lots of tlc in my way - FSB Forums
Thread Tools Display Modes
Old 11-28-2012, 11:22 PM   #1
kpnorden
All right so I have an 1989 5.0 bronco. It sat for seven years in the back yard and I'm bringing her back but rear main seal aint my problem. When I finally started it I let it run for about an hour the started tinkering with it.
When i started to press on the gas it would try to die on me but would push through it. I tried to rev it a little bit and to listen to the problem. After doing that it started to pop and backfire. It keeps doing this while idling.
Need some advice on what to do.
Also checked distributor, wires, and plugs
Need some help...
kpnorden is offline   Reply With Quote
Old 11-29-2012, 12:30 AM   #2
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
Start with seafoaming the engine.
"hold my beer and watch this"
Hydroboost walkthrought
My Build Thread!! II
My Build Thread!! - retired
Ewgoetz is offline   Reply With Quote
Old 11-29-2012, 12:42 AM   #3
kpnorden
i put seafoam in the gas tank should I put it in the lines?
Old 11-29-2012, 01:50 AM   #4
kentucky4x4
kentucky4x4's Avatar
I have a 87 5.0 doing the same thing. I think it's in my fuel pressure but not sure. If you figure it out be sure to let us know what it is. Full tune up on mine didn't help any.
90 f150 302 stock 33" swampers
kentucky4x4 is offline   Reply With Quote
Old 11-29-2012, 05:50 AM   #5
tommyp1979
Corrosion in cap / rotor..fuel bad from sitting, fuel pressure?
tommyp1979 is offline   Reply With Quote
Old 11-29-2012, 07:22 AM   #6
Saltlife
Beach bumming it....
Saltlife's Avatar
Bronco Info: 88 XLT 351W C6 With way too much to list here done to it.
X2 would not hurt
Yes run it through a vacuum line.
X2 did you put new fuel in the tank?
What kind of prep work did you do to get it started and running after sitting for 7 years?
Josh
88 XLT with rebuilt 351W and C6. 7" lift on 35" 12.50 mickey thompson baja claw mtz's, SUMMIT headers, direct fit MagnaFlow High Flow cat, No mufflers, Saginaw, TRE flip, 3g 160 amp alt, HIDs, sliders, and custom bumpers with KCs.
FSB Official Health and Fitness Thread
My Build - El Surfista
Saltlife is online now   Reply With Quote
Old 11-29-2012, 11:20 AM   #7
riccnick
riccnick's Avatar
Bronco Info: 1986 Ford Bronco Eddie Bauer 351W
Hey man, I hope you didn't start it with 7 year old gas in the tank, seafoam or not, gas that sits for more than a month without treatment usually goes bad, with treatment you might get a max of a year out of it. But 7 years? I'm pretty confident that's just water now. I would start with draining the tank, maybe even flushing out the fuel lines if you can, some fresh 93 octane, and some fuel injector cleaner/ water remover in there to get the stuff that has already ran through your lines and injectors.
Also, change that oil! New plugs maybe, and check all your vac lines for cracks. 7 Years is a lot of time my friend.
-Nick
1986 Ford Bronco Eddie Bauer 351W H.O. 4x4 C6 Auto
2012 Subaru Impreza 2.0i Premium
Dearly Missed: 2010 Toyota Tundra DC Trd Off-Road 5.7 V8 Flomaster 50-Series Dual Exhaust
riccnick is offline   Reply With Quote
Old 11-29-2012, 12:46 PM   #8
kpnorden
Yea I did but now it's not even cranking replaced starter solenoid still not cranking
And what can I do to get that has out
Old 12-02-2012, 01:04 AM   #9
kentucky4x4
I poured fuel mate in mine and ran it till it was empty. Not saying its the best idea but why drop the tank when you'll never get it all out? I'm almost positive I have mine figured out. Will know for sure tommarow and will let y'all know what it was if it fixes it.
You may not post replies
Forum Jump
