blowed up my driveshaft - FSB Forums
Thread Tools Display Modes
Old 11-21-2012, 12:16 PM   #1
oddball22
Bronco Info: 82 bronco
need to know what years will interchange with an 82 on a double cardan driveshaft. my h yoke blew a part in two pieces and damaged the end of the shaft and also the cv ball, so need a new set up. i'm a parts replacer not a tech. and this is the first time i have seen a shaft with 3 u-joints
oddball22 is offline   Reply With Quote
Old 11-21-2012, 01:13 PM   #2
Northernguy
Northernguy's Avatar
Bronco Info: 80ish Bronco 300/4.9,wee little stock carb. T-18.NP 208,9" Gotta love stock!
Most any bronco with the same transfer case will have the exact same shaft. Mine is out of an 86 at the wreckers 10 yrs ago.
They all have the double cardan joints on the rear shaft.
Welcome to the site.
https://www.fullsizebronco.com/registry/22538
Full Size Bronco! Not just a truck, It's a way of life! lol
Originally Posted by Glayd View Post
dude, these things are the Chuck Norris of SUV's. It aint gonna get any better than a Bronco.
Northernguy is online now   Reply With Quote
Old 11-21-2012, 08:40 PM   #3
BigWheelz
Bronco Info: 1978 Bronco, 466 EFI
Best bet is to get a new shaft from Jeffs Bronco
Opportunity is missed by most people because it is dressed in overalls and looks like work- Thomas A Edison
BigWheelz is offline   Reply With Quote
Old 11-21-2012, 08:42 PM   #4
Kingfish999
Nothing beets a Fullsize
Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
if the tranny and transfer case are the same it should work. dont know if a donor from a truck with a 9" axle or 8.8" axle will change the lenght. if you have any lift or do hard wheeling might wanna find a driveshaft shop and get a custom one build thats stronger and perfect length
i bought a front DS from JBG and it works but it is very worn out and loose after a year. might nto be the best quality
Kingfish999 is offline   Reply With Quote
Old 11-28-2012, 11:50 AM   #5
oddball22
i found one from an 94 but the yoke ends are not the same
Old 11-28-2012, 12:02 PM   #6
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
I believe the yoke ends changed in the mid 80's. just don't remember the exact year.
"hold my beer and watch this"
Hydroboost walkthrought
My Build Thread!! II
My Build Thread!! - retired
Ewgoetz is offline   Reply With Quote
Old 11-28-2012, 04:08 PM   #7
Kingfish999
all you have to do is take that off the u-joint. its called a companion flange. opposite of what i did which was putting a 96 axle in my 88 truck which i had to add the companion flange.
Old 11-28-2012, 04:49 PM   #8
huggyb1972
Dirty Minded
huggyb1972's Avatar
Bronco Info: 89' Bronco 5.8l Variable Speed V8, Forward, Rev, Turns left, right, stops, and everything.
You will have to change the transfer case end over also it can be done I had to do it on mine.
here is what I found http://www.fullsizebronco.com/forum/...d.php?t=193215
DRAFTHORSE
351W, C-6, 10.25/D44
FOTM DEC. 2011
"Quando Omni Flunkus, Moritati,"
When all else fails roll over and play dead.
I'm as Free as Federal, state, and local laws/ordinances allow.
huggyb1972 is offline   Reply With Quote
You may not post replies
Forum Jump
