Two catalytic converters? Seriously? - FSB Forums
Thread Tools Display Modes
Old 11-21-2012, 02:31 AM   #1
XLTBronc93
Bronco Info: 1993 Bronco XLT, 302, e4OD, 147k, no mods 1983 F100, 300, 3-speed 80k
Hey everyone, so the other day I went out and bought a new magnaflow cat and glasspack for my 1993 bronco 5.0. Stupid me never thought to check the exhaust before I bought them, sort of an impulse buy. Sooo now I'm trying to work with what I've got. I notice that the first cat(?) is also a sort of y pipe. I was wondering if I could punch this out and use it just as the y pipe and run the other cat behind it and not have any problems. I also noticed how tight the spaces are underneath the truck, what do you guys use to cut your pipes? I did the exhaust on my 83 pickup and there was enough room to shove a hacksaw up there. Should I buy a pipe cutter? I've only got a few days to get this done, then its back off to school so I can't really order parts and the exhaust leak is driving me nuts. Thanks a lot guys, you're always a ton of help.
1993 Bronco XLT, 302, 147k miles
31" x 10.5" Firestone Destination A/T
1983 F100, 300 "BIG SIX", 80k miles
Magnaflow Glasspack, Hiflow cat, LED interior lighting, 1600W sound system
XLTBronc93 is offline   Reply With Quote
Old 11-21-2012, 02:34 AM   #2
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs, 200,010Miles
Why do you want to punch it out?
Is the cat clogged or melted inside it?
If neither, than leave it alcove and hook up the rest.
Ewgoetz is offline   Reply With Quote
Old 11-21-2012, 02:45 AM   #3
XLTBronc93
Wow thanks for the quick replys. Yes the y pipe/CC is clogged/broken. I can hear the pieces rattling around inside when I give the engine some gas.
Here's the thing, a new y pipe costs 30 bucks and I can't find a store nearby that has it, so I'd have to order it.
The same thing happened to the cat on my 83, so I punched it out because I couldn't afford a new one. The rattling is another thing that makes me insane.
I understand that the emissions system shouldn't be touched, but the o2 sensor is in a pipe before the y-pipe so I shouldn't have to touch that and as long as I leave the other o2 sensor behind the new cat, all should be fine, right?
Old 11-21-2012, 03:09 AM   #4
XLTBronc93
Originally Posted by TheUnforgiven View Post
You're retarded. We all gotta share the same oxygen. Thanks for f*cking it up.
then order a new Y-pipe, you got the modern 3 way cat, so what's stopping you? unless the 02s are throwing codes, i'd leave them alone.
Well I mentioned it earlier, but I only have until this weekend to get it done, before I have to go back up to college, and I seriously doubt the y-pipe would get here by then because of the holiday .
Old 11-21-2012, 03:40 AM   #5
Steve83
Steve83's Avatar
Then have it delivered to where you will be when it arrives.
Did you notice the 2 transmissions, seriously? And the 2 drive axles, seriously? And the 2 doors, seriously? Just because you don't understand what things do, how they work, & why they're there, that doesn't make them useless, redundant, or unnecessary. Fix it right, and it'll last. Hack it up, and you'll be whining about it being unreliable. Read this:
http://www.fourdoorbronco.com/board/...ead.php?t=5427
Old 11-22-2012, 12:38 AM   #6
joerickson
Bronco Info: 1978 F150 Shortbed
You say there is an exhaust leak that's driving you crazy? Do you know where the leak is coming from? If it's coming from the manifolds, a new muffler will not fix the leak.
Sawzall works best for cutting the pipes.
joerickson is offline   Reply With Quote
You may not post replies
Forum Jump
