Grinding/Whining sound and a Clunk i need HELP - FSB Forums
Thread Tools Display Modes
Old 11-19-2012, 04:50 PM   #1
LiftedBronco93
sorry if there is already posts about this but I've done a little research and haven't found what the problem could be...
First off, I have a 1993 bronco AUTO, 351 windsor bored 30 over, it has a 9 inch suspension lift, ford 9 inch rear axle with 4.56 gears and locked with a spool, and a dana 44 front axle that is gutted at the moment so no 4x4...I had 36 inch super swampers on it but needed money so i sold those and only could come up on some 33's so thats whats on it now...
i never noticed the noise when i had swampers on it but now driving down the road this thing screams, it has a real loud whining/ grinding noise while accelerating, it starts at about 1.5 to 2k rpm's, when i am all the way on the gas or mostly on it it whines LOUD and when i let off a little but still slightly on the gas the grinding noise starts, if i let off completely no there is no noise at all...
the other problem is a CLUNK noise it doesn't do it to often only a few times since i had this rig but usually when I'm slowing down and it shifts back into a lower gear...
PLEASE I NEED HELP ASAP, i need to get this thing fixed as it is my daily driver and I'm starting a new job next week, and as of right not its up for sale for $3300 obo so it'd help to sell it if i got these problems fixed other then that it runs and drives like a champ, couldn't go wrong with a FORD
THANKS FOR YOUR TIME AND HELP
LiftedBronco93 is offline   Reply With Quote
Old 11-19-2012, 06:35 PM   #2
Saltlife
Beach bumming it....
Saltlife's Avatar
Bronco Info: 88 XLT 351W C6 With way too much to list here done to it.
The grinding whining noise could be bearings somewhere. Check your brakes too.
Josh
88 XLT with rebuilt 351W and C6. 7" lift on 35" 12.50 mickey thompson baja claw mtz's, SUMMIT headers, direct fit MagnaFlow High Flow cat, No mufflers, Saginaw, TRE flip, 3g 160 amp alt, HIDs, sliders, and custom bumpers with KCs.
FSB Official Health and Fitness Thread
My Build - El Surfista
Saltlife is online now   Reply With Quote
Old 11-19-2012, 06:59 PM   #3
LiftedBronco93
thanks, yeah brakes are fine, i found this video on youtube and its a similiar noise but mine is more obnoxious, and the guy said it was a tranny bearing
http://www.youtube.com/watch?v=Qli4uQJJjrk
Old 11-19-2012, 08:02 PM   #4
JMBronco
Bronco Info: 94 Bronco
sounds to me like pinion bearings, jus went through this on my 94.
JMBronco is offline   Reply With Quote
Old 11-19-2012, 08:23 PM   #5
LiftedBronco93
Where are the pinion bearings located??? and how hard is that to fix??? is it expensive???
Old 11-19-2012, 08:49 PM   #6
garymunson
Bronco Info: 93 XLT, 5.8, E4OD, manual Xfer & hubs
If it's two separate noises, I'd suspect the clunk means you need to lube the drive shaft slip joint.
garymunson is offline   Reply With Quote
Old 11-19-2012, 10:37 PM   #7
LiftedBronco93
ok yeah ill check that out... thanks
and yeah it 2 different noises the whining/ grinding is constant usually when it shifts into 2nd gear and so on at about 1500 to 2000 rpms is when it starts and then the clunk sounds like something popping in and out of place but doesn't really do it to often...
Old 11-19-2012, 10:43 PM   #8
4NIC8R
4NIC8R's Avatar
Bronco Info: 91 Silver Anniversary
Could be a lot of things. You're driving a spooled rear end on the road as a daily driver? Wow.
See how much play you have in the rear end to try and eliminate pinion bearings. Put it in neutral and see how much you can turn the driveline.
Could also be the transfer case
1991 SA
5.8L, E4OD, BW1356
217,000 miles and rolling
Second... and Fourth Owner!
4NIC8R is offline   Reply With Quote
Old 11-20-2012, 01:06 AM   #9
LiftedBronco93
Yeah i know shit happened and i got stuck with my wheeler as a daily.
I will try that tomorrow in the light and let you guys know how it goes
Old 11-20-2012, 01:08 AM   #10
LiftedBronco93
i know the front drive line will spin now in park of course because the front axle is gutted, and tried the rear drive line while in park and it does not move at all
Old 11-20-2012, 09:18 AM   #11
garymunson
r.e. the clunk....I suspect you'll find the boot around the slip joint torn. BGraveyard has been the only source I could find for them $30 something shipped.
Old 11-21-2012, 06:03 PM   #12
4NIC8R
4NIC8R's Avatar
Try the driveline in neutral. Check the U-Joints and slip joints. Are you sure you're hearing it from the rear end? If the drive line is in good order, then check the pinion. If that is ok then I'd look at the transfer case. They are famous for going out.
As for the grinding sound, it could be that the pump-stay arm in the tcase broke off and it's randomly kissing the gears inside it. That's how mine did me dirty.
1991 SA
5.8L, E4OD, BW1356
You may not post replies
Forum Jump
