#1 |
iTrader: (0) Bronco Info: 89 Eddie Bauer 5.0 AOD
Different gear carriers for gears over a certain ratio?
Every once in a while when I'm searching about differentials on the net, I'll see a reference about carriers such as 'for rear gears up to 4.10' or 'for rear gears above 4.30'
Why is this? I always thought I could use my carrier that is currently equipped with 3.55 gears, even if I had to install 5.13. Am I missing something? Is this a Chevy/Dodge thing perhaps? |
| Sponsored Links | |||
Advertisement | |||
#2 |
Salt blows goats for fun
![]() Join Date: Aug 2004
iTrader: (8) Bronco Info: 2006 Kia Spectra
there is a carrier break after 4.10 i believe that use a different carrier. why i don't know. never looked into it. just read a little about it here.
#3 |
![]() Join Date: Feb 2012
iTrader: (0) Bronco Info: '93 Custom, '90 Lincoln 302, E4OD sixlitre tune and a lot of overdue service
You can only put so many teeth on a ring and then you need a larger ring. They can't just put smaller teeth on due to strength requirements.
#4 |
iTrader: (2) Bronco Info: 1990, 351W, E4OD, 4" lift, extended radius arms, 4.56 gears, Detroit rear, Truetrac front
It depends on the axle.
For the Bronco D44, the carrier break is at 3.92. The carrier for 3.73 gears has a lower mounting point for the ring gear than the carrier for 4.10 gears. As gear ratios go up the ring gear gets thicker. By moving the mounting point closer to the pinion, you don't need such a thick ring gear. The 8.8 doesn't have a carrier break.
It Draws Wrenches Like A Ferrari Draws Wenches... |
#5 |
for the 8.8 you will need a notched crosspin if you go with 4.56s and up.
96 f150 straight 6, d44 SAS, 4.56s, Aussie lockers, 35 inch mtrs. My build thread http://www.fullsizebronco.com/forum/...d.php?t=213623 |
#6 | |
iTrader: (0) Bronco Info: 1982 302, T-18, 4in lift w/35's
#7 |
The D50 has the same carrier break as D44, so yes 4.56 gears will work on one that had 4.10.
The 9" does not have a carrier break so 4.56 will work there too.
#8 |
Oh,I see.
So, it's safe to pick up a locker for my 8.8, but leave the front LSD until I change gears from 3.55 to something bigger. That makes a lot of sense. Thanks! |
#9 |
Choose your 8.8 locker properly.
If your 8.8 has a factory L/S (likely if the front has it), most of the drop in lockers (Spartan, Aussie, Lock Right, etc) won't fit. I've read that there are some made for the L/S carrier but they are expensive to the point of being near a Detroit, which is better than any drop in locker because it replaces the 8.8 carrier. If your 8.8 is an open carrier you have many options. My personal drop in preference is the Aussie. I had one in my CJ7 and it worked great.
#10 |
I'm open front and rear right now, with 3.55.
I was thinking about picking up a Powertrax for the rear 8.8, and then looking for a factory traction-lok to put in the front. However, I think I'll leave the front open, unless I could find a smoking deal on one. Really appreciate all of the info. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
