19 AM   #5
RebelPride2009
Okay well then I know where to get the transmission itself. More questions are coming, 1 can i run the T-case that I have now on the ZF trans? and 2 if i dont have the bell housing, Im gonna take a shot in the dark, but would I be able to use a bell housing off of a 2wd zf transmission for the 4x4 zf?
Old 11-18-2012, 06:18 PM   #6
JBfab
JBfab's Avatar
Your t case will work, 203,205 bw1356 elec or man. The bell housings however are cast into the case so theres no swapping of them. Bummer i know so you need to find a sb bolt pattern 4x no matter what. There is always the option of a devorced t case but that opens up more issues.
Old 11-18-2012, 11:13 PM   #7
GetBent4x4
Bronco Info: Brick Nose on 15x10s/32s with leveling coils
e4od needs a trans cooler, atleast a 11x7 and a remote filter. Btw put in a drain plug in your pan and your e4od will be the simplest trans to change the fluid on since there is a torque converter drain that is easy to get to. mercon is $11.50 a gallon at walmart, I've even seen some big lots having mercon for $3 a quart.
GetBent4x4 is offline   Reply With Quote
Old 11-18-2012, 11:23 PM   #8
lifeizhard102205
lifeizhard102205's Avatar
Bronco Info: 1993 EB 351W, SAS'd 44, 37" Hummvee tires, 10.25 rear, smittybilt 12k winch homemade mount
for the 351w you need the zfs5-42. the other ones (i forget the numbers) are for the big blocks as far as the bellhousing is concerened. the diesel has different gear ratios in it as well. read my transmission swap. it's the same swap you're wanting to do. click on my bronco build up below and i believe the link is posted in there somewhere.
lifeizhard102205 is offline   Reply With Quote
Old 11-18-2012, 11:34 PM   #9
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
I just swapped in the '90-F250-parts-truck's EEC with the ZF. :)
I have -no- idea what your '96 will need that way. :/
The F250's EEC wanted a different resistance to a certain smog
part than what was on the '91 Bronco, so swapped that too. :)
The point to that is, there's a bunch of little things like that you'll
eventually need/want and a parts truck is a cheaper way to buy
a transmission or other major part anyway. Wrecking yards can
set on their parts with high prices and wait for a sucker and no
use playing their game, is my way of looking at it. YMMV
Ain't this a pretty sight... ? ;)
Alvin in AZ
ps= x2 Life Lizard's post #8 :)
Alvin in AZ is offline   Reply With Quote
Old 11-18-2012, 11:39 PM   #10
RebelPride2009
I actually have read that entire thread down to the last period, you did an outstanding job very thorough and which is pushing me more towards wanting to do the swap. I just have to find a donor truck at a junk yard with all the parts that im going to need. And once I do your thread, will be most of my reference to this project, it has to be one of the best ones that i have read yet.
I have a large aftermarket trans cooler mounted on it along with the radiator. The only thing that is not on that i wish was is the remote filter. My 93 bronco had one and it was great, used to change it every 2 times i changed my oil. And since i have discovered that apparently i just overheated my trans, probably from pushing it too hard going over mountains with a ton of scrap metal I am going to flush the fluids, and swap the filter out this week and try to keep it going as long as i can, well at least till I can find my donor truck.
Old 11-22-2012, 07:36 PM   #11
RebelPride2009
Exclamation
Finally got a break with hunting for a parts truck, I found a guy who is only about 25 minutes from me with a 4x4 F150 w/302 he is parting out. its got a 5 speed that is said to have the low 1st(granny gear) and all the components are there. We did some negotiating via the phone, and i got a final purchase price of 450 for the trans, clutch, flywheel, pedal assembly, and maybe the transmission cross member. im gonna go up next week and pick up the stuff. is there anything else that you guys can name off that i would need to pull off of this truck when i go up there?
Old 11-22-2012, 10:36 PM   #12
cajunrebel
Chillin on the Gulf Coast
cajunrebel's Avatar
Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
That truck is probably gonna have an M5OD and not a ZF5. The M5 is not nearly as strong. Plus I believe that the flywheel is different for a 302 and a 351.
cajunrebel is offline   Reply With Quote
Old 11-22-2012, 11:31 PM   #13
Robs79BBbronco
Robs79BBbronco's Avatar
Bronco Info: 79 Ranger XLT-460,NP435,NP205,stock axles/3.50's,2.5"RC lift,33"trxxs mt's,72 impala horn(best mod)
X2....if your going to swap,go beefy.....or go home.m5od ain't worth the hassle.
Sent from my XT603
Robs79BBbronco is offline   Reply With Quote
Old 11-23-2012, 08:38 AM   #14
RebelPride2009
Sent from my XT603
I guess the hunt continues. What trucks are the ZF trannys most common to come in? I had an 89 f150 with the 4.9 that had the zf, but that was years ago.
Old 11-23-2012, 09:11 AM   #15
garymunson
Bronco Info: 93 XLT, 5.8, E4OD, manual Xfer & hubs
r.e. putting a drain plug in an E4OD pan... The only way to properly change fluid in an automatic is flushing it through the cooler line. The filter in an E4OD is large enough never to need changing for the life of the tranny. If you change one, cut the old one open and look inside it. You'll never waste time and money pulling an E4OD pan again.
garymunson is offline   Reply With Quote
Old 11-23-2012, 09:36 AM   #16
RebelPride2009
I like the drain plug idea, but my uncle who is a master transmission mechanic of over 30 years went crazy on me when i said i wanted to flush the fluid out of my trans, he says it will just kill the trans because whatever particles are in there are actually keeping it working.
You may not post replies
Forum Jump
