cb radio causing digital gauges to cut out - FSB Forums
Thread Tools Display Modes
Old 11-20-2012, 06:30 PM   #1
RyanApfel
RyanApfel's Avatar
Bronco Info: 1988 Bronco 351w 3 speed automatic 35s 4inch lift
The title says it all. Anytime I hit the talk button on the CB radio, my digital gauges for voltage water temp and oil pressure flicker and cut out until I stop pressing the button. If I unplug the antennae and press the button it doesn't make the gauges cut out so I assume it's some type of interference from the CB. Anyone know how to fix this?
RyanApfel is online now   Reply With Quote
Old 11-20-2012, 06:49 PM   #2
fartman
fartman's Avatar
Bronco Info: 88 FSB. 4.9l -T18-BW1356-33" MTs-Warn hubs Daystar leveling kit 808 Aussie locker
Is the coax running near the gauges? Did you use the same ground for the CB as the gauges?
Sliding rear windows, GT roll bar, Cargo net and looking for other rare options.
J A S N http://www.fullsizebronco.com/registry/19528
fartman is online now   Reply With Quote
Old 11-20-2012, 06:58 PM   #3
bukk
bukk's Avatar
Bronco Info: 1990 bronco 5.0 aod 4x4
cb radio
i had a similiar problem and bought a heavy duty noise filter at radio shack it worked for me and ran power from cb directly to battery instead of fusebox.
1994 f150 xlt 4x4 flair side
bukk is offline   Reply With Quote
Old 11-20-2012, 07:46 PM   #4
theramsey3
#1 Asshole
theramsey3's Avatar
Bronco Info: 90 5.0 H.O. E4OD BW1356 3.54 3L55 32/11.50R15 Black not the one in the pic ^^^
Are you using a "linear" or amplifier? if you are you likely need to get some ferrite cores to create an rf noise filter as close as you can to the gauges on the power supply and inputs. I had to do that with all of my stereo equipment when I was running my linear. every time I keyed up I could hear myself talking through my stereo equipment.
Gotta get going again soon. my supermotors for before and after.
Originally Posted by ford_munky_man View Post
I was always taught u got to lube it up before you stick it in. My friends said the teacher yesterday said that too.
theramsey3 is offline   Reply With Quote
Old 11-20-2012, 07:55 PM   #5
RyanApfel
RyanApfel's Avatar
not using an amplifier. the cb has its own power strait to the batt and its own ground to the body. i tried moving the coax as far away from any of the other wires as i could and it still had the problem. so a noise filter sounds like the way to go. does it just hook up in-line?
Old 11-20-2012, 09:29 PM   #6
bossind
Moderator
bossind's Avatar
Bronco Info: 1996 EB Bronco, 5.8, E40D, Dana 44 SAS, 4.88 gears. 35" SuperSwampers
Adjust your SWR!
http://www.rightchannelradios.com/tu...-adjusting-swr
bossind is offline   Reply With Quote
Old 11-20-2012, 10:09 PM   #7
adrianspeeder
USAF C-17 Avionics
adrianspeeder's Avatar
Bronco Info: '94, '92, '88, and '84 Broncos
And don't key your set without a dummy load or antenna. If you haven't fried your transmitter already.
Adrianspeeder
adrianspeeder is offline   Reply With Quote
Old 11-21-2012, 01:59 AM   #8
mkinsman
Bronco Info: 1996 Bronco, Eddie Bauer Maroon/Tan, 5.8 6in lift with 35 " kumho mt's (craigslist special)
never NEVER key the mic without the antenna attached, will fry the radio
mkinsman is offline   Reply With Quote
Old 11-21-2012, 06:34 PM   #9
RngTrtl
RngTrtl's Avatar
Bronco Info: 1994 5.8L, Auto, 1356
Originally Posted by bossind View Post
This. SWR is Standing Wave Ratio. If it is not as close to 1:1 as possible you are bleeding off power that could interfere with things.
1994 Ford Bronco, 5.8L, E40D Auto, 4wd
1987 Ford Bronco II, 5.0L, AOD Auto, 4wd
1985 Porsche 928, 5.0L 32V V-8
1991 Suzuki Katana, 1100cc
2000 Ford Focus Wagon (wifes grocery getter)
RngTrtl is offline   Reply With Quote
Old 11-21-2012, 06:36 PM   #10
RngTrtl
RngTrtl's Avatar
This as well. Its kinda like dry firing a bow.
Old 11-21-2012, 11:34 PM   #11
DRFC29`
DRFC29`'s Avatar
Bronco Info: 1994 351w, 6in lift ,33's spool front, ls rear 8000lb winch
What kind of antenna ? location? i had a magent mount it bleed on everything went to a solid mount on the back of the truck problem went away but thats my 2 cents.
DRFC29` is offline   Reply With Quote
Old 11-26-2012, 07:48 PM   #12
RyanApfel
RyanApfel's Avatar
It is a magnet mount on the roof. I ordered a noise filter online. If that doesn't work I'll look into a solid mount antennae.
Old 11-27-2012, 02:44 PM   #13
1starvingtrucker
1starvingtrucker's Avatar
Why are you running a magnetic mount antenna? Is your CB going to be mounted temporary, also? Get a real antenna. Good luck
1starvingtrucker is offline   Reply With Quote
Old 11-27-2012, 03:23 PM   #14
BigBlue&Goldie
Bronco Info: 1993 XLT, 5.8L, E40D, Stock......for now!
I agree, those magnetic antennas are junk. Get a Firestick and mount it on your rear tire carrier. I ran my ground to my body and have never had an issue. The coax line is easily ran in Broncos, and the Firestick kit comes with plenty.
BigBlue&Goldie is online now   Reply With Quote
Old 11-27-2012, 08:08 PM   #15
1starvingtrucker
The Firestick needs 18 feet of coax. That is what I have always been told by any CB shop I have been to. Otherwise, I don't believe you will ever get the SWR adjusted. Firestick is really good for a fiberglass and you can get one at any truck stop.
Old 12-08-2012, 01:58 AM   #16
RyanApfel
RyanApfel's Avatar
I got a magnet antennae because I don't have a tire carrier so there's no real easy spot to bolt it on. On another note, the noise filter I ordered worked like a charm. No more interference.
Old 12-12-2012, 10:40 AM   #17
1starvingtrucker
That is great if you fixed the problem and it works for you. My position is the better equipment you have the more you will be able to use it. I have one aluminum antenna and sometimes I pick up base stations from Puerto Rico and Cuba. Other times, I may pick up West Coast. I can pick up racket from El Paso any day I want to (about 800 miles away). I had a conversation two days in a row with someone in Nebraska. All of this may sound unnecessary, but if you can consistently talk to people clearly that are 5 to 10 miles away your radio becomes a lot more useful. It will help a lot just talking to people that are within eye sight.
Old 12-12-2012, 11:45 AM   #18
tonyroc14
tonyroc14's Avatar
Bronco Info: 1993 XLT 5.8,1991 XLT 5.8 - sold
My 2 cents is to run good coax and antenna. Those are the key. You should always run coax in multiples of 3 feet to get the best SWR. Here I talk about all this and I have shit coax, shot antenna and shit SWR. Lol. I just haven't had the money, time, or the interest in fixing it....
Sent from my iPhone using AutoGuide.com App
tonyroc14 is offline   Reply With Quote
Old 12-12-2012, 12:23 PM   #19
1starvingtrucker
Good coax and antenna is a must, but everyone always told me Cobra radios were good. Even some CB shops. I will never buy another. They may be tough, but I never had one that was a great performer. I had 2 or 3. I have tried them stock and taken them to the CB shop to get the mods. Didn't matter, I was always trying to get them to work better. And I couldn't. After I bought a big radio, and a few mods, I was content. I wasn't trying to make a Cobra do something it wasn't designed to do.
The radio I use now has 18 ft. coax and a Predator antenna (aluminum) and I don't think I have ever had to adjust the trim on the antenna. I do check it sometimes, though.
I always use 18 ft coax because I was told (by several CB shops) that the antennas we are talking about have a relationship to the actual size of the radio wave traveling through the air and are designed to work with a piece of coax 18 ft long (or something like that). And I don't think I have ever been able to set SWR with any other length than 18 ft.
Where did you get the "multiples of three" from? Truck stops usually have coax in multiples of 3 and I never knew why.
Old 12-12-2012, 06:15 PM   #20
tonyroc14
tonyroc14's Avatar
As a rule of thumb you want to run 18 feet because it keeps the same ratio. Antennas are simply a ratio of the actual wave length. But if you simply can not run 18 then go with 15, or 21 if you need more. I don't have the exacts as to why it's 3 feet, I just know it is, haha.
You may not post replies
Forum Jump
