#1 |
can't get to codes
i have a 96 xlt 5.8l When i try to crank it up it won't fire if I cycle the key 3 or 4 times it starts and runs good. i replaced the pressure regulator and didnt fix the the problem. check engine light came on so i picked up a Hanyes manual went through how to retrive codes it showed where to place jump wire to start koeo test i found the STI connector but can't find the DLC connector. If there is any sugguestions or hints i could use a little help.
| Sponsored Links | |||
Advertisement | |||
#2 |
![]() Join Date: Jan 2010
iTrader: (1) Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
If you have a 96, than your computer is odb2. The diagnostic port is inside the cab, to the bottom od the dash, should be kinda under the glove box and ash tray. You will need a scanner, not sure you can pull codes on obd2 manually.
"hold my beer and watch this" ![]() Hydroboost walkthrought My Build Thread!! II My Build Thread!! - retired |
#4 |
Failing fuel pump? Not priming? Or can't prime enought pressure?
Try going to a local parts place, usually they have test equipment they rent out or loan. They can also come out with the equipment and see what codes you have if you bring the vehicle to them.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
