#1 |
iTrader: (0) Bronco Info: 1995 bronco xlt 6 inch ranchero suspension lift 35 in dunlop mudrovers
Boss radio acting up
So i bought a new radio for my bronco we wired everything up correctly as far as color corrdination goes. the fuse is not blown we checked every single fuse. The radio turns on you can see it when you shine a flash light on the screen, but when you try to play music none plays and the screen and buttons don't light up like they should. There is one wire that i think may be important its an orange wire which i think is illumination. But the wiring harness on the radio itself does not have an orange wire. Any idea's of what my issue is?
| Sponsored Links | |||
Advertisement | |||
#2 |
![]() Join Date: Jan 2010
iTrader: (1) Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
Did the radio come with instructions? Or is this a stock ford radio?
"hold my beer and watch this" ![]() Hydroboost walkthrought My Build Thread!! II My Build Thread!! - retired |
#4 |
I'm gonna guess that you hooked up the wires wrong than.
I've rarely seen a aftermarket radio with the same color wiring as a car work. I suggest goin to Walmart or any other electronics place and getting a stock wire adapter. It should also have the wiring labeled for what wires are for what. Usually the orange wire is the power on in the vehicle. Look at the wiring diagram in the instructions.
#5 |
![]() Join Date: May 2007
iTrader: (4) Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
Maybe these will help...
1995 Bronco 130-1 Radio ![]() 1995 Bronco 130-2 Radio (Premium Sound) ![]() 1995 Bronco 130-3 Radio ![]() 1995 Bronco 130-4 Radio
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
#7 |
iTrader: (0) Bronco Info: 87 EB w/302,C6,1356, 36 TSL's and I need a spare, PM me if you local and have a spare tire for sale
Throw it in the trash and save up twice as much for a good quality unit.
There are eleven wires on a radio. Hot Ground Remote The other 8 are for speakers. |
#8 |
iTrader: (0) Bronco Info: 88 Bronco 351 C6 33's redhead/saginaw
+12v to power radio
+12v with constant power for the memory - 12v ground lead for power antenna 8 speaker wires on my new Kenwood HD with bells and whistles. The HD does make a difference. Now to get the new speakers in. You are going to have to cut and splice speaker wires. |
#9 |
iTrader: (3) Bronco Info: 1988 XLT 5.0l w/AOD & Rebuilt BW1356
This is all you need to make the install clean and easily reversible if you ever decide to re-install the factory unit.
http://www.scosche.com/car-audio/product/226 |
#10 |
Just throw 12+ volts to it.(dont hold me responsible if your Boss gets fried)
Or Blue/Red according to this: http://www.the12volt.com/installbay/...etail/807.html |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
