Under valve cover inspection and no heat - FSB Forums
Thread Tools Display Modes
Old 11-23-2012, 11:27 PM   #1
InsanePyro
Junkyard Rat
InsanePyro's Avatar
Bronco Info: '89 Bronco XLT. Front clip swap. 351 w/ C6. 4" lift. 33x10.5x15 BFG Mud Terrains
I'm going to pulling my valve covers because the gaskets are cracked and leaking a bit. I'm just wondering what I should have a look at as long as I have them off.
Secondly my heat doesn't seem to want to get warm. The fan is blowing fine and all but not much warmer then outside ever gets going even after driving around for 30 minutes. The temp gauge gets to the middle but I thought I read those were dummied up just as the oil pressure gauge was.
Originally Posted by Smokes35
I thought we all bought Bronco's because they ran on whale oil and panda tears
Originally Posted by TheUnforgiven
You are a ****in' pollock. It's 10 seconds of math. Christ.
InsanePyro is online now   Reply With Quote
Old 11-24-2012, 01:56 AM   #2
Mikey350
Bronco Info: 1996 Black 302 XLT - 1994 Green 351 E. B. both have E4OD, 3.55 axles, 31 10.50x15
For the heat issue: Try reverse flushing the heater core, if that doesn't work, the heater core might be plugged. (This is assuming that the coolant is full.)
The temperature gauge is an analog device, it changes resistance as the temperature of the coolant changes. So it is NOT like the oil pressure sender, which is just a switch that closes at about 5-7 pounds of oil pressure.
For the valve covers: Look at the valve stem seals, the oil drain back holes, spin the pushrods to see if any are bent (if the engine has been running fine, you probably don't have any bent pushrods). Check/replace the PCV valve grommet, the PCV valve should be a fairly tight fit to prevent leakage. I'm sure there's more that others will add.
Mikey350 is offline   Reply With Quote
Old 11-24-2012, 01:56 AM   #3
romnasty
Sounds like a coolant flush is about due and make sure to purge the coolant system of air, if air is in trapped in the system this can cause air pockets in heater core giving you the heating grief. You can you use a coolant purge tool or burp the thermostat hope that helps. And as mike350 stated be sure to check the stem seals and if your up to the work change them they are cheap and well worth your time.
romnasty is offline   Reply With Quote
Old 11-25-2012, 12:54 AM   #4
InsanePyro
Junkyard Rat
InsanePyro's Avatar
Should I try replacing the thermostat or go right for the flush?
Old 11-25-2012, 02:00 AM   #5
rhauf
rhauf's Avatar
Bronco Info: 82 bronco 408w 4" lift 35's, 88 bronco 351w all stock on 31s
im sure flushing it is a good idea... ESPECIALLY if it has had water in the system and caused a bunch of rust and mineral deposits all over everything.
although, usually weak heater means thermostat is stuck open, wrong temperature, or missing. i'd make sure it has the correct 190 degree thermostat in it. (just put in a new one) oh, and get a decent quality thermostat. they're not expensive and it's a critical part. cheap ones can cause problems.
-Ryan
Check out my youtube page. Many bronco videos.
http://www.youtube.com/user/rhauf1
rhauf is online now   Reply With Quote
Old 11-25-2012, 01:55 PM   #6
sackman9975
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
Feel the heater hoses and see if one is hotter than the other once the engine is/should be warmed up. If one is way hotter than the other, then it sounds like the heater core is plugged.
~ Scott ~
~My Exhaust clip on YouTube ~ 205k on the odometer and no longer a daily driver. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
sackman9975 is offline   Reply With Quote
Old 11-25-2012, 07:40 PM   #7
InsanePyro
Junkyard Rat
InsanePyro's Avatar
Whats a good brand for the thermostat? And Sackman I'll do that the next time I take the Bronco out for a spin
Old 11-25-2012, 07:50 PM   #8
TheUnforgiven
Loves the vag.
TheUnforgiven's Avatar
Bronco Info: 2006 Kia Spectra
STANT all the way!!!! do NOT get a "fail-safe" stat. what they do is when they fail, they fail open so it doesn't overheat the engine. problem with them is they fail open ALL THE TIME. they SUCK ass at life. otherwise all good advice.
by the way mr.pyro, did you get my PM about the fuel filter?
2006 Kia Spectra 4 banger/5 speed.
At least I can fix an engine.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 11-25-2012, 07:57 PM   #9
InsanePyro
Junkyard Rat
InsanePyro's Avatar
Cool thats what Advance carrys...makes life a bit easier...
And yeah I got your PM
Its just been so damn cold I haven't looked into that. Still getting used to the cold after the hot as hell summer
Ah it appears I have the bowl thingy...was looking for the wrong thing the whole time.
Old 11-25-2012, 08:04 PM   #10
TheUnforgiven
Loves the vag.
just curious because your noob ass didn't say thanks or anything you dickface
i work for advance, i get 20% off anything I buy.
Old 11-25-2012, 08:10 PM   #11
InsanePyro
Junkyard Rat
InsanePyro's Avatar
Like I said barely even looked into it...but thanks all the same.
Noob? Says the guy that traded his Bronco for a Kia
Old 11-25-2012, 08:12 PM   #12
TheUnforgiven
Loves the vag.
you're welcome
and no, i didn't trade my bronco for a kia. i traded an F150 for a kia.
Old 11-25-2012, 08:22 PM   #13
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
or the valve is stuck closed and not letting coolant circulate in the core.
Originally Posted by TheUnforgiven View Post
you're welcome
what a down grade that was.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 11-25-2012, 09:08 PM   #14
TheUnforgiven
Loves the vag.
don't give a f*ck what you think don.
Old 11-25-2012, 09:12 PM   #15
jopes
gone fish'n
jopes's Avatar
BAND
Let's Go Fishing.
Old 11-25-2012, 09:13 PM   #16
jopes
gone fish'n
jopes's Avatar
oh btw, dunno if I mentioned this or not, they just stocked 5,000 tigers in 3 different lakes.
Let's Go Fishing.
Old 11-25-2012, 09:24 PM   #17
InsanePyro
Junkyard Rat
InsanePyro's Avatar
Henry Ford is rolling in his grave
Just giving you shit
Old 11-25-2012, 09:26 PM   #18
TheUnforgiven
Loves the vag.
fawk henry too, don't even care.
yea don, you mentioned that. population control for what species?
Old 11-25-2012, 09:30 PM   #19
InsanePyro
Junkyard Rat
InsanePyro's Avatar
Old 11-25-2012, 09:31 PM   #20
TheUnforgiven
Loves the vag.
it happens to everyone at least once. cry about it.
You may not post replies
Forum Jump
