#1 |
Ok so a little bit of the background of my truck. It is a 92 F150 with the 302 a 3 inch body lift and i just finished a SAS with a d44 & 9" combo from a'79. When i did the sas i put tierod and draglink from an 89 f350 custom track bar. When i finished the swap i had 35's and had no DEATH WOBBLE drove it around up to 60 mph no problems even took a trip to Uwharrie national forest with "no problems" but i just swapped it over to 38.5 x 15 x 15 boggers. Now that i have the boggers on i get bad death wobble on the drivers side. I know i need to rebuild the driver side hub, but that shouldn't cause the death wobble right? Any help would be good thanks.
DD is a 2010 wrangler- ****o Tango, why is m.a.n.g.o not allowed? 92 F150 Flare Side on 38.5" boggers SAS'd with 4.88's and locked front and rear. |
| Sponsored Links | |||
Advertisement | |||
#2 |
Beach bumming it....
![]() ![]() Join Date: May 2011
iTrader: (3) Bronco Info: 88 XLT 351W C6 With way too much to list here done to it.
Are the Boggers new or did you buy them used?
Josh 88 XLT with rebuilt 351W and C6. 7" lift on 35" 12.50 mickey thompson baja claw mtz's, SUMMIT headers, direct fit MagnaFlow High Flow cat, No mufflers, Saginaw, TRE flip, 3g 160 amp alt, HIDs, sliders, and custom bumpers with KCs. FSB Official Health and Fitness Thread My Build - El Surfista |
#3 |
Charlie doesn't surf!!
![]() Join Date: Apr 2003
iTrader: (31) Bronco Info: 1992 xlt, 351EFI, .040, E40D, D44 SAS w/Trutrac, Detroit locked 8.8, MAF conv, Tweecer tuned..
Wouldn't make sense for it to ride fine with the 35's then not to on the 39's. That is unless there is something wrong with the tire. Also, keep in mind, you went up nearly 4 inches to a very aggressive tire..how were they balanced?
As a side not, the 37 inch swampers I put on my rig shook like hell until I had beads put in them. |
#4 |
I bought the boggers used but the guy only had about 4 trail rides on them so basically new. Wasnt able to balance them and i didn't have any bb's to put in at the time. Do y'all think thats all it really is? I mean i know its gonna shake like hell from going from baja claws to boggers but this is only sometimes and violent
#5 |
yes they will shake like hell if they're not balanced..the swampers I have aren't nearly as aggressive as your boggers and they were a horrible ride until I had the beads put in them.
#6 |
Does it happen more at high speeds? And yes get them balanced. Did the PO have them sitting for any long period of time?
#7 |
I think they sat for a month total.
I dont really know how fast im going no speedo...but its around 35-40 havent tried to go anyhigher since i put them on
#8 |
mine were horrible at that speed until I got them balanced..even if they sat for a month, unless they were on the vehicle that wouldn't be a problem. go have them bead balanced and then let us know how it rides.
#9 |
![]() Join Date: Oct 2010
iTrader: (8) Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
Arent the boggers biased ply tires? That will also contribute to the shaking. Deff get them balanced in some way or form. Gunna need alot of bb's thats alot of rubber to balance out.
![]() Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825 |
#10 |
Balanced should help. I had a bad wobble on the highway with some tires a guy let sit for 8 months that i bought. Come to find out one had a flat spot from sitting so long.
#11 | |
Thanks 351w500
![]() ![]() Join Date: Mar 2005
Location: Northcentral,CA.Twain Harte, up here in the mountains
iTrader: (52) Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
![]() You answered you own ? Also this is not the section to ask ? So I'm moving your thread
![]() I take Prayer Requests. God Bless |
#12 |
How many Bb's would y'all guess per tire like 1/2 box
#13 |
![]() Join Date: Jan 2010
iTrader: (1) Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
http://www.fullsizebronco.com/forum/...t=43333&page=4
That thread should help you on bead balancing.
"hold my beer and watch this" ![]() Hydroboost walkthrought My Build Thread!! II My Build Thread!! - retired |
#14 |
You thought what......
![]() Join Date: Oct 2012
iTrader: (0) Bronco Info: Sold the 79 waiting for a next to free 80s to snatch
Shocks and ball joints contribute a lot to a death wobble too. Also, only one side? Make sure your track bar didn't come loose.
79 Bronco 6" lift, mild 460, and 3/4 tons----Sold ![]() 94 F150 4x4 302 zf5spd swap----run about 97 F350 Crew Cab 4x4 4" lift---work beast Old guys,......they're tricky. |
#16 |
iTrader: (0) Bronco Info: 87 EB w/302,C6,1356, 36 TSL's and I need a spare, PM me if you local and have a spare tire for sale
I am in the process of curing my death wobble on a TTB.
Yesterday, I PAID $80.60 TO HAVE MY 36 swampers BALANCED. It hurt on my wallet real bad though. But, It was worth every penny I need ball joints too. |
#17 | |
AKA: Butthead
iTrader: (0) Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
You guys seeing how Death Wobble works? :) You can "kinda fix it" with one thing but it's really a combination of things adding up that causes it. Bunch of guys with big tires and Death Wobble in this thread yet there's a bunch more out there with the same tires and no-Death-Wobble because the rest of their steering and suspension systems are in better shape (and in better adjustment too?) is all. Back in the 70's even the 2wd Chevy and Dodge pickups would get death wobble and they had the double-wishbone front suspensions on 'em like a friggin' car. So it's not just the Twin-I-Beam or Twin-Torsion-Beams doing this. There's no Death Wobble if everything's right. See it? :) Alvin in AZ ps- The bead idea sounds like a good idea. :) ...guys used-to-use water. |
#18 |
I saw a rental Jeep JK in Telluride that had such bad death wobble that the unsuspecting driver about ran it off the road! It was one of the craziest things I have ever seen a vehicle do.
Like Alvin said, I would start replacing all the joints in your front end. Our trucks are all at that age where there should be just about no factory joints/bearings left. |
#19 |
I tried to have them balanced by a shop but the boggers are too loud for the machine to balance them. The 35's i had were balanced and never had a problem like i said they were with the same busted ass ball joints.
#20 |
iTrader: (0) Bronco Info: '89 bone stock. Got 3/4 of parts for spring resto and disel swap tho!!!!
I think the real question here is, if im reading correctly, You did a SAS half assed. didnt bother to change your "busted ass ball joints", didnt bother to rebuild your hub when it should have been. And you are having problems with death wobble, as you didnt get your tires balanced.
1, fix your crap so its easier to diagnose. 2, with the 38s it puts MORE strain on your "busted ass ball joints" then the 35s did. 3, if you need wheel bearings in that front hub, that will contribute as well as bigger tires put more strain on them as well 4, balance your tires as said, but i doubt that will solve your problem entirely as you have a whole slew of stuff that could be contributing.
** 1989 Bronco XLT - 7.3 idi NA / ZF5 speed conversion underway. Build thread http://www.fullsizebronco.com/forum/...=1#post2865645 |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
