Exhaust manifold bolt - FSB Forums
Thread Tools Display Modes
Old 11-18-2012, 03:04 PM   #1
captbo
captbo's Avatar
Bronco Info: 78, xlt 351M ,1992 EB 5.0, 1995 xlt 5.8
My exhaust system came friday and I began to spray the stock collector or flange bolts with PB blaster all I can see id the botton Stud and nut!, is it infact a stud or is it a "replaceable" bolt ! I am worried about breaking it!
captbo is offline   Reply With Quote
Old 11-18-2012, 04:13 PM   #2
BigBud
You thought what......
BigBud's Avatar
Bronco Info: Sold the 79 waiting for a next to free 80s to snatch
Yes, it's a thread in stud. Heat and penetrating oil and it should come out of the manifold.
79 Bronco 6" lift, mild 460, and 3/4 tons----Sold
94 F150 4x4 302 zf5spd swap----run about
97 F350 Crew Cab 4x4 4" lift---work beast
Old guys,......they're tricky.
BigBud is offline   Reply With Quote
Old 11-18-2012, 04:45 PM   #3
captbo
captbo's Avatar
Thanks Big Bud
Old 11-18-2012, 09:52 PM   #4
379sinvb
Resurection Ranch
379sinvb's Avatar
Bronco Info: War Horse,Blue Eyes,Black Stallion & Youngblood the newest member.
Spray them a couple more times before you go at them. When you do start take the wheels off, it will give you better access to them.
Rick
My Project- "Left for Dead"
379sinvb is online now   Reply With Quote
Old 11-19-2012, 10:18 AM   #5
captbo
captbo's Avatar
Will do Thanks Rick !
Old 02-10-2013, 07:57 PM   #6
johnnyreb
manifold bolts
I have found as hard as it is to remove exhaust manifolds . I replace the bolts---- with studs then I put double brass taps on them --one to make sure the otherone does not back off.Plus I add a lock washer and I have not had anymore trouble taking them off later on down the line.
johnnyreb is offline   Reply With Quote
Old 02-14-2013, 08:31 AM   #7
Full-boost21
Full-boost21's Avatar
Use deep creep made by seafoam, best canned stuff I've ever seen. Keep a small torch handy also.
"You can have any color that you want, as long as it's black."
Full-boost21 is offline   Reply With Quote
Old 02-14-2013, 10:54 AM   #8
InfoFord
InfoFord's Avatar
Bronco Info: Picador 4 door bronco EFI 460 E4OD electric shift 1356 Tcase 3.55 10.25 rear, 3.54 Dana 44 front
X2 been using it exclusive for almost 10 years makes everything else like water
Trent
NORTH COUNTRY SPECIALTIES
Picador (1979 4door Bronco)
79 Ford CrewCab 4X4(My Dually Project)
79 Ford Bronco and My Boat
InfoFord is offline   Reply With Quote
Old 02-14-2013, 12:03 PM   #9
TheUnforgiven
Salt blows goats for fun
TheUnforgiven's Avatar
Bronco Info: 2006 Kia Spectra
Heat helps, run the engine for awhile to heat up the bolts.
2006 Kia Spectra 4 banger/5 speed.
I like to eat poop.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 02-15-2013, 01:10 AM   #10
speedyweasel
Certified Asshat
speedyweasel's Avatar
Bronco Info: Dentside Bronco & '04 Excursion XLT
Originally Posted by TheUnforgiven View Post
Heat helps, run the engine for awhile to ensure that you burn the shit out of your hands.
My '78 Build Thread
...when Children, Teenage girls, Pregnant Women and Old men are trying to shoot you, chances are, They are not the enemy. -JohnMcD348
speedyweasel is offline   Reply With Quote
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
