#1 |
![]() Join Date: Jul 2010
iTrader: (2) Bronco Info: 81 Bronco 351M c6 SAS
tranny not engauging
truck has a C6 transmission
truck fires up i put it in drive no movement then after it sits in drive for about 30 seconds it finally engauges after its engauged the first time will go back into drive no problem til motor cools down again tranny is not slipping or showing any other issues also yes i checked my fluids. also it will go into reverse no problem
MARCH 2013 FOTM |
| Sponsored Links | |||
Advertisement | |||
#2 |
![]() Join Date: Dec 2007
iTrader: (41) Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
Sounds like it cold be a valve body issue, possible loose filter/filter port (snout).
Ever suck through a straw with a hole? Takes a while to get the fluids through past the air hole, but once its does and if there's constant draw, it will always provide pending on fluid level.
~ Scott ~ ~ Ford's, please bring back the Bronco!! ~ ~ My Exhaust clip on YouTube ~ 203k on the odometer and no longer a daily driver. ~ ~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
#3 |
yeah we were thinking to start with the filter just wanted to get an idea of what i was up against thanks
MARCH 2013 FOTM |
#4 |
Nothing beets a Fullsize
iTrader: (10) Bronco Info: 96 Bronco 5.0, 88 Bronco 5.8
tranny filter might be clogged. mine would do weird stuff when it was clogged. when i replaced it i was amazed by the crap in it. it might be good to do the valvebody while your down there tho. sucks to waist all that money on tranny fluid. good time to get a shiftkit also for the truck, it helps ALOT
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
