#1 |
dual vs single shock high lift
hey yall, jus finished my SAS swap. im using skyjacker f250 rear 8in softride leaf springs up front. been researching but cant find a good answer. should i go dual shocks up front or single? the springs are kind of stiff, but still have a good bounce to them.
| Sponsored Links | |||
Advertisement | |||
#2 |
dual shocks will help prevent shock fade but will cost more obliviously than a single shock setup.
96 f150 straight 6, d44 SAS, 4.56s, Aussie lockers, 35 inch mtrs. My build thread http://www.fullsizebronco.com/forum/...d.php?t=213623 |
#4 |
iTrader: (1) Bronco Info: 1996 Bronco, Eddie Bauer Maroon/Tan, 5.8 6in lift with 35 " kumho mt's (craigslist special)
havent done the sas swap but thinking about doing the same, pretty much cuz the buckets have seen better days and havent decided to reoplace with single or dual
#5 |
Nothing beets a Fullsize
iTrader: (10) Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
get rid of those buckets and use use a 78-79 style buckets and F250 shock towers. the buckets add 3" of lift or so and the shock towers allow longer shocks and use a standard eyelet instead of a stud to mount the shock.
#6 |
I always feel you are better off with 1 quality shock with proper valving than 2 crap shocks. If you are sticking to slow speed offroad driving, shock fade shouldn't be a big issue.
#7 |
iTrader: (0) Bronco Info: 5.8 m5od 33" cooper STT removed sway bars msd ignition, MAF swap with open filter, SAS, M15000
I run dual shocks on mine and love it. I have a 5" lift, SAS, superflex coils, Duff radius arms, BKG shock hoops and no sway bars
BIG BABIES!!! |
#8 |
Moderator
![]() ![]() Join Date: Oct 2004
iTrader: (3) Bronco Info: 1996 EB Bronco, 5.8, E40D, Dana 44 SAS, 4.88 gears. 35" SuperSwampers
Duals are cool but a quality single can do the same.
-Steve My SAS Build http://fullsizebronco.com/forum/showthread.php?t=69270 3" Exhaust http://www.4x4preservation.com/forum...read.php?t=201 My SuperMotors http://www.supermotors.net/15991 4x4 Preservation 4x4preservation.com |
#10 |
hows the truck running without the sway bar?? i am considering taking mine out but get mixed reviews, some people say go for it some say never do it
#11 |
It handles fine so long as you take a corner at the posted speed
BIG BABIES!!! |
#14 |
this is my daily driver and i do a little bit of trail riding, nothing too rough though. but yea worse comes to worse it just goes back in
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
