Simple upgrade you should do now! - FSB Forums
Thread Tools Display Modes
Old 11-30-2012, 08:55 AM   #1
helirich
helirich's Avatar
So my tailgate window stoped working when it was up. Did the power direct to the motor thing and got it open. The problem was the switch that assures the gate is closed. I got to thinking, what does this switch do for me? It prevents me from moving the window when the gate is down. In 22 years of owning a Bronco, I have never "axcedentally" opperated the window when it was down. I have needed to oppperate it many times to work on it. It's not hard to defeat by clicking the latches, but why?
Solved. I just unpluged the switch and cut the wires right at the plug. Strip them and twist together. Done. I recumend you do this simple upgrade the next time you get a chance. It's alot eazier to do it now then wait till you have to hot wire the moter to get the gate open. LOL.
BTY The switch/plug is located behind the access cover on the drivers side. It is a little hard to see as it is behind the window rail.
Edit: also while you have the cover off, mark the plug that goes to the motor. That way if you ever have to "hot wire" the motor, you don't have to figure out which plug goes to the motor and which goes to the truck.
helirich is online now   Reply With Quote
Old 11-30-2012, 10:25 AM   #2
InsanePyro
You'll always be Kia-Boy
InsanePyro's Avatar
Bronco Info: '89 Bronco XLT. Front clip swap. 351 w/ C6. 4" lift. 33x10.5x15 BFG Mud Terrains
This seems like one of things that somewhere...somehow...will come back and bite you
Surviving is winning. Everything else is bullshit. Whatever it takes, kid. Survive.
Center your signatures you goddamn Neanderthals
InsanePyro is offline   Reply With Quote
Old 11-30-2012, 11:23 AM   #3
wdford
wdford's Avatar
Bronco Info: 1995 EB 351W, E40D
Agreed but these were built for the masses. We are of the enlightened few and would NEVER do such a thing.
wdford is offline   Reply With Quote
Old 11-30-2012, 11:38 AM   #4
CrazyBRONCOguy
CrazyBRONCOguy's Avatar
Bronco Info: See Signature
Mine has been bypassed for a few years now. While I do agree you should be able to adjust it and make the window work right, my switch was being extra finiky. I have never had an issue. I did solder and shrink wrap the wires when I did it.
To me this is along the same lines as a clutch start switch on a manual.
'92 Eddie Bauer- C6 Swap, 9" Swap, Roller 357W, AFR Heads, MAF, SCT Tuned, 4" Lift, 4" Exh, 4.10's, 33's
'78 Custom- 4" Deaver Lift, Mild 460, 8 Point Cage, 4.10's, 35" MTZ's, Clydesdale Steering, WH Trac Bar, E-Fans
'96 F250- 460, E4OD Punisher Valve Body, 3 Pod, Crane HI-6S Ign
'05 Excursion- V10, Warn Hubs, Coffin Muffler, Volant CAI
'92 F150 '79 F250 '86 Mustang '95 T-Bird '08 DS450X '01 Banshee '12 DS450XMX
CrazyBRONCOguy is offline   Reply With Quote
Old 11-30-2012, 11:43 AM   #5
sackman9975
"living life"
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
Old saying........"if it ain't broke, don't fix it"
I personally won't do this as sometimes the gate doesn't latch all the way once it's closed, you won't want to roll the window up against the track where it will bind.
~ Scott ~ My Tech write ups:
How to properly set the timing on a 302 or 351
Harmonic Balancer Crankshaft bolt removal
How to press rotors without taking them to a machine shop
~E303 w/Flowmaster 40 & 3inch exhaust rumble ~ 216k & counting. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 23 years ~
sackman9975 is online now   Reply With Quote
Old 11-30-2012, 11:48 AM   #6
FordsForeverEric
FordsForeverEric's Avatar
Bronco Info: '87- 4.9, Tremec RTS 4-spd, 33's, SAS
Mine has been like this since I had wiring trouble with the tailgate a year ago...
Even with my loose tailgate latches and hitting potholes my back glass hasn't broken yet
FordsForeverEric is offline   Reply With Quote
Old 11-30-2012, 11:58 AM   #7
defcon5
defcon5's Avatar
Bronco Info: 1992 XLT 5.8, SAS 8 inches and Tons
Exactly, and sometimes others may drive and use your bronco.
1992 Bronco XLT, 351w. 8 inch lift SAS on tons!
http://s1334.photobucket.com/
defcon5 is offline   Reply With Quote
Old 11-30-2012, 12:00 PM   #8
wdford
wdford's Avatar
Do what I do, "no you may not" :)
Old 11-30-2012, 12:07 PM   #9
defcon5
defcon5's Avatar
Ya, ya, ya, everybody says that, but one day someone else will be behind the wheel.
Old 11-30-2012, 12:15 PM   #10
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
I think modifications like this one made by owners are cool as anything. :)
Always have and always will.
Not all my modifications are for anyone else and this one ain't for me. ;)
There's been a few times when very competent adults and/or kids have
climbed in and they closed the tailgate behind themselves and the window
wouldn't go up because the tailgate wasn't latched good.
I caught it right away from the driver's seat and happily got out and re-shut
the tailgate for them and off we went. :)
Alvin in AZ
Alvin in AZ is offline   Reply With Quote
Old 11-30-2012, 03:05 PM   #11
task1
task1's Avatar
Bronco Info: '79 400m 0.30 over comp cam edelbrock intake/carb double exhaust 4in lift 33in bfgs
my tire carrier prevents the gate from becoming unlatched. Window will be ok as long as you dont slam door( ask me how i know )
task1 is offline   Reply With Quote
Old 11-30-2012, 03:51 PM   #12
Tullio
RAAAAAH!
Tullio's Avatar
Bronco Info: '90 FSB, SAS'ed, locked, geared, caged, gutted, built and filthy
NEVER!
302 roller, GT40 heads, E-fan, off-road cam, headers, 35x14.5 Pitbull Bias Rockers, 10" aluminum wheels, 4.56 gears, rear Detroit Locker, front Truetrac, built AOD, Kodiak auto steps, custom exhaust, full 2" DOM cage, PRP reclining suspension seats and harness, D44 SAS, 1.5" DOM/heim steering, Deaver coils, Bilstein 7100 14", F350 brakes
Tullio is offline   Reply With Quote
Old 11-30-2012, 07:19 PM   #13
inxy
Bronco Info: 88 Bronco 351 C6 33's redhead/saginaw
After two hours of screwing around I found a defunct tailgate window safety switch. Removed, spliced wires, no more problems. No problems since then a year ago.
inxy is offline   Reply With Quote
Old 11-30-2012, 08:30 PM   #14
helirich
helirich's Avatar
If you did, the worse that could happen is the window break. Its not like you would crash the truck. I dont think it would break. In any case, I always make sure the gate is shut.
In 22 years, I have let my best friend and my wife drive my truck. Probubly about five times in all. My wife cant reach the tailgate, let alone shut it. I would be happy to have my friend bust the glass. Then I could never let him live it down. (never happen) LOL
I know its hard to believe, but allot of people dont want to drive a truck on 38's. Go figure.
Old 11-30-2012, 09:17 PM   #15
sackman9975
"living life"
Exactly.....that's why it's not a upgrade for me.
I drove around with no window in the winter before......let me tell you, IT SUCKS!!!!
Old 12-01-2012, 12:20 PM   #16
helirich
helirich's Avatar
I think that would teach you to shut the gate or not to loan your truck to people you dont trust. LOL. But really now, couldnt you just put a piece of cardbord over it temporary.
Wait till you have the back full of sh*t and the window wont go down. Then what, break the window?
Old 12-01-2012, 01:14 PM   #17
sackman9975
"living life"
No.....
I've owned these trucks for 21 yrs...... I've experienced pretty much all they can dish out. I have my remedies.....
Old 12-01-2012, 01:38 PM   #18
JerryC
JerryC's Avatar
Bronco Info: 96 XLT 5.8 (gone)
When mine wouldnt move it was the "plastic" sleeves on the posts that gate latches to, they were just wore out. Enough slop the saftey switch wouldnt let the window move.
JerryC is offline   Reply With Quote
You may not post replies
Forum Jump
