#1 |
I am beginning the process of repairing/replacing the rear quarters on my 1996 daily driver. I want to know if anyone has a specific brand recommendations for replacement rear quarter panels. I have been around replacement fenders that were for a service van we had, and they were really thin and tinny sounding once installed. There was no comparison between the replacement panel and the OEM panel. I do not want to order a set of new quarters from LMB, JBG, etc. and find out they are not even close to OEM quality. I know there are a lot of companies that provide these. Which have you used, and which can you recommend I either go with, or even stay away from?
Thank you. |
| Sponsored Links | |||
Advertisement | |||
#2 |
I used to know this stuff
yo BOSS,
MILL SUPPLY, Cleveland, OH Their body parts On-line Store site is For 1/4's; http://rustrepair.com/PANELS/FORD-92...BED-REPAIR.HTM 98-87-50-LH; LH Complete Rear Quarter, that fits 87-96 Ford Bronco.-detail 87-96 212.50 25.00 Pounds. 75x34x8 inches This part is too large for UPS and must be shipped Freight. Lead time is about 11 days. 98-87-50-RH; RH Complete Rear Quarter Panel, that fits 87-96 Ford Bronco.-detail 87-96 212.50 ============ to save $ on a compl 1/4 panel I bought the 1/4 panel patch panels They are primed and of 18 gauge steel - exact fit around wheel well arch and packaged very well for shipping. see #50 I ordered it on 6 JUN 2011 @ 1225 hours and received on 8 JUN 2011 !!! S & H cost for both from Cleveland, OH to NJ was $12.xx #52 LH Upper wheel arch area 16"H x 40"L 87-98 $29.00 & RH from the horizontal crease below camper top down to wheel arches and around the arches exact fit = Will be able to weld w/no adjustments to it or the 1/4 can be attached w/body adhesive or even PL Premium; Sixlitre has been experimenting w/PL Premium on some parts. Of course, cut the rusted arch section out and inner panel. so you can inspect and clean higher up inside 1/4 Here is my 1/4 panel section in my site http://www.broncolinks.com/index.php?index=459 examples; Replacement w/adhesive including inner wheel house in an 86 Source: by Sixlitre (Malcolm H, Eddie Bauer) at fullsizebronco.com Replacement w/adhesive w/parts list; including wheel house in a 90; Panel Adhesive, $26.00 a tube & Application Gun, $65.00 by wheelersautobody.com , etc. Source: by Jason T (Broncomx, Two Face) at http://www.fullsizebronco.com/forum/...p?t=7712&pp=20
96 XL 5.0 E4OD, Man Xfer/Hubs USN (Ret) & MIL/DoD Contingency Planner (ret) THANKS to ALL WHO SERVE! my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php |
#3 |
I used Browns Rust Repair Supply for my Fender replacement. The 1/4's were thicker than the stock sheet metal.
#4 |
Flange the fender or the repair panel?
I am thinking of using repair panels to fix my rusted rear fender openings over my wheel wells. I plan on glueing them into place using SEM panel adhesive. (I already have the gun, and like the product). I have a vice-grip flange tool. My question is which part do I flange? I would think I would want the old fender to be straight, and my replacement panel to be flanged. This way the repair panel buts up behind the OEM Ford rear fenders, etc. Am I correct with this?
I did think it would be easier to flange the Bronco, and strip off the outside paint to accept the flat repair panel? What do you guys think? |
#5 | |
iTrader: (0) Bronco Info: 78 Bronco,472 Super CobraJet,C6 3500 stall,39.5 Super Swampers, 5:14 Ratio
#6 |
Forward Some Money
![]() Join Date: Mar 2004
iTrader: (5) Bronco Info: '89 Bronco, 5.8, MAF, Summit shorties, Bassani SS, AOD, Tru-trac posi, Stocker
Flange the old fender and leave the repair panel flat.
Click HERE to visit my frame-off NOS restoration thread. Photobucket Album ....and a crap load of pictures.... |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
