#1 |
MSD install help
I have a 95 with a 351 and looking for advise on where to put my MSD box. I am thinking of removing my smog pump (since we don't have emission in Florida) and remove the extra parts and install above the right wheel well. Is this a good option or is there a better place?
Thanks |
| Sponsored Links | |||
Advertisement | |||
#2 |
![]() Join Date: Jan 2010
iTrader: (2) Bronco Info: 1995 XLT 351W, 2.5 R/C Lift,4.10's..much more to come
A better place for the MSD box would be the trash can.
Not trying to be a dick but MSD systems(made in Taiwan I believe)are failure waiting to happen.
No bum that can't speak poifect English oughta stay in this country...oughta be de-exported the hell outta here!" -Archie Bunker bron·co/ˈbräNGkō/ Noun: A wild or half-tamed horse, esp. of the western US. |
#3 | |
![]() Join Date: May 2007
iTrader: (4) Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
A Multi-Spark Ignition Box works great, if it is installed correctly. The power and especially the ground must be directly off of the battery. I installed mine on the passenger side inside fender, adjacent to the Starter Relay. I removed my unusable lift-jack bracket to make room.
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
#4 |
SOD BUSTERS Member
mine is on the other side fender about in the same place. been there since '02 and has been fine.
![]() '92 Eddie Bauer- C6 Swap, Roller 351W, MAF, RJM Harness, B.O.C. SCT Tune, 35" BFG's '78 Custom- 4" Superflex Lift, Mild 460, 8 Point Cage, 4.10 Gears, 35" MTZ's '96 F250- Tow Rig, 460, E4OD Punisher Valve Body, Triple Piler Gauges '92 F150- 2wd, Winter Beater, 3.73's, 5.0 '79 F250- 2wd, Farm Truck, Waiting Restoration '03 SVT Focus- Daily Driver, OZ Wheels, 6 Spd '86 Mustang- Fastback, SOHC 4.6L Swap Project |
#5 |
thanks Seattle. Thats where i was thinking of putting it. did you remove your smog pump or leave it intacted?
#6 |
My Bronco is Emissions Friendly in strict Washington State.
#9 |
![]() Join Date: Jul 2009
iTrader: (1) Bronco Info: 90' 351/E40D 38" tires, 4.88 gears, full float 8.8, lockers F&R
I mounted mine on the hood right over the stock ignition. You can see it in this picture. Thats a piece of stainless I bent to fit it. Has been in this truck for ten years. Anybody that doubts it's benifit is welcome to visit me. I can unplug it and plug the stock system back in. You'll know right away!
#10 | |
![]() Have you ever used one? I would also be happy to unplug mine as well, and my truck is well tuned with excellent ignition components. I have used it since pre-stroker with great results - after I learned how to properly install it...
#11 |
nice looking motor. I'm not against the smog pump itself or its purpose, more the space all the parts take up.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
