#1 |
How difficult to pull 302
I finally got the chance to finish my motor after my honey du list.
I will be hold tranny with straps will use smaller wheels up front to lower it, will remove hood to make life easy. Am I missing anything? Below is link to motor on test stand. My plan is to run for 15 min a time on stand before swap end of dec. http://www.youtube.com/watch?v=bPBH6...e_gdata_player |
| Sponsored Links | |||
Advertisement | |||
#2 |
Forward Some Money
![]() Join Date: Mar 2004
iTrader: (5) Bronco Info: '89 Bronco, 5.8, MAF, Summit shorties, Bassani SS, AOD, Tru-trac posi, Stocker
Why are you running on stand? New cam?
When you shut it off (since their is no exhaust) stuff something non-flammable into the headers. You don't want the cold air racing into a hot head.
Click HERE to visit my frame-off NOS restoration thread. Photobucket Album ....and a crap load of pictures.... Last edited by j. r. Nice; 12-05-2012 at 01:03 PM. |
#3 |
Yes new cam. Running on stand to find any issues before swap. Already found main seal was leaking. Plan is to run motor with water this weekend with 15-20 min runs to check for leaks. Any odd sounds ect.
#5 |
Loves the vag.
![]() Join Date: Aug 2004
iTrader: (8) Bronco Info: 2006 Kia Spectra
but having to install the cooling system twice causes more chances for damage (improper use of a screwdriver...been there done that) or leaks anyway. If you do the job right you'll have nothing to worry about.
#6 |
Cooling is done via a water hose through thermostat water neck. Insert wrap at water pump outlet and regulate water flow.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
