#1 |
iTrader: (0) Bronco Info: '79 400m 0.30 over comp cam edelbrock intake/carb double exhaust 4in lift 33in bfgs
gearing advice
Hey guys looking for some advice. I have a 79 bronco with a 400 0.30 over edelbrock alum intake, comp cam, howell tbi, detroit on back running 33 tires.
I dont think truck is underpowered. I mostly run sand dunes and on long hill climbs truck maxs out would regearing help out any???? On highway it does approx 2-2300RPM at 60mph |
| Sponsored Links | |||
Advertisement | |||
#2 |
![]() Join Date: Oct 2010
iTrader: (8) Bronco Info: 94 C150, 351/zf,5"lift,35" xterains,flow40, mac headers,sag swap, elec fan, 4WDB
What is your current gear ratio?
![]() Visit my build thread- http://www.fullsizebronco.com/forum/...d.php?t=211825 |
#3 |
TTB for short
iTrader: (0) Bronco Info: '95 L,'93 Bronc,'96 Turbo Dizzle
Whats the rpm range on the cam and intake? That will be the major factor...
Charity is injurious unless it helps the recipient to become independent of it. John D. Rockefeller |
#4 |
Im running stock gears 3.5? Forgot to mention that in 4 hi it feels likevit wont even move so always wheel in 4 lo
#5 |
Driving Stuff Henry Built
![]() Join Date: Oct 2006
iTrader: (9) Bronco Info: -90 xlt, 351w, e4od, 3.55:1, sag, warn hubs, trans cooler, 35" bfg m/t, -73, 400, np435, 35s
Sure, lower gears would give you more torque to the wheels. The trade off is higher revs on the highway, but your truck would probably appreciate it on the hills. 33's are larger than stock, so you currently have less torque to the wheels than it started out with.
Here's a good Gear Ratio Calculator. Plug in your current info on one side, & your new combo on the other, then hit Calculate on each to see what effect the changes will have.
Baba Looey's Favorite FSB Links........................Common Replies to FAQs ![]() “Don't find fault, find a remedy.” -Henry Ford |
#6 | |
![]() Join Date: Jul 2009
iTrader: (1) Bronco Info: 90' 351/E40D 38" tires, 4.88 gears, full float 8.8, lockers F&R
1. Does it bog down and down shift. 2. Or do you mean that you are spinning the wheels as fast as you can in 3rd gear-low range and want more wheel speed? If 1, (hard to believe in low range) keep it in 2nd. If 2, get bigger tires. I think your gears are OK. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
