92 F150 battery dies and no odometer - FSB Forums
Thread Tools Display Modes
Old 12-01-2012, 06:16 AM   #1
firelt90bronnco
Resident Wrecker Driver
firelt90bronnco's Avatar
Bronco Info: Sold-1990 Fullsize, 1995 FSB, 1997 F250 PSD, 1979 Bronco Custom with a big block
Ok, so I have a 92 150 5spd 5.0. Recently I changed the slave cylinder and for a week after the truck drove like a champ. One night the battery died. A quick jump and it was fine again for a day. Now, it'll only hold a decent charge for 1 hour. I pulled the positive terminal off with it running and it stayed running. I noticed the odometer is not displaying its mileage now too. I changed the battery to a newer and stronger one as well. Any guesses?
1992 F150 Lightning clone
1995 Bronco Eddie Bauer
My infamous line "you should have been swallowed"
firelt90bronnco is offline   Reply With Quote
Old 12-01-2012, 08:02 AM   #2
firelt90bronnco
Well, odometer returned this morning. I'm just not sure why she keeps needing a jump
Old 12-01-2012, 08:05 AM   #3
wdford
wdford's Avatar
Bronco Info: 1995 EB 351W, E40D
measure the draw on the battery and remove fuses one at a time. It's a quick and easy way to try and isolate the faulty circuit.
wdford is offline   Reply With Quote
Old 12-02-2012, 12:30 AM   #4
Steve83
Steve83's Avatar
NEVER disconnect a running vehicle from its battery - you're lucky you didn't fry anything. Have the battery checked with a MidTronics tester, similar to this:
Old 12-02-2012, 02:01 AM   #5
pfun41
pfun41's Avatar
Any auto parts store can check the battery with a tester. If it checks out then there must be an electrical fault that drains the battery when its not being charged. A bigger battery Isn't going to help.
As mentioned, use a multimeter to measure the draw at the battery and pull the fuses one at a time until it goes down. When it goes down to normal the fuse you pulled will be for the faulty circuit. Then you can go from there.
1994 Bronco 5.0 liter E4OD factory MAF_31" Bfg A/Ts_130 amp 3g, Auxillary transmission filter,cooler and temp gauge, Homemade Y pipe
my build: http://fullsizebronco.com/forum/showthread.php?t=176792
my youtube: http://www.youtube.com/user/pfun41#p/a
1990 Bronco 302/AOD stock - Sold
pfun41 is offline   Reply With Quote
Old 12-03-2012, 11:29 AM   #6
moz_21
moz_21's Avatar
Bronco Info: '89 XLT, 5.8L, black/red, 6" Skyjacker lift, 35" MTZ's
92 has the older style alternator I believe. Mine shorted out in the regulator, had a 3-4A draw. I replaced it with the 3G alt.
'89 Bronco XLT, swapped/rebuilt 5.8/AOD, MSD & timing bump, 6" Skyjacker lift, 35" Mickey Thompson MTZ's, 4.88 gears, Detroit TrueTrac (fr) and Locker (rr)
'96 Bronco, EB, MAF 5.8L/E4OD, stock, (eventual) tow rig
moz_21 is offline   Reply With Quote
You may not post replies
Forum Jump
