#1 |
Hello,
I have been searching the forums for weeks but I am not really sure what I am looking for so I need a little help. I have a 1990 XLT with the 351w and an automatic transmission I would guess E4OD. The 4x4 is manual with manual hubs. Recently it would not go into reverse and would make a loud humming noise like radio static but it eventually shifted into it so I could get out of a parking space. Later it did the same thing when coasting around 55 in drive but only lasted a few seconds. After that I was going about 45 when it made the noise but there was also extremely loud banging, grinding, and every undesirable noise you can imagine. Now it won't shift into any gear and makes the the noises if attempted which I will not do again. ![]() I don't know if this means the tranny is shot or the transfer case or what and if it is worth repairing since this Bronco is pretty rusted out. I am just partial to it and would hate to see it go. Not sure what to do here. |
| Sponsored Links | |||
Advertisement | |||
#2 |
Charlie doesn't surf!!
![]() Join Date: Apr 2003
iTrader: (31) Bronco Info: 1992 xlt, 351EFI, .040, E40D, D44 SAS w/Trutrac, Detroit locked 8.8, MAF conv, Tweecer tuned..
If it's not going into any gear you're going to have to start tearing into things. not sure how good of a mechanic you are, but the transfer case is the easiest place to start and could be part of the problem.
#3 |
![]() Join Date: Oct 2010
iTrader: (8) Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
Ive had a shift fork in my transfer case break already. Left me stranded at a gas pump. Thought i blew out my trans but it ended up being the tcase. They are easy enough to tear into with simple hand tools. Do a search here i believe theres a write up on how to do so including a tool list.
![]() Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825 |
#6 |
Id open it up and see whats going on inside. And replace some seals while your at it.
#7 |
![]() Join Date: Jul 2009
iTrader: (1) Bronco Info: 90' 351/E40D 38" tires, 4.88 gears, full float 8.8, lockers F&R
Sounds like the T-case. Almost certainly the shift forks. I would take it apart. It can be rebuilt fairly eazy. Also they can be had a the yards pretty cheap.
BTY- it's not real heavy either. I've pulled mine many times without a jack. Just unbolt it and get under it and press it. (maybe 80 lbs.) It will not fall when unbolted, it has to be slid back abit. |
#8 |
My money is on your transfercase. Common problem with them. You could try putting the case into 4 low and see if it'll move the truck.
Regardless I'd reccomend tearing the case apart if for no other reason than to fix the stay-arm. Here's links to a couple write-ups: Allfordman's Shadowfax's Here's a exploded diagram of the 1356 (shamelessly swiped off Steve83's collection) ![]() Parts links are posted on Fordman's and Shadowfax's write-ups. I used tbtrans.com and was happy with their service. The entire job can be done with handtools, except getting the yokes off. I took mine to a local tire shop that rattled the nuts off for me. Ask away if you have questions.
1991 SA 5.8L, E4OD, BW1356 217,000 miles and rolling Second... and Fourth Owner! Last edited by 4NIC8R; 12-01-2012 at 06:56 PM. Reason: Credit to steve. |
#9 |
![]() Join Date: Dec 2007
iTrader: (41) Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
If you get grinding nose when placing the Trans back into park after trying to get the truck to move, it's the transfer case. This is because the output shaft of the Trans is still moving. Thus meaning your Trans is good.
~ Scott ~ ~My Exhaust clip on YouTube ~ 204k on the odometer and no longer a daily driver. ~ ~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
#10 |
Thank you for all the replies. I do get the noise when going back into park so that's a good sign. Before I tore it apart I wanted to see if I could find a decently cheap one and I think I have for $75 but I want to make sure they are interchangeable and it's worth it.
Here are pictures of the one on there: ![]() ![]() ![]() ![]() And the "new" one: ![]() ![]() ![]() My concerns are that I don't see on the old one those two holes closest to the front on the new one, the numbers are different, and I don't see any drain plugs. |
#11 |
My advice, rebuild the one you have. Any used one will have the stay-arm issue unless it has already been dealt with, which you won't know. If that tcase has over 160k miles on it then the stay-arm is going to be a problem. It's not really a hard fix and does not take much in the line of special tools.
As for the "new" one, it should fit. Take off the transmission adaptor first though, obviously. I do see the drain plugs in the first picture of it. I cannot read the numbers in this photo and am not sure what holes you are talking about. Edit: One thing I cannot see in the picture either is the speedo sensor hole in the tail housing. Is that case off a 92-96? I believe they changed that part, since they do not have a speedo cable.
1991 SA 5.8L, E4OD, BW1356 217,000 miles and rolling Second... and Fourth Owner! |
#13 |
iTrader: (0) Bronco Info: 1987 FSB 4" suspention 2" body. Straight 6 C6 trans
I have the same thing going on in my 87, only all my gears work except reverse. If I put it in 4 wheel drive then I have reverse. Any idea if it is maybe the same thing? Any help would be great.
Sent from my iPhone using Autoguide |
#14 |
Sure sounds like it. Does it grind in 2wd, reverse to park?
#16 |
It also makes the clicking/grinding like noise when I'm going over 25 and let off the gas. If I just tap the gas it stops for a sec.
#17 |
I'm almost positive your transfer case is going out.
#18 |
What is it that points you to the t case and not the trans? I just want to be sure before I go spend money.
#19 | |
If the output shaft is turning (meaning your trans is supplying output to the transfer case), you'll hear a grind from the park gear when putting back into park because nothing (transfer case) is keeping is locked. While in 4wd, it's keeping it locked and you won't hear it and your reverse works.
#20 |
Ok so I just got in my truck and it went into reverse just fine in 2wd. However it still makes like a Noise like a bearing that's loose and spinning to fast. And when I start slowing down the sound also starts to diminish, then fades away around 15 mph.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
