#1 |
![]() Join Date: Dec 2009
iTrader: (0) Bronco Info: 78, xlt 351M ,1992 EB 5.0, 1995 xlt 5.8
round vs square headlights
My 78 has round headlights I have seen some where the 78 has square , were they changed over? some like round? some like square? whats the deal?
| Sponsored Links | |||
Advertisement | |||
#2 |
IIRC 78 depending what trim level had round vs square.
86 F150 Xl 351H.O /c6/9"/bw1345 bbk 1 5/8 equallength hedders,2 1/4 dual,600 vac.sec holley |
#3 |
SOD BUSTERS Member
Yeah not all 78's had the square was an option, however all the 79's do have square
![]() '92 Eddie Bauer- C6/208 swap, Roller 357W, MAF, RJM Harness, BlueOvalChips SCT Tune '78 Custom- 4" Superflex Lift, Mild 460, 8 Point Cage, 4.10 Gears, 35" MTZ's '96 F250- Tow Rig, 460, E4OD Punisher Valve Body, Triple Piler Gauges '92 F150- 2wd, Winter Beater, 3.73's, 5.0 '79 F250- 2wd, Farm Truck, Waiting Restoration '03 SVT Focus- Daily Driver, OZ Wheels, 6 Spd '86 Mustang- Fastback, SOHC 4.6L Swap Project |
#4 |
:My understanding is: '78 XLT's had square, others were round, all '79's had square. My '78 (or what's left there of.....
) is an XLT & has the square lights....
If it ain't broke, keep trying to fix it!!!! |
#5 |
iTrader: (0) Bronco Info: Mostly stock '78 with a 351m. Rear disk conversion with f350 booster and master cyl.
I switched mine over to the rectangle lights. IMO, Looks way better, doesn't cost a lot and is a piece of cake to change.
#6 |
gone fish'n
![]() ![]() Join Date: Feb 2003
iTrader: (4) Bronco Info: pile of parts
78LXT = square headlights
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun! ![]() Let's Go Fishing. |
#8 |
iTrader: (1) Bronco Info: 1978 4x4 460 4 speed on 40" tires
LOL I just picked up all the parts to swap my 78 from the rectangle to the earlier round lights. I just like the look of them better, more "Old School" them the rectangle. I was going to swap on an entire grill assembly from my old 76 F250 XLT but I forgot to fill in the holes in my hood that the FORD letters mount into. I decided I didn't want
FORD FORD on my front end.
1978 Bronco Ranger XLT Blue and White (Sig pic is on little tires to fit in the garage) 460 4bbl 4 speed BW1356 40 inch tires on 16.5 wheels Work in progress: Hydraulic clutch conversion (was original auto trans), 4 wheel disc brakes, front and rear bumpers with winches, spare tire carrier, reinstall gas tank, all new fuel and brake lines, interior panels, new seats, on board storage, wet sand paint... |
#9 |
iTrader: (0) Bronco Info: 78' Bronco-Rebuilt 400m & Front/Rear Detroit Lockers
REAL TRUCKS HAVE ROUND HEADLIGHTS...haha what ever floats your boat! I like the round
78 Bronco- 4" Lift and 35s, Front/Rear Detroit Lockers, 4:10 Gears, a Rebuilt 400M, all that Jazz ![]() My Build Thread: http://www.fullsizebronco.com/forum/...d.php?t=213507 |
#11 |
iTrader: (0) Bronco Info: 1979 Bronco, 400ci, 3" Lift, 33" Coopers.
I think they both look really good. Mine is a 79 so I have the square.
Sometime I would like to see how a pair of these would look on mine. ![]() Then it wont matter what shape the headlights are.
-rvcam 1979 Bronco Ranger XLT, 351M400, C6, 4" lift, 33" Coopers. http://www.supermotors.net/23872 Last edited by rvcam; 12-05-2012 at 05:25 PM. Reason: spelling |
#13 |
iTrader: (1) Bronco Info: 80 Bronco XLT 302 4sp, 4"lift on 35" Factory LS F&R
Um no 78 had BOTH, high end had square, lower class had round.
I HAD a 78 Ranger XLT with square................. Books prove what I say................... |
#14 |
#15 |
I like headlights that work.
My 79 build http://www.fullsizebronco.com/forum/...d.php?t=207864 - Aluminum 3-core radiator, Mallory 85 HEI conversion distributor, High Angle Driveline One Tons front and rear, JBFAB Twin stick shifter kit, True trac differentials front and rear, Yukon 4.56 gears front and rear, Moser Extreme 31 spline rear axles, Borgeson adjustable steering shaft and rag joint, 95 amp 3G alternator, Fireguy/RJM Tech upgraded headlight harness, and a ton of other crap! |
#16 |
SOD BUSTERS Member
I switched mine over to square but im starting to like the round better now. I kept all the stuff thinking I might stick some non DOT off-road lights in the round bezels at some point.
#18 |
iTrader: (0) Bronco Info: 74 f100 mine,79 bronco my wifes
I like the old school look better. The square lights look to bulky to me.
Stand on it till you make it or bust it then stand on it somemore
#20 |
Convicted Drunk Dialer
iTrader: (2) Bronco Info: '78 Bronco Custom - 305 L6, ZF 5-speed, NP205, D44, 9"
Round > square. That's all you really need to know.
Supahmotahs "What’s more chickenshit than ****ing with a man’s automobile? I mean, don’t **** with another man’s vehicle." - Vincent Vega |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
