#1 |
'94 FSB 6" Lift NEW Wrangler (35 12.5 15'zz)
always have aligned myself with a 2 X 4 and a couple of Nails 35z wore out correctly about 45K put the new Wranglers on (1200.00) and thought it would be good to get a PRO alignment 3 shops want $70-$90 for alignment one wants $180.00 !!!!! (because its lifted and raised) are they SPECIAL or am I missing something????? why would lifted and raised have anything to do with Aligning front end ????? |
| Sponsored Links | |||
Advertisement | |||
#2 |
iTrader: (0) Bronco Info: 1992 XLT 5.8, 3 inch body lift and 33 inch BFG
Because they can. That is a good price as well.
1992 Bronco XLT, 351w. Mostly stock for now. http://www.superford.org/registry/ve...il.php?id=3717 |
#3 |
They have to pay for the expensive alignment system, the guy doing the alignment, the lights in the shop, and still put some money in the owners pocket. The price isn't bad at all. Personally, I would get a lifetime alignment deal if you plan on sticking with the TTB.
#4 |
Beach bumming it....
![]() ![]() Join Date: May 2011
iTrader: (3) Bronco Info: 88 XLT 351W C6 With way too much to list here done to it.
Take it to a mom and pop shop that still aligns with mirrors and lights. If you take it to a shop with these new machines they will try to put you to stock and that is not what you are. Lift and tires do make a difference. Have you replaced your adjustment bushings?
Josh 88 XLT with rebuilt 351W and C6. 7" lift on 35" 12.50 mickey thompson baja claw mtz's, SUMMIT headers, direct fit MagnaFlow High Flow cat, No mufflers, Saginaw, TRE flip, 3g 160 amp alt, HIDs, sliders, and custom bumpers with KCs. FSB Official Health and Fitness Thread My Build - El Surfista |
#5 |
iTrader: (0) Bronco Info: 1995 ford bronco 302 engine, 4x4, 229,000 miles. E4od. 33x12.5x15 on 15x12 rims.
Yeah mom and pop. Cost was 49 dollars. Not bad i think compared to tire kdom 79.
http://www.supermotors.net/24663 |
#6 | |
![]() Join Date: May 2007
iTrader: (4) Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
#7 |
![]() Join Date: Feb 2011
iTrader: (0) Bronco Info: 1995 EB 351W, E40D
Those are average prices. We get $150 and go up from there, euro cars mostly. The rack alone is 35k then there's the actual alignment equipment, maintenance and software updates. To do it right as a shop owner is not cheap.
However a lifted truck with big tires doesn't need millimeter precision either. At the racetrack we use toe plates and a manual camber tool.
#8 |
![]() Join Date: Jun 2010
iTrader: (1) Bronco Info: Brick Nose on 15x10s/32s with leveling coils
some of the commercial idiots want two or three times what you were quoted OP. Make sure they are doing toe AND CASTER AND CAMBER. You need the adjustable bushings for caster/camber. you won't know what degree you need to till they try and adjust the caster/camber. You can always buys the bushings off rockauto and then come back in a 2nd time and let them do the caster/camber.
#9 |
iTrader: (1) Bronco Info: 1995 C-350 9 passenger bus, 7.5L, Auto, 225K miles, 8000# Winch, 285x75x16
WOW! You guys are on the wrong coast!
My local Mom & Pop in the city is $40 all day long, lifted TTB or stock 350 solid axle. Only time it was more was when they had to change out the bushings to get it right the first time. That was $20 and that only covered the parts. Make sure they are not trying to charge you for a four wheel alignment. Only time I got a qoute somewhere else they tried that. I asked the guy to show me how they would adjust the rear and he walked away!
Doug 1995 Centurion C-350 4-Door Bronco 1965 Buick Rivera-401 Nailhead V8-Sunday Driver 1961 Shasta Deluxe 19' Camper |
#10 |
Moderator
![]() ![]() Join Date: Oct 2004
iTrader: (3) Bronco Info: 1996 EB Bronco, 5.8, E40D, Dana 44 SAS, 4.88 gears. 35" SuperSwampers
Toe is easy and cheap to do, but if they have to get into camber and caster - its a huge job! I wouldn't do it for 200 bucks!
-Steve My SAS Build http://fullsizebronco.com/forum/showthread.php?t=69270 3" Exhaust http://www.4x4preservation.com/forum...read.php?t=201 My SuperMotors http://www.supermotors.net/15991 4x4 Preservation 4x4preservation.com |
#11 |
Nothing beets a Fullsize
iTrader: (10) Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
ive taken it to many shops that say 70-90$. then they call me saying you need your camber bushings replaced and that will be an hour of labor each side plus 20$ for the new bushings. 75$ alignment + 20$ bushings + 180$ labor (90$ an hour) = EXPENSIVE jsut to find out they couldnt get it alligned properly.
thats y i do it halfway myself. get adjsutable alignemtn bushings, get them at Nuetral (0*/0*) and put them in. take it somewhere that will give alignment check free and get the handout that shows how bad the alignment is. adjsut the bushings to where it needs to be. put bushings back in and adjsut the toe with the tape measurer or take it and get the toe profeshiopnally done. cant get the alignment any better than that. |
#12 | |
this It ought to be a toe and go - anything over that and it's time and materials!
#13 | |
Moderator
#14 |
not if you do it right. with the handout form the alignment check it says how much the camber and caster is off. the adjustable alignment bushings inclued a chart so you can adjsut for both to be perfect. well as lnog as your alignment isnt too far out that is. after i do my part ofthe alignment sometimes i go and get the toe set and they always wonder how i got the alignment pretty much perfect
#15 | |
Moderator
#16 |
not with adjsutable alignment bushings.
http://www.supermotors.net/registry/24917/80108 http://broncograveyard.com/bronco/i-...ings-pair.html |
#17 | |
Moderator
#18 |
you must have never seen a double axis adjsutable bushing before. you can adjsut BOTH camber and caster seperatly. they give you a chart to know what position to set it.
1. you use the chart to find how which set of letters you use so you have the correct amount of camber and caster. 2. you adjsut the top part of the bushing 3. you install the bushing so the bottom part is in the correct position 4. adjsut toe 5. ???? 6. PROFIT |
#19 | |
Moderator
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
