Cant get body of locking hubs all the way in? - FSB Forums
Thread Tools Display Modes
Old 11-18-2012, 02:19 AM   #1
wilburbeest
wilburbeest's Avatar
Bronco Info: 1989 Bronco Custom 4x4 w/300i6/M5OD
So I tore apart my front end, put in new u joints, ball joints, tie rods, grease seals, and packed the bearings. Now for some weird reason I cant get the main housing for the locking hubs far enough in to get the lock ring on the outside. I assume I did something wrong, so here's the step by step of what I did. One thing I was wondering was if the inner bearing needed to be tapped into the seal or something, but I assumed that would get pressed in when I tightened the jam nut.
  1. Drop the larger of the two wheel bearings into the inner side of the rotor, so that the smaller diameter will face the outside.
  2. Tap the new seal in
  3. Put the rotor back on the spindle.
  4. Slid the other wheel bearing in with the smaller diameter facing the inner bearing.
  5. Tightened the jam nut to 70 ft-lbs as specified in my Haynes manual
  6. Slid the locking hub body back in and found it was stopping short.
EDIT: So it just hit my dumb ass that the axle isn't bolted to anything. So I'm guessing the real issue is the axle not being out far enough.
wilburbeest is offline   Reply With Quote
Old 11-18-2012, 07:17 AM   #2
TNT89Bronco
Down to 3
TNT89Bronco's Avatar
Bronco Info: '79 351M NP435 and '78 Custom 400M C6 w/sliding windows
Yep! Get a pry bar. Pry it out a little.
'89 351W C6 Eddie Bauer -33x12.5x15
'79 351M 4 Speed Custom
'78 400M C6 Custom w/AC and sliding windows
Check out my '79 Restoration Project...
http://www.fullsizebronco.com/forum/...d.php?t=203050
TNT89Bronco is offline   Reply With Quote
Old 11-18-2012, 08:46 AM   #3
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
Or have some one pushing the axle stub from behind.
"hold my beer and watch this"
Hydroboost walkthrought
My Build Thread!! II
My Build Thread!! - retired
Ewgoetz is online now   Reply With Quote
Old 11-18-2012, 09:05 AM   #4
f150inline
f150inline's Avatar
Bronco Info: f150
there are 3 rings that hold the hub and rotor to the spindle the first one that goes on has a nipple and the second one has holes in it if the nipple is not in one of those holes you will not be able to put the third ring all the way down or put your hubs on.
96 f150 straight 6, d44 SAS, 4.56s, Aussie lockers, 35 inch mtrs. My build thread http://www.fullsizebronco.com/forum/...d.php?t=213623
f150inline is offline   Reply With Quote
Old 11-18-2012, 10:16 AM   #5
KC200787
Sitting here. Strokin my:
KC200787's Avatar
Bronco Info: 1995 Ext Cab 4x4, 5.0, 5sp Pickup
Originally Posted by wilburbeest View Post
...[*]Tightened the jam nut to 70 ft-lbs as specified in my Haynes manual
I hope you shortened up the torquing sequence for lack of typing, otherwise you'll probably have ruined wheel bearings in the short future
Otherwise, yes, the axle needs to be pryed outward. Usually take a large screwdriver/prybar and push on the u-joint to gain enough slack to put the clips on, and you're good to go. If you still can't get the clip on, chances are something else is wrong.
My Supermotors PageMy vehicles:
Truck: 1995 Ford F150, Ext. Cab, 5.0L, 5sp, 186k miles, 4x4, 31" Trailblazer Mud Terrains
Project: 1988 Bronco, c6, 5.0, 33's
DD-1996: Subaru Legacy L, AWD, 2.2L H4 190k+
KC200787 is offline   Reply With Quote
Old 11-18-2012, 11:43 PM   #6
BigBlue&Goldie
Bronco Info: 1993 5.8L
Like others have said, get a small prybar behind the u-joint. If that doesnt work, google the Warn hub install guide and the step by step tutorial on this site.
BigBlue&Goldie is offline   Reply With Quote
Old 11-20-2012, 01:08 AM   #7
wilburbeest
Thanks for all the input! Pardon the unnecessary thread
Oh #$%# that 70 ft-lbs is only to seat the bearings isn't it! Well I guess that's why you actually READ the instructions. All I did was look for the torque spec. So I need to back it off and retorque it to 15-20 ft-lbs I guess. Would that really ruin the wheel bearings just from sitting up on jack stands with the nut torqued down more than it should be for operation, but still within spec for seating?
Old 11-20-2012, 02:24 AM   #8
Billy89EB
Billy89EB's Avatar
Bronco Info: 1987 Eddie Bauer 302, 4" rancho lift, dual magnalfows, 35" Discoverer stt's
I wouldn't sweat it if it's only on the stands. I'm sure the bearings may eventually have problems operating under that torque only when driving.
Billy89EB is offline   Reply With Quote
Old 11-20-2012, 06:43 AM   #9
KC200787
KC200787's Avatar
You should be ok as long as you didn't drive it.
KC
Old 11-22-2012, 06:54 PM   #10
wilburbeest
Awesome! Good to know my tard moment Didn't cause a major issue xD
You may not post replies
Forum Jump
