C6 to 4 spd swap - FSB Forums
View Poll Results: C6 vs 4 spd 78 bronco with a 400
C6 8 44.44%
4 spd 10 55.56%
Voters: 18. You may not vote on this poll
Thread Tools Display Modes
Old 11-25-2012, 12:20 AM   #1
tylerb
Bronco Info: 1978 BRONCO xlt 400cI 4" lift 33" tires
C6 to 4 spd swap
Currently have a 1978 bronco with a 400. have a c6 for the tranny and want to throw in a 4 spd i got from a 78 bronco parts truck. Wondering what i should look at or replace before i do the swap. replacement part brands would be nice
tylerb is offline   Reply With Quote
Old 11-25-2012, 12:45 AM   #2
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
This a dd or a weekend rig?
Dd than the c6.
Weekend than maybe the 4 spd
"hold my beer and watch this"
Hydroboost walkthrought
My Build Thread!! II
My Build Thread!! - retired
Ewgoetz is online now   Reply With Quote
Old 11-25-2012, 12:55 AM   #3
InsanePyro
Junkyard Rat
InsanePyro's Avatar
Bronco Info: '89 Bronco XLT. Front clip swap. 351 w/ C6. 4" lift. 33x10.5x15 BFG Mud Terrains
I'd think it'd be the opposite. C6 gets pitiful mpg (yes yes we drive Broncos....but gas mileage is always a plus)
Originally Posted by Smokes35
I thought we all bought Bronco's because they ran on whale oil and panda tears
Originally Posted by TheUnforgiven
You are a ****in' pollock. It's 10 seconds of math. Christ.
InsanePyro is online now   Reply With Quote
Old 11-25-2012, 01:07 AM   #4
tylerb
Its a daily driver but I dnt mind shifting gears. Plus tht low front gear wld be fun on the weekends. also hoping to raise my mpg up a little from 8. The truck seems to have a slow reaction to it. Thinking its the tranny I've spent hours messing with the distributor and carb with no luck
Old 11-25-2012, 09:09 AM   #5
Ewgoetz
Ewgoetz's Avatar
Sounds like you already know your decision.
Old 11-25-2012, 11:33 AM   #6
tylerb
I want to do the swap I jst want to know what to look at or replace before I do it
Old 11-25-2012, 12:07 PM   #7
Pedestrian
Bronco Info: 79 EFI460,T18,ORD Doubler,Lincoln locked Sterling rear, Coil sprung D60 front, 4" lift on 37s
Do you have a complete donor vehicle to rob the stuff off or do you just have a transmission.
You will need the pedals, linkage, belcrank, bellhousing, release fork etc.
As far as what to replace, I would replace the clutch friction disc, pressure plate, pilot bearing and throwout bearing.
Pedestrian is offline   Reply With Quote
Old 11-25-2012, 12:13 PM   #8
tylerb
I took out every thing I need out of a parts truck
Old 11-25-2012, 07:05 PM   #9
Pedestrian
The nylon bushings on the bellcrank are replaceable as are the felt washers, also the nylon bushings on the ends of the clutch linkage rod. I also drilled and installed a grease zerk fitting on the bellcrank. None of these things are critical but it will make the clutch action smoother.
Old 11-25-2012, 07:05 PM   #10
kochic
kochic's Avatar
Bronco Info: 1979 bronco,351m C6 np 205,
I did the opposite on my '79.
I went from a 4 speed manual to a C6.
I miss the super low first gear from time to time.
I lost a bit on mileage as well, the C6 costs more in gas but I gained in ease of use...hit the gas and away you go.
If you have a parts trucks, you can do the conversion
You will have to take everything from the drive shaft on.
everything will bolt on, the holes are already there in the floor for the clutch rod.
marc
kochic is offline   Reply With Quote
Old 11-25-2012, 07:37 PM   #11
f150inline
f150inline's Avatar
Bronco Info: f150
4spd better mpg and more fun
96 f150 straight 6, d44 SAS, 4.56s, Aussie lockers, 35 inch mtrs. My build thread http://www.fullsizebronco.com/forum/...d.php?t=213623
f150inline is offline   Reply With Quote
Old 11-25-2012, 10:49 PM   #12
fomoco88
fomoco88's Avatar
Bronco Info: 85 bronco,2000 ranger,86 Ranger
I am going c-6 with mine in the spring.
fomoco88 is offline   Reply With Quote
Old 11-25-2012, 11:03 PM   #13
Ziggy
Ziggy's Avatar
Bronco Info: 79 Bronco
My DD is a stick shift and I don't mind it till I get into traffic and I get tired of holding the clutch in or I have to stop on a hill and some ding dong is on my butt. My 79' has a C6 and I'm happy with the automatic, even nicer when I'm off road, just put it in 1st gear and away I go. Friends have manuals in their vehicles and hate all the shifting they have to do when we're out wheelin' around. I'll sacrifice the MPG for less dancing with 3 pedals.
3G Alt. Upgrade, Duel Batteries, 351M bored .030 over with Edlebrock cam and intake, C-6 w/AO4D internals, 3" lift w/RS 9000, 33x12.50 MTR's, Saginaw PS Pump Conversion, On Board Air, Detroit Locker, Hydro Boost Brake System, Altimeter from a CH-46D, Map Light from a MH-53E.
U. S. Government - Wasting paper and keeping Lumber Jacks gainfully employed since 1776.
Ziggy is offline   Reply With Quote
Old 11-26-2012, 12:39 AM   #14
Seattle FSB
Seattle FSB's Avatar
Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
I'm with you. My 5-speed F250 is a pain to drive around hilly Seattle, especially in traffic.
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
Seattle FSB is offline   Reply With Quote
Old 12-02-2012, 03:50 PM   #15
tylerb
Am I better off buying a performance clutch kit or are the ones from orielys or Autozone decent
Old 12-02-2012, 04:21 PM   #16
89Heaver
Bronco Info: 89xlt 5.8l c6
i drove stick for years and there are times im glad my bronco is auto. wish i had a 4spd auto but like many admit c6 is one hell of a tranny. If you are just driving it like a sane man then get the heavy duty from a reputable company. If you need more then spend more. Only you will know how you will drive it.
89 xlt, 351w, C6, 355 gears, F250 front coils. Duratrac 33x12.5x15. 3G upgrade. My first one
89Heaver is offline   Reply With Quote
Old 12-02-2012, 06:00 PM   #17
Robs79BBbronco
Robs79BBbronco's Avatar
Bronco Info: 79 Ranger XLT-460,NP435,NP205,stock axles/3.50's,2.5"RC lift,33"trxxs mt's,72 impala horn(best mod)
X2.....it's not bad in traffic,if you had a bad knee or something...I can see the dislike of the clutch.
Sent from my XT603
Robs79BBbronco is offline   Reply With Quote
You may not post replies
Forum Jump
